Question about Timex Watches
How to change battery w30m timex with cr2016 battery
Hard to keep battery in place trying to get the back on.
SOURCE: watch battery replacement
I used a modification of the vise solution. I put a plastic bottle screw cap on either side of the watch (bottle side in) and tightened the vise. I heard a satisfying "pop" and I am on my way. Fred
Posted on Oct 07, 2007
SOURCE: adjusting my timex expedition cr2016
For CR2016, press and hold the SET lever for atleast 10 - 20 secs. Push the mode button until the hours value blinks. Use the 'ALARM ON' lever to adjust the time. Use the mode button to move from hours to minutes and repeat the same steps. Push the SET lever to set the time once all the required fields are adjusted.
Posted on Jun 03, 2008
SOURCE: Timex Indiglo WR 30M Wristwatch
First, find the arrow on the back and use a small screwdriver or knife to pry open the back at that point. Replace battery and then replace back wiht the arrow pointing to the middle of the band as orginially found. Third, press the back on the left side and then use a rubber mallet to strike the "raised" side down and it'll snap in place. Alternative method -- use a cushioned screw clamp to compress the back.
Posted on Aug 15, 2008
  • 299 Answers
SOURCE: How do I get the back off to change the battery?
There is a special caseback prying tool for that purpose. You can find them on ebay for a reasonable cost but you just might want to let a watch shop do it for you to avoid damaging the watch. Also, once you get it off, you have to get it back on which may require the use of a case back pliers designed to prevent damage to the crystal when seating the caseback, You will also want to replace the rubber gasket on the caseback to keep it water resistant. Even if it looks OK, the gasket should not be reused as once it has been compressed and removed it will not seal properly and allow dust and water to enter. Most shops, including Sears, will change the battery and gasket for about $8 while you wait.
Posted on Apr 22, 2010
gemineye61
  • 831 Answers
SOURCE: model no cr2016 cell timex
Thank you for contacting FIxYa.
You can get instructions/manual at the following link:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
By the way, that is not the style # of watch, that is battery type.
Best regards. Jewel
Posted on Sep 10, 2010
What's the band size for a cr2016 Timex indiglo? Also says wr 30 m.
these are not the model number , CR2016 is the lithium battery number and the WR30 is water resistance 30 meters.
you will need to send the watch off to Timex csd@timex.com
May 09, 2017 | Timex Watches
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Hello. I own a 40 to 50 year old "Timex Electronic" watch. There is a number date at the 3 o'clock position. I see no other identifying info on the outside. I don't have a battery for it. How
What is the exact model of the watch. I have several Timex Electronic watches that might fit your description. If you pop the caseback do you see the old battery inside? Most batteries would have a reference like: CR2016.
Jan 06, 2013 | Timex Watches
Timex expedition indiglo wr50
The battery is a CR2016 as noted in the description. Hard to find these days.
Aug 31, 2017 | Watches
How do I open the back to change the battery on my timex e tide/temp watch
you had to have a knife caseback opener or any flat tools. look for the small opening on the back located on the upper right side of the caseback, insert the flat tool inside of it and just flip it up. then it pops out. note: after you had change the battery, you had to use pressing tools to cover it again because it cannot press by hands to seal it. it uses CR2016 size of battery. i hope i had been helped you.
Aug 20, 2011 | Timex Watches
Model no cr2016 cell timex 1854 can't change the date
Best regards. Jewel
Sep 10, 2010 | Watches
I have a Timex I bought in 2007 on the back of the watch it says CR 2016 cell and WR 100m. The time started to catch on a certain time and stopped the date from working properly, I need to know how to...
You should probably replace the battery using a new CR2016 battery. Let the watch set a while without the battery to help it reset. WR 100m just means the watch is "Water Resistant to 100 Meters". Then use the following info.
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Sep 01, 2010 | Watches
Get cover off the timex watch indiglo w30m watch
Try removing the rubber washer or the black band on the cover then try snapping it back on. I removed the washer and placed it on the back of the watch before I placed the cover on and it just snapped back on.
Sep 14, 2009 | Timex Watches
Beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
May 31, 2009 | Timex Watches
Watches Logo
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
