Question about Furuno 1623 Radar 16nm Range
Was wondering if I can shorten the antenna cable to my Furuno 1623.
The cable is 18 feet to long. I do have quite a bit of wiring experience but I'm unsure if there are some wires that need to be shielded.
3 Suggested Answers
rjrod888
  • 8 Answers
SOURCE: Furuno Radar 1623 and 1715
Hello.
According to the operating manuals of the two radars (found on Furuno's Website (www.furunousa.com), they do use the same antenna cable.
Hope this was helpful.
Posted on May 04, 2009
  • 111 Answers
SOURCE: IS THERE A EXTERNAL ANTENNA AVALIBLE . IF SO WHAT
I would assume you're talking about the radar? it's a RSB0093-074 it's just for the 1623. There are no other options. If you're referring to gps antennas then any antenna that outputs nmea can be used.
Posted on Jan 25, 2010
Furuno 1623 Radar Power Cable
pn 000-147-564 from a Furuno dealer in your area. ($60 msrp)
May 16, 2014 | Furuno Fr8062 12.1 Color Lcd 6kw 15 Meter...
Can a furuno 1835 cable be cut, spliced & shortened
Sometimes shortening the cable by a lot will cause a timing issue (center spot or hole). The answer to your question though is yes.
Feb 05, 2014 | Furuno 1835 4kw 24 Dome 10.4 Color Lcd...
Antenna GPS Tram 1655 is compatible with GPS FURUNO?
If the Furuno unit you're referring to uses a GPS antenna with a coax (i.e. GP31/32) then the Tram antenna will work but the connector is wrong. The Tram antennas usually come with BNC connector and Furuno uses a TNC. Will need an adapter.
Oct 14, 2013 | Furuno GPA019S GPSDGPS HField Antenna...
Ca I buy a 5 metre extension cable as the 10 metre cable that came with the 1623 is too short?
Quite sorry but Furuno does not carry "extension" cables for radar antenna signal cables. If the original cable is too short, you would need to obtain a 15M whole cable, furuno part number 001-122-870-10. Or the 20M whole cable part number 000-144-565. You might be able to find a technician willing to custom manufacture an extension for you but I emphasize the word might.
Regards,
John
Feb 18, 2012 | Furuno 1623 Radar 16nm Range
I have a Furuno Radome RSB0094-075 with a Navnet RDP 139 10.4" What I dont have is the antenna cable to connect the two units. What cable should i be ordering for this?? Thanks, Mike
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
Nov 06, 2010 | Furuno NavNet vx2 1920C GPS Receiver
Furuno 1942Mk2 Problem
it cannot determine a heading, have you also damaged an internal antenna or positioning / gps device inside it? It is unsure which direction it is pointing in but uses triangulation to determine this.
That requires either an electronic compass unit, or gps to achieve correct heading and hence correct orientation of the radar image
Nov 14, 2009 | Furuno 1942 Mk2 Radar
The display shows in feet. Just wondering if anyone knows how to change it to fathoms thanks
click the settings menu and then cswitch the customary system to metric
May 04, 2009 | GPS
Hello.
Dec 03, 2008 | Furuno Fr8062 12.1 Color Lcd 6kw 15 Meter...
Furuno 1623 Radar reading "no heading pulse"
The messages “NO HEADING PULSE” and “NO BEARING PULSE” means that the display is not communicating with the scanner (antenna). Both of these signals are generated in the scanner if you get this error check that the antenna cable is firmly connected and that the contacts are clean and corrosion free.
If the connection at the display looks good and feels like it’s properly connected, check the cable for any damage If you find damage you could try to repair the wires BUT (because of corrosion and moisture problems) IT IS STRONGLY REMENDED that the cable be replaced, but it’s kind of expensive $275.00.
The Part number is 000-130-034. Depending on the marine shops in your area they may have it in stock (or they can order one) but you can get it directly from Furuno at;
http://www.furunousa.com/Furuno/Rooms/Search/ProductPropertySearchResults?_webrFormIdentity=com.webridge.layout.FormLayoutExImpl%5BOID%5B47F81E95CB197F4C8708859EA0E22F08%5D%5D&_webrFormUniqueID=0&_webrCharacterEncoding=iso-8859-1&_webrLocale=en-us&_webrClusterUpload_2=&ptype=com.webridge.entity.Entity%5BOID%5BE670694808555649838ED263AA4CAB0A%5D%5D&productname=000-130-034&searchOption=normal&searchOption_webrHidden=radio
I hope it’s just a loose connection. Good luck!
Apr 28, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Can't Receiver ( No Signal )
I WOULD SUGGEST THE ARIEL BREAKING DOWN, OR AN INGRESS OF WATER IN THE COAX CABLE. IF YOU NO SOMEONE WITH THE SAME UNIT TRY YOUR UNIT ON THERE ARIEL.
Feb 27, 2008 | Furuno GP32 GPS Receiver
Furuno 1623 Radar 16nm Range Logo
49 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
David Burbee
David Burbee
Colin Stickland
Colin Stickland
Are you a Furuno Boating Expert? Answer questions, earn points and help others
