Volume automatic decreases. Have no control of volume
  • 242 Answers
Ensure nothing sticky has been spilled on the TV or the remote, causing the volume down button to stick. Remove batteries from remote to rule it out. Carefully inspect TV volume control for a sticking button. If you find it is sticking, get electrical contact cleaner from Radio Shack and spray the button. Ensure TV is unplugged first.
Posted on Oct 27, 2008
Why does volume control not work?
I plugged in in the cable that works for the ears phones from the TV to my Lifestyle system and it fixed everything for me. Good luck hope this helps you.
Jun 29, 2014 | Bose Lifestyle 5 System
How do I change radio volume on the alarm?
This clock is supposed to have an automatically "increasing" volume feature (starts off low, gets louder over a minute or so).
If not sufficient, look on the top right side of the clock, there should be an up/down volume control. It is a black oval-shaped button with a picture of a sound speaker in the middle. Push it upward to increase volume and downward to decrease volume. Unfortunately, you have to have a flashlight or light on to see it because none of the controls are illuminated.
Dec 02, 2013 | Sharper Image Sound Soother White Noise...
Volume goes up and down by itself
Hi wally,
It is sad your having a problem with volume automatically increases
and decreases without any manual input.
These could be caused either by a component on the circuits
( front panel), a faulty regulator or microprocessor.
Components :
can be such as tact switches , diodes
PCB foil tracks, connectors. These means it may needs servicing.
Start with the basics, take out batteries from the remote, and see
if it affects the receiver volume or the one causing the problem.
If the symptoms still persist, One may have to open it up.
and check on it.Have a tech to guide you if you feel you can DIY.
One of the ways to tackle these problem is to take out the
tact switches , or have it disconnected . And use the remote
volume control to adjust the main volume.
If these works for a day or two, find or order replacements
for the said bad components.
There might be other ways but that is what Tech are for.
Let us know what you find , or needs further assistance.
Oct 29, 2012 | Pioneer Vsx-d811s Audio Video Multi-...
My Amplifier is in good working condition, except for the volume control has gone weird Using the remote, you can increase volume, but not decrease volume. On the unit, rotating the volume control...
Cleaning the contacts may help. The volume knob should pull off. Once its off use a non-flammable contact cleaning spray to clean the contacts behind the knob.
Electronics and automotive stores should have this.
May 16, 2011 | Onkyo TX-DS494 Receiver
I have located the volume control button on my monitor but every time i pres it it decreases the volume. I need to Increase the volume not decrease it. Help
You've failed to mention the make/model of your monitor. There should not be a single button for volume control, as volume control is either up or down. Try the button above the one you've been pushing.
May 11, 2011 | Computers & Internet
Dont know how to control the volume, i cannot find my manual
Most of the time their are multiple ways to do this.
1. On the speaker in the lower right hand corner left click and a volume bar appears. Slide it up and down. It should be adjust to 75% IMO.
2. On your keys there should be symbols that look like speakers that should match the color of you "fn" key. Press and hold the fn key and then press the corresponding speaker key to increase or decrease the volume.
3. There may be a rotary volume control on the front of the laptop case. It's as simple as turning it to increase or decrease it.
On the volume bar in windows verify that the muted in unchecked.
Mar 10, 2011 | Computers & Internet
Everything lights up and is working,but i have no sound
Do you accidentally have it muted? The Mute button, located on PASSPORT's top panel and SmartCord. Have you turned up the volume on it? Volume Control (VOL) To increase or decrease the audio volume, press and hold the (+) or (-) volume control buttons located on the top case. A sample alert tone will be generated, along with a corresponding bar-graph on the display. Once you have reached your desired volume level, simply release the button. This level will be stored in memory. In Preferences Auto Volume is the default. This feature will increase the audio alert level automatically when the ambient noise in the vehicle is high. Good luck.
Mar 06, 2011 | Passport 9500i Radar/Laser Detector
Toshiba volume increases by itself
yesterda i ve repaired a laptop with the sam problem. i hav done all reinstallation of windows and drivers.
but this is very funny when i found that the inbuilt key of laptop volume control was pressed automatically so when i try to decrease volume it increases automatically.
so please check for your touchpad drivers and check that any key is not jammed in laptop/desk top.
May 09, 2010 | Microsoft Windows XP Professional With...
There is a ribbon cable between the laptop & the screen. It sounds like you have a short in that cable. If you're not good with tedius electronic repairs, it would be best to have a shop repair it.
Mar 25, 2009 | Gateway Computers & Internet
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
