Question about Sony Handycam CCD-TRV108 Camcorder
Camera won't play or record
A couple of pieces fell out of the camera mainly a roller and a little white piece where can I get a repair manual?
  • 10,594 Answers
Please insert roller on pinch roller shaft and put white plastic piece (lock) on it. Roller location is shown in below exploded view of camera mechanism.
Need further info / help, let me know.
Posted on Oct 27, 2008
HP camera piece fell off when trying to open it. Where does it belong?
U are in deep doo doo because if your unit is out of warranty HP will not do squat for you!
Apr 30, 2017 | HP Photosmart M537 Digital Camera
My window i thought came off track however when i got my panel off a little white piece was broken and my window wont stay up
That white peice could have possibly been on of the rollers from the regulator or a guide.
Sometimes you can purchse a new roller and it will need some pressure to snap it onto the pin. Or you can purchase a repair part that is the roller already on a pin and the old pin needs to be ground off from the back side (its like a rivet smashed onto the regulator or guide).
Then that white piece could have came from something else. Don't really know unless you look.
Aug 30, 2011 | 2000 Pontiac Grand Am GT
WHY MY LCD WONT WORK BUT CAN RECORD THROUGH THE EYE PIECE
send it in for repair. You may have pointed the lens at the sun while carrying the camera around and burned out the lcd.
Jun 27, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
Missing piece, camera will not turn tape
the pinch roller goes here:
you are missing the snap spring too, which is used to lock the pinch roller.
May 21, 2009 | Sony Handycam DCR-TRV240 Digital Camcorder
Printer rollers came off in paper jam and i cant get them back on
After a week of frustration trying to get the blasted thing back in--I could get the roller piece back in but not with the wire and could get the wire back on the little knob that holds it but that would prevent the roller piece from going in, I cut a notch in the white plastic above the spring hole so that I could, with very small needle nose pliers, hold the straight part of the sprint up while I put the roller piece in place. I then let the spring down through the notch I cut. It took a couple of tries but it all was pretty easy once the notch was cut.
Feb 10, 2009 | Epson Stylus Photo 785EPX InkJet Printer
Cat jumped on top of printer and 2 pieces popped out
Hi there you will have to remove the top cover and you will be able to see where it goes as the roller in question is the paper eject roller. there are usually four screws under the top cover and also at the rear of the machine. The picture where the roller is resting on the top of the printer the roller is situated right under that also that white bushing holds the roller in at one end usually the left as you look at the machine from the front.
Thanks J
Jan 20, 2008 | Brother HL 5250DN Laser Printer
Soldering 'Card Cover Open' Switch Closed
I had the same problem after a little plastic trigger thing fell out of the hole above where it says push to eject. After poking around for a while I took the camera apart (remove 7 screws) which made it much easier to see, with a magnifying glass and lamp, what the problem was. A damaged wire that needed to be connected to something. Only the very end of the wire was visible, inside a small white plastic box thing. The plastic box thing eventually fell apart with my attempts to put in bits of wire of varying shapes. When it came loose I was left with a short stiff bit of wire. I took a strand of copper wire (from an old piece of electrical wire), twisted it so I had a small loop at one end, looped it over the end of the stiff bit of wire, and then curved the rest of the wire (about 3 - 4 cm long) so it was resting on a silver piece of metal just below where the white plastic box had been. Put the cover back on and the camera worked. Needless to say, it won't let me know if I've left the cover off, but then it won't work unless the cover is on, so it doesn't seem to matter. Saved about $100.
Aug 13, 2007 | Olympus FE-130 Digital Camera
A part has fallen out.
The component that fell out is called a tape guide. The guide assembly fits into the guide rail on the supply side (left side) of the drum. You will notice another guide to the right, this is the take up guide assy, it sits in the guide rail assembly as well. There will be a silver shaft sticking up from the guide rail where the tape guide should be seated, with gentle pressure, the guide should snap back on and the unit should operate correctly. Please do not touch the drum surface as this may damage the video head assembly. Hope this helps you, good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | JVC GR-SXM265 S-VHS-C Analog Camcorder
Sony Handycam CCD-TRV108 Camcorder Logo
161 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
