Where do i find a tv stand for the aquos lc c3242u I only want the stand and screws
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
dsacco86
  • 1077 Answers
SOURCE: I can not remove the stand from my sony aquos tv.
With the 4 long screws removed, it should come out.
Here's where you can download the manual for the LC-46D62U.
http://www.sharpusa.com/files/tel_man_LC46_52D62U.pdf
It has the instructions you need for the stand.
Posted on Jun 02, 2009
  • 4 Answers
SOURCE: Missing LCD Stand Screws for Sharp Aquous 46" LC-46D62U
am not sure on size service manual doesnt say but there 2 1/2 long.
Posted on Jul 22, 2009
budmrtn
  • 11361 Answers
SOURCE: Sharp Aquos LC-C3242U power issues
Do you get any indicator lights at all, if you do, then the 5v standby circuit is working, if you get nothing at all, then the main power supply will be the first palce to look, blown fuse? capacitors?
Posted on Nov 06, 2009
SOURCE: my sharp aquos lc-c3242u turned itself off and now
no it only flashes green like once or twice... and its off.
Posted on Dec 03, 2009
Why won't my LC-C3242U Sharp Aquos tv won't turn on
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 06, 2014 | Sharp Aquos Televison & Video
Sharp aquos lcd colour tv model lc52le700e i need an orginal stand for this tv where can i get it if possible at all
I found this available on www.encompassparts.com.
log in as a guest, enter your model number, the first three parts listed for this tv are,
Stand support, Stand base assembly, and stand screws. Total cost for the three items $ 108.00
I checked E-bay and found none.
Jul 14, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Nov 06, 2009 | Televison & Video
Jul 15, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Jun 02, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I can not remove the stand from my aquos 46 inch tv.
you will find 4 screws at the back of the tv about 4" inches from the bottom. lay the tv set flat on your bed. you will need a metric allen wrench to remove the 4 screw. once the 4 screws are removed slide the base away from the tv.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
REMOTE CODE
i need the code for a sanyo!
Feb 18, 2008 | Televison & Video
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
Electro Med Services...
