Question about Lands Phones
Paanasonic kx-tg8321e base station with 4 phones
The Machine
  • 788 Answers
SOURCE: I have a KX-TG6700 base
The KX-TG6700 manual at: http://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdfhttp://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdf
States:
For best performance
Base unit location/avoiding noise
The base unit and other compatible
Panasonic units use radio waves to
communicate with each other.
For maximum distance and noise-free
operation, we recommend the following:
LPlacing the product away from electrical
appliances.
LPlacing the base unit in a HIGH and
CENTRAL location with no obstructions
such as walls.
LRaising the antennas vertically.
LIf you use the handset near a microwave
oven which is being used, noise may be
heard. Move away from the microwave
oven and closer to the base unit.
LIf you use the handset near another
cordless phone’s base unit, noise may
be heard. Move away from the other
cordless phone’s base unit and closer to
your base unit.
Have you considered all these points?
Is there a way you can move the base station to another location in your house to see if the problem get better? I don't beleive your base station is faulty, I suspect interference from something.
I don't think the 2.4GHz set is causing any issues, but you never know, try unplugged it for a while to investigate.
If you do determine that the base station is faulty there probably isn't many options to get it repair other than sending it to Panasonic. May be cheaper to buy a new base station to go with your extra handsets.
Good Luck!
Posted on Mar 14, 2008
jerryg50
  • 1673 Answers
SOURCE: Panasonic Phones are on mute and will not work
The following is generic for most cordless phones:
Did you check to make sure that the phone is not in the intercom mode? If this phone has a base station speaker phone, make sure it is not on mute. Some of these phones have a fax connection. Make sure your phone line is not accidently pluged in to the fax section. Also if the phone has a fax monitoring feature check the the setup menu that the fax is not enabled. If the phone has an answering machine mode, make sure that this feature is turned off.
In the worse case:
There may be a defect in the X-Mit section of the phone. I would suspect the fault to be in the base.
Jerry G.
Posted on Apr 13, 2008
SOURCE: Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Posted on Aug 27, 2008
Z1G ZA9
  • 122 Answers
SOURCE: lost instructions for Panasonic telephone KX-TG8321E.
Hi, you can find a free download here...
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
Just type in your model number and it will bring up a link to download 'operating instructions' or a 'quick guide'.
Hope that helps?
Posted on Apr 30, 2009
  • 4 Answers
SOURCE: I have a Vtech 2431 base station with 4 phones,
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time. Then all you have to do is re-register handsets...
Posted on Aug 16, 2009
Panasonic KX-TCD25AX cordless phone. Why can't it find the base station?
several reasons
too far away from the base station
too much interference between the phone and the base station ( buildings, iron sheeting etc)
the phone is not programmed into the base station memory-- re do the system program where the base station recognizes each phone and sets it's number for identification
May 14, 2015 | Panasonic Lands Phones
How do i sync my panasonic phones cordless kx-tga810
335 is the magic code when you want to remove a previous handset or base station registration!
Handset:
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
Dec 23, 2013 | Panasonic KX TGA810 1Line Cordless...
How many handsets does a Panasonic KX-TG5561 base station support
Yes. The base unit can support up to 8. (one is already included)
Jan 22, 2013 | Lands Phones
Panasonic KX-TGA711E
this sounds like you are either out of range of the base unit or your base station isnt plugged into the mains, ensure you have the base station plugged into the power and the phone line from the wall socket is plugged in, the base station controls all the handsets, if it isnt plugged in they wont work, good luck
Aug 05, 2009 | Panasonic KX-TG1033S Cordless Phone
Lost instructions for Panasonic telephone KX-TG8321E.
Hope that helps?
Apr 30, 2009 | Lands Phones
Caller ID has aparently stopped working
Based on a user's review of this phone system on Amazon, I unplugged the base station, waited a few seconds and then plugged it back in. Caller ID display and announcement both work fine.
Mar 23, 2009 | Panasonic KX-TG5777 Cordless Phone
Panasonic KX-TG6071B - Feedback from base station
-Possibly the hands set is away too far and its base can't communicate.
Good luck & enjoy
Mai
Oct 23, 2017 | Panasonic KX-TG6071M Cordless Phone
I have a KX-TG6700 base station and 4 Handsets. When I have been calling on the handsets I have recently found that there is static on the line. Later I realized that there is problem with the DTMF being...
States:
appliances.
such as walls.
your base unit.
Good Luck!
Mar 14, 2008 | Lands Phones
Lands Phones Logo
23 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
