Washing maxchine does not agitate
Washing machine is brand new from Lowe's and will not agitate - tries to agitate but the action is very minimal.
    Genius:
  • 1,122 Answers
What make all model?mike
Posted on Oct 27, 2008
Washer won't agitate
Really depends on brand of washer and how it's designed. Some agitators are dual action and top moves independently from bottom like a ratchet. Plastic ears inside agitator could be stripped out. Could also be motor coupler that joins motor to transmission in some Whirlpool made washers.
Aug 26, 2017 | Washing Machines
GE washer WNSB9080B only allows me to run "Drain and Spin", no other cycle. It wounds like there is still water inside when I move the drum around.
In top loading washing machines, the agitator is responsible for moving the clothes through the water and detergent and is driven by the output shaft of the transmission. The output shaft is normally splined and the center of the plastic agitator will have a matching spline to ensure a tight fit. Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Jul 18, 2016 | GE Washing Machines
Washer wont agitate or spin
Aug 03, 2017 | KitchenAid Washing Machines
Kenmore 80 series washer agitates minimally but when you push down on agitator slightly it agitates more and is now having trouble starting to spin tub is it a belt issue?
Check out: http://www.appliance411.com/faq/agitator-dogs.shtml You can buy parts here: http://kenmore80serieswasher.com/whirlpool-kenmore-washer-agitator-cam-kit-285809/
Jun 25, 2011 | Kenmore Washing Machines
+whirlpool LSQ8243HQ0 water valve works. wont wash or spin. new motor coupling and timer.
Under the agitator you have what is called (agitating dogs). The agitator will have to be removed. The top should spin off, you will be able to look down into the agitator and see a bolt. Remove this bolt and the agitator can be pulled out. The agitators are small pieces of plastic with small teeth. These teeth get worn out over time or if the washer is overloaded. When the agitator free spins one way the teeth grab a (gear) on agitator and this is how you get the washing action (agitating). These dogs are easy to replace and cost about $5. If you need more info check out *how to replace agitating dogs)
Dec 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Kenmore washing machine, it's approx 6 years old. The agitator on this machine always moved in a back and forth action. The other day it started to move in one direction only. Can you please tell...
Sounds like you need new agitator dogs. They are part number 80040. They have teeth in them and the teeth strip out. You will need to remove the agitator to replace these parts. Hope this helps _MJ_
Aug 17, 2010 | Kenmore Washing Machines
Kenmore Series 70 top load barely agitates....
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Three places to look.
1. Assuming that this washer has a two piece agitator, I'd check the "agitator dogs" on the top section.
2. It's possible that the splines on the agitator have worn over time.
See the following description of how to remove the agitator.
Look inside the agitator at the splines.
3. It's also possible that the splines on the agitator shaft have worn.
With the agitator off, check the condition of the splines. If they are worn, the options are to replace the agitator shaft (disassembling the transmission) or replacing the transmission itself.
May 06, 2009 | Kenmore 15864/15862 Top Load Washer
Lent in waterhose
Lint is nothing more than broken fibers in the fabric. To minimize lint, make sure you don't overload the machine. Loosely load items to the top row of holes in the tub. With a full oad, select the highest water level and use the proper amount of detergant. If you have a two piece agitator, verify the upper section turns one way like a ratchet. This action keeps the load circulating so the same items are not at the lower section of the agitator thoughout the wash and rinse cycles.
Apr 27, 2009 | Washing Machines
Simpson 175 HD washing machine Programme keeps stopping Is it the timer or some other problem
image_bubblequestion_04.gif Can you please identify the problem with my washing machine?It appears all the functions of my simpson 175 washing machine work normally except the agitator only moves briefly and harshly for between 1 and 2 seconds.
Simpson 175 HD (Dual Action Agitator) Washing Machine.
1517 5M40 A 28 June 1990
Jul 12, 2008 | Washing Machines
Wont spin or agitate
Not sure what you mean? if you have normal wash action then it is agitating in the wash cycle.  Otherwise if it doesn't agitate or spin but does fill with water then your motor or motor control board is bad.
Oct 27, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
