Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
HD RCA TV NEEDS REPAIR
I had a tech come out and said I need to replace the convergence board.
The model number is R52WH74YX81. Do you think you can help me out with fixing my TV?
    Genius:
  • 1,030 Answers
Let see if i agree with the tech. first question what does the picture look like. Second in customer menu under setup do you have the "convergernce " option in the menu if not it might be a simple inexpensive repair known as fl231 fuse. if you have the option try autoconverging see how far it gets. does the picture bow in from the top and bottom. there are three possible cuircit boards that effect convergence. And it takes a technician sometimes to adjust... let me know and will continue to troubleshoot this down
Posted on Oct 29, 2008
Hit by litning
my friend it is the tv tunner that needs to be replace you will have to take your set to a repair shop for repairs.tv needs qualified tech to repair them.you might cause injury to your self.although you want to save money it is best to have a tech deal with your tv,than doing more damage to your tv and to yourself.it will cost you less on the longer run.good luck
Jun 19, 2007 | RCA Scenium HD65W20 65" Rear Projection...
Tip
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W..
· Symptom: No Convergence, Picture is bowed and distorted, colors don’t align.
The Fuse for the convergence power supply has blown
You'll also notice that the convergence settings have disappeared from the on screen menu. The fuse likely blew because of a fault on the convergence board. If you've never done soldering or dismantled a TV before this is probably not the best place to start. The back cover needs to be removed and the fuse (see picture) identified, the deflection/power supply board needs to be unplugged (label or mark all connectors beforehand) and flipped over and the fuse checked/replaced. You need a soldering iron and solder ****** or solder wick and a multi-meter to check the fuse. If you want to tackle it yourself see attached image for reference or get a quote from a repair shop (approx $200-$300 Total) the convergence board may also need repair.
  • Symptom: Dead Set - TV Tries to Start or intermittent dead.
The set could be in shut down mode due to a fault detected in the power supply, vertical or horizontal deflection circuits.
The common problems with this chassis that will cause a dead set or intermittent dead set symptom are, bad power supply capacitors, bad flyback, bad HV cap in horizontal output circuit and cold solders (on opposite side of board) especially under the flyback area. To gain access to replace any of these parts the back cover needs to be removed and the deflection/power supply board needs to be unplugged (label or mark all connectors beforehand) and flipped over.
These are only the most common problems and it could be any number of other faults.
If you have electronic (TV) repair experience check the items mentioned (see picture), otherwise it's best to seek a qualified RCA tech for an estimate/service call.
· Symptom: Erratic operation of set – turns off by self, the volume or channel changes by self or on screen menu appears intermittently.
Switches on the front panel assembly (FPA) problem.
What happens with this model is the FPA switches (one or more) start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to initiate erratic commands.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disassembly.
Note: The remote will still work with the FPA removed so the set can be tested.
Hope this helped, johnnydiode, Fixya.
on Dec 08, 2009 | Televison & Video
Picture not in focus
Devices: All projection TV's (HD or analog), especially Samsung
If its a Samsung HCN653W (or similar model), the first thing to try is the menu option named "Magic Focus", which tunes the set's focus.
Otherwise, it sounds like a job for a convergence. Perform a convergence procedure on your TV, and if the problem recurs within a few days/weeks, then your TV's 'convergence amplifier' board (aka "convergence amp board") is starting to fail.
This board may fail completely, in which case, your convergence procedure will fail to improve the picture.
A "convergence procedure" can be performed entirely by just using the appropriate setup menu option and your remote control.
This board may partially fail, in which case your convergence procedure will properly converge the Red, Blue, Green colors on just part of the screen, whereas a properly functioning convergence amp board will allow complete convergence of the colors across the entire screen.
Your TV's convergence procedure instructions will be found in your TV's Owners Manual.
At least one Projection TV manufacturer recommends that the consumer perform a convergence procedure every 30 days, but most TV owners find that excessive, and might only do one when (a) there's an evident color convergence problem in any part of the picture, or (b) once every 3-6 months.
How-to video: www.youtube.com/watch?v=esk4nYZKFcg
how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
cost to you: $zero
If the convergence amp board is bad, cost for a service call would be $300 (USD) plus $100 for a new board plus 50% markup on parts = about $450 (USD)
Cost to order a new board online: about $100 (USD) + shipping + sales tax.
Alternatively, if you can solder/desolder STK's (Power Amplifier Integrated Circuits), one can repair a convergence amp board for as little as $30 (USD) or so.
Dec 04, 2011 | Sony Televison & Video
My RCA D52W26 projection Tv is blurry. Digital board replacement
You cannot replace it yourself sir because there are a lot of adjustments(electronically not mechanical) and you need an equipment to transfer the data from the old EEPROM to the new one. If the convergence is fine then the fuse should be ok..Picture is blurry??? 1. could be a dusty CRT lens, you can clean those 3 lenses by taking off the front speaker grill then there's a small hole that you can see the lenses... or the mirror needs to be cleaned also. 2. maybe it needs a convergence alignment, pls check your owner's manual if available. thanks:)
Dec 28, 2009 | RCA Televison & Video
HD 1080 Series (WD-55809) - Color convergence issue
I don't know of illustrated instructions but I can provide you with the service manual for your TV. It does have illustrations of disassembly and components as well as schematics. Your set very likely needs new convergence IC chips. This is a common problem with all projection TVs. The repair is not expensive ($60-75 in parts)  but does involve unsoldering and removing the old chips and soldering in new ones. Some times there are some fuses that need to be replaced as well. If you want the manual provide me with an email address.
Dec 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
RCA HD TV, convergence needs to be run and it is
You have a bad capacitor most likely on the convergance or other system board. You can purchase a manual and tester to find the fualty component.
Sep 13, 2009 | Televison & Video
Need of a Convergence Board for an RCA PROSCAN Model 80690WW1
You can order a replacement Convergence Board or Convergence Amplifier Board for this model (PS8069) from a major RCA parts distributor at the link below:
RCA PS80690 Replacement Part Convergence Board
RCA PS80690 Replacement Part Convergence Amplifier Board (2F27039-502)
Please note, these boards are no longer available from the original manufacturer (RCA) and only appear to be available from PTS.
Apr 08, 2009 | RCA Televison & Video
RCA PICTURE
Its a convergence problem either the convergence board or the convergence power supply board needs replacement. The following link will help you determine which board you need, just leave them a email with your model number and symptoms.
http://servicemanuals.vstore.ca/
Jul 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Kp-57ws500 sony projection tv convergence problem
Sony convergence problems
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Jan 22, 2008 | Sony KP-41T65 41" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
168 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
