Question about Spektrum Dx6i Computer Radio
Broken Trim switch DX6I
Two months ago I sent my DX6I in for a broken trim swith,(throttle). Yesterday it happened again. Not wanting to spend $20.00 for shipping again, I opened the back and found the problem.Looking at the throttle trim switch I found the spacing where the rocker contacts the 2 button switches, the gap was too large for contact.
This is the second time this happened is there a more robust replacement trim switch available ? or how do I permanitely fix this one?
There is a solution. East R/C manufactures aluminum replacement trim switches AND aluminum roller menu button wheels for this radio and others.
Posted on Jun 26, 2009
I agree go with the Aluminum trim tabs from East RC, the store is actually right down the road from my house and they are great,honest people. See the links in the other post. Yes they are costly, but they will last forever and breaking the trim tabs is quite common. East RC makes those in their shop they do not import them so you probably won't find them any other places for the same price/quality.
Posted on Jan 17, 2010
  • morengin Mar 10, 2011
    There is another outfit on the West Coast making them. I just purchased 4 of them for $23 delivered. Contact them at
Do you want to sell it as is if so how much thanks
Posted on Jan 03, 2009
    New Friend:
    Problem Solver:
  • 5 Answers
This is a common problem. Fix it yourself and re-inforce the repaired switch with CA or Hot Glue It will hold forever!
Posted on Jun 16, 2013
Why will trim & tilt on my outboard work sometimes and sometimes it will not?
I would look for a corroded ground wire or a connection that has a corroded connection. Clean all ground and hot lead connections, then seal them from moisture.
Sep 14, 2014 | Cars & Trucks
Trim relay solenoid 1993 mercury 75hp
swop the solinoids and try again if then goes down and not up then the solinoid is duff ! if nothing then check the trim switch wires with a multi metre , check wires not broken etc also !
Mar 23, 2014 | Light Boating
Spektrum dx6i rudder error
Hi you need a new rudder motor
Mar 22, 2014 | Spektrum Dx6i Computer Radio
Tilt trim go up wont go down 2003 johnson 140 hp 4 stroke
You may want to check service bulletin #2002-052. Some of these motors supply too much voltage to the trim switch at the throttle lever and that trim switch stops working. There is an add-on harness #586806 that fixes this. If you can still tilt and trim the motor at the trim switch that is built into the motor housing this is likely the problem.
Jan 30, 2012 | Boating
Replace the dash mounted ignition switch at a 2000 malabu
first disconnect negative battery terminal. ( on models equipped with the theift lock audio system, be sure the lock out system is turned off, before disconnecting battery ). first remove dash board trim around the trim has to come off of dash. after removing trim on dash, there are 2 screws to re move ignition swith remove these screws, then pull out switch and disconnect the wiring connector. you may have to wiggle the switch one way or the other to get it out. the trim on dash just pulls straight out. us something to get behind trim and pop it out. be carful the trim will crack very easy. good-day !!
Jun 11, 2011 | 2000 Chevrolet Malibu
The back latch won't open now on the trunk door. All kinds of rust chunks were falling out of it when we tried to close it. Now it's broken. It didn't want to close at first now it won't open at all. Seems...
There is no easy cheap fix especially if you rush into it. It can be $300 in parts, plus your efforts.The handle for the back htach has likely rusted a ad seized. If you put your hand on it you can likely move it back and forth and then activate the lock and unlock modes with your power switch inside the vehicle.
The wide plastic trim above your license plate MAY need to be removed, the problem is it's retainer bolts will also be rusted. Access is from the inside underneath the back door trim panel and as you attempt to remove them they tear out of their plastic mounts in the molding.
There is a pivoting handle underneath the trim which is the one you normally grip to open and close the door manually. It is likley seized at it's pivot point due to rust buildup. If you can put a fine long balded screwdriver up beside the handle and twist gently and scrape, while spraying with a rust buster of some type, you may be able to free the handle, temporarily and rust will crumble out during the process.
If this does not free it, the bolts holding the trim must be removed to give you more access.At this stage the bolts often shear from the plastic outer trim and require the entire panel replacement.
Go to a LEXUS dealer and get the cost first and ask to see the components on screen or in hand, which you are working on before you take the plunge. Explain to the parts counter that you may need the parts and are trying to evaluate the task at hand.Then decide what you are prepared to spend.
FYI An experienced tech can seldom save the outer trim so be prepared....Best of luck, be gentle and patient
Oct 01, 2009 | 2000 Lexus RX 300
Motor died when I slowed down, and wouldn't crank again
Some motors have limit switches built in to kill the ignition if the motor is started at odd angles. The trim is different for speed and passenger load. The limit switches may be adjustable to eliminate that problem. Usually when you go to dock the boat will fish tail if the trim is too extreme for slow speeds.
Apr 07, 2009 | Boating
Power door lock switch replacement
Remove or Disconnect
Door handle trim plate.
  1. .Install or Connect
  2. Electrical connector and door lock cable.
  3. Trim panel by engaging hooks on backside of panel.
  4. Push pin fastener in defroster duct.
  5. Screw from behind lamp assembly.
  6. Courtesy lamp assembly.
  7. Two screws in arm rest.
  8. Arm rest cover plate.
  9. Door handle trim plate.
There May Be A Need to Drill Out RIVETS that Hold Motor in place,. Just Replace with>>MACHINED SCREWS & BOLT'S
  1. Trim panel. See: Doors, Hood and Trunk\Doors
  2. Four tabs retaining switch.
  3. Electrical connector.
Install or Connect
  1. Electrical connector.
  2. Snap switch into trim panel.
  3. Trim panel.
Mar 14, 2009 | 2000 Buick Park Avenue
Broken bezel/trim on door of GE Profile Spacemaker XL MICROWAVE.
You need to call GE customer care and order the trim you need. Make sure they will ship the replacement guide with the part. Before you do that however, carefully inspect the door to see if the old trim can be easily removed. This is important! You must determine that the door/gasket will not get out of alignment in the process. If this happens, dangerous microwave energy can escape.
Nov 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spektrum Dx6i Computer Radio Logo
1,862 people viewed this question
Top Spektrum Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Spektrum Toy Expert? Answer questions, earn points and help others
