Question about Electrolux Dishwashers
Electrolux error code hd
What does error code Hd mean on my Electrolux dishwasher model EIDW6305GS
COXY
  • 76 Answers
SOURCE: Electrolux Gallery Dishwasher Error Message AL3
It sounds like it could be a heater problem, I would check this first
Posted on Nov 27, 2007
SOURCE: error code 01 on elecrolux dishwasher EIDW6305GSI
Usually the error code 01 means you backed up water in the unit. First be sure that the drain is clear.  Run the garbage disposal and be sure your sinks are draining.
I got lucky on a EIDW6105 unit by trying this.
All the lights are flashing and it shows error code 01.
Push down on two of the buttons and hold (I pushed on the Favorite and Heavy buttons), until the flashing stops (about 8 seconds).
The machine now showed and error code 08.  Then hit the start button.  My washer then cleared and runs normally.
Hope this helps, better than a sevice call to clear the code.
Posted on Dec 28, 2008
SOURCE: error code on electrolux dishwasher,
electrolux wave touch dishwasher giving error code 1?
Posted on Oct 20, 2009
SOURCE: electrolux dishwasher error code 01
I found the error codes in the owners manual, (01) is a leak. I called customer service (no wait time) and they said there is pan under the tub that will contain and detect water if it leaks. They said I could wait for it to dry out. They said there could be a hose that became loose or had a pin hole in it. After I hung up with customer service I did my own problem solving. The diswasher washing cycle was just started. Then then the door was opened 5 to 6 times to add more utensils and dishes while the the machine was running. Then the error code came on. this was the first time this had happened. I beleive water seeped doen through the hinges and the seal into the pan. I unpluged the dishwasher and disconnected the water line and pulled it from under the counter. Then lifted the diswasher onto 4 inch blocks of wood placed under the feet. This made it easier to access the pan. It had 2 screws inthe front and 1 in the rear with 3 clips. I removed the pan and dried it. Inspected the hoses under the unit and determined none of them had appeared to be leaking. I positioned a fan to blow under the unit to speed up the dry time, about 1/2 an hour. Put everything back together and ran a high pressure hot water cycle and found no leakes, so far.
Posted on Jan 12, 2010
tattootech2
  • 72 Answers
SOURCE: ewdw6505gso electrolux. error 1. have turned off
the water will have leaked into the drip pan underneath, which is installed to protect your floors. Unfortunately, only way to get at it is to pull out dishwasher and remove 3 phillips screws that hold it on. In order to repair leaks, Electrolux came out with a "leak kit", which is part number 154769101. Comes with all parts that they had leak issues with
Posted on Apr 07, 2010
I have an error code on my Electrolux dishwasher EO?
Hello Judy, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "EO". The error code "EO" means that you could have a possible issue with the flow controller. I would recommend performing a reset on your dishwasher and this could help clear out any potential miscommunications. You can reset the dishwasher by disconnecting power from it for at least ten minutes. If the reset does not help correct the error code I would recommend having a professional technician out to perform a full diagnosis. Hopefully this information is helpful to you. -Matt
Feb 03, 2016 | Electrolux Dishwashers
No water flow
Hello Bob, I appreciate your post!
Based off of the inquiry your Electrolux dishwasher is not allowing water to flow inside of it and it is producing an error code of Hd. It appears that the Hd error code is an invalid code. I would recommend performing a reset and you can do that by flipping off the household circuit breaker for at least ten minutes. If this does not help resolve your issue can you please comment with your model number? You can locate the serial tag (which lists your model number) on the inside left hand wall of your dishwasher. With this information I would be able to assist you further. I look forward to helping you further. -Matt
Dec 01, 2015 | Electrolux Dishwashers
ELECTROLUX WAVE TOUCH GIVING ERROR CODE 4
Hello JOHN, thanks for your post!
From the information you have provided your Electrolux dishwasher is displaying error code 4. "E4" stands for drying damper which means it could be a potential problem with your damper or the main control. I would recommend performing a reset and that could clear any false error codes. To reset your dishwasher flip the household circuit breaker off for roughly ten minutes. If that does not help correct the issue I would recommend having a professional technician out to properly repair it. Good luck. -Matt
Jan 09, 2015 | Electrolux Dishwashers
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux Dishwashers
F0
Hello Friend, this is Z. I am pleased to help you!
I see that your post is listed under Electrolux Dishwasher; however please help me understand what your concern is? Is your dishwasher getting an error code F0 or are you seeking an Owner's Guide? May I have your model number please? The serial tag, which lists your model number, is typically located on the right side as you open the door. Thank you!
Jul 14, 2014 | Electrolux Dishwashers
ALL LIGHTS FLASHING
Find main breaker, totally cut power to dishwasher. It offer clears out circuit glitches and lock ups
Sep 15, 2012 | Electrolux EIDW6305GS Builtin Dishwasher
Electrolux dishwasher error code 4
Hello, scot
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Oct 02, 2011 | Electrolux EIDW6305GS Builtin Dishwasher
ER 01 error, leak detected, but there is no apparent leak
Hi, there is water lodged in the bottom pan of the unit. (Unit has to be pulled out to get to the pan.) Am thinking that the back legs of the dishwasher is too high and water is unable to drain out properly. So lower the legs and pull the dishwasher out in about 2 months to check for water in the pan.
That will solve the problem....
Jun 28, 2011 | Electrolux EIDW6305GS Builtin Dishwasher
Dishwashers Logo
390 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
