Question about Whirlpool Washing Machines
F1 code on whirpool duet dryer wed9200sq1
Model #wed9200sq1
fridgetech
  • 473 Answers
SOURCE: Code F1 @ Whirlpool Duet Sport Washer
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00003&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0607261&backToLink=Return%20to%20Sub%20Components%20list.
Posted on Dec 12, 2008
  • 9 Answers
SOURCE: f1 code for duet sport
you have a bad machine controller, check the warranty in your use and care guide to see if the part is covered under manufacturer warranty.
Posted on Jan 28, 2009
  • 117 Answers
SOURCE: whirpool duet dryer not heating
You can buy an inexpensive multimeter for less than 20 bucks, well worth it for this since you have all the parts in front of you.
Then go here.....http://www.wikihow.com/Use-a-Multimeter.
Make sure you have 240 volts at the outlet first!
Best of Luck!!
http://tclaundryrepair.com/
Posted on Feb 25, 2009
scottowa
  • 87 Answers
SOURCE: whirpool duet dryer mod GEW9200LW0, working but not heating up
If it's starting and not heating it's usually one of two things. Take off the bottom panel. 2 screws hold it in place. If you have a way to check the element with a meter or something that would be ideal. It should read about a short circuit. The other part that goes out a lot is the thermal fuse located in the front on a pipe it's long and narrow. Here is a link to show where things are in there. Let me know if you have any more questions
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=GEW9200LW0&productCategoryId=0151200&brandId=1198&modelName=DRYER
Posted on Mar 12, 2009
SOURCE: whirpool duet washer - error code f35. shuts off
Hi, I did the procedure stated above and don't know if it solved the problem with the F35 error yet but I'm pretty sure it will. But, I did find a nail in the trap! I'm sure that was causing the error. However, I wish I had known that water was going to pour out of the trap. I didn't use the washer last so maybe it didn't drain properly and I should have ran it on the spin & drain cycle before cleaning the trap? Anyway, just a heads up to other people attempting this procedure. If there is a way to avoid the water running all over your floor, do that before opening the trap to clean it. Thanks for the solution, mstechwizard!!
Posted on Jul 28, 2010
Dryer has f01 error
F-01 is a failed communication of the=> Whirlpool Dryer Main Control Board W10174745 The control board has likely shorted out. Not a cheap fix but it is a fix
APPLIANCE 911
Nov 28, 2015 | Dryers
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
My whirpool duet dryer control lock light is on and my dryer will not work
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
Nov 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F 01 error code whirlpool duet dryer. Can I replace the control panel?
Where is the thermistor on the dryer on whirpool duet or remove control panel
Feb 28, 2011 | Whirlpool Dryers
Whirpool Duet hums but will not start.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 06, 2010 | Dryers
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Oct 26, 2009 | Whirlpool Washing Machines
Whirpool duet dryer
Press/hold start for 5-10 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 12, 2009 | Whirlpool GEW9250 Electric Dryer
Washing Machines Logo
296 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
