Question about Pantech Cell Phones
How to fix calibration on pantech laser
Touch screen is not responding
guru_fixya
  • 944 Answers
SOURCE: my samsung impression touch screen
To recalibrate follow this procedure.
Go to setting>phone setting>calibrate
The calibrate screen pops up follow the screen and with the finger or stylus click on the cross image.It will ask for 2-5 times until it is able to detect your response time.Then save the changes.
If you are not able go into menu settings.To make the calibration to Factory setting.(Take back up of all data)
Reset is the only option if you want to take it to the Factory setting.
If you want get it back to factory settings.
full reset:*2767*3855#
default code:000000
If still after the old calibration if you have problem with the touch screen.
Take apart the screen and remove all the dirt and water particles.
If still you have the problem check for any internal component failure.Check flex is properly placed into the socket.If it is defective
Replace flex cable.Flex cost is around $10.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 05, 2010
  • 87 Answers
SOURCE: I Have The Same Problem!!!!!
I went through 3 of these phones. The best way is to throw them in the garabage.. Literally. I had 2 units that the screens failed on them. The other one shut off and turned on when it pleased. The longer you use them the more problems occur. But if the screen is failed, then it will not be able to respond to touch and will never be able to be calibrated.
Posted on Jun 05, 2009
frankgant
  • 250 Answers
SOURCE: Nintendo DS touch screen will
It might be time for a new one or the ribbon cable has come loose inside the DS. If you are good with tools and electronics you can open it up and see if it has come loose. But if you're not good at this sort of thing I wouldn't recommend that. If it's in warrenty Nintendo will replace it.
Posted on Mar 29, 2008
SOURCE: Screen Calibration problem with SteetPilot c330
Turn off the unit. Then hold down the power button for about 1 minute and the calibration screen will eventually come up.
Posted on Oct 13, 2008
SOURCE: LCD not responding to touch
how can i calibration my mini dv screen its model(dcr-hc26)?
Posted on Feb 16, 2010
Touch screen not responding
Which model of Ricoh are we talking about here? If touch screen is not responding before replacement, re-calibrate touch screen or replace it. I can help you with the calibration code if you require. If the touch screen is not responding after replacement, check whether the replacement lcd display panel was installed reverse as the connectors will not have contact.
Mar 12, 2014 | Ricoh Office Equipment & Supplies
I have a pantech crossover. I went to unlock the screen and it displayed for a second and then went black. You can see the backlight. The screen still resonds to touch. Swipe it and you can hear it unlock....
unlock pantech phone at cheaper price $0.50 onwards
http://unlockpantechmobile.com
unlock pantech C740 Matrix,
unlock pantech C790 Alladin-Duo,
unlock pantech C810 Duo,
unlock pantech C820 Matrix Pro,
unlock pantech P1010,
unlock pantech P2000 Breeze,
unlock pantech P2020 Ease,
unlock pantech P2030 Breeze III,
unlock pantech P6010,
unlock pantech P7000 Impact,
unlock pantech P7040 Link,
unlock pantech P7040P,
unlock pantech P8000 Crossover Android,
unlock pantech P9020 Presuit,
unlock pantech P9050 Laser,
unlock pantech P9070 Burst,
unlock pantech P8010 Flex,
Unlock Any Pantech,
unlock pantech,
unlock pantech Mobile,
unlock pantech Phone,
Jul 27, 2013 | Cell Phones
My nokia touch screen is not working. Everything else on the phone seems to be fine, just that when I touch the screen there is no response. Please can you help?
Hello there,
There are two major reasons that could be causing the touch screen not to be responding. The first is if the phone fell and the sensor board got bad, and the best solution is to replace the sensor board. To replace the sensor board is quite sensitive so i will strongly advice you seek advice from a specialist that can assist you with that. But if you intend to fix it DIY way, then you can ask and i will direct you through the steps.
On the other, it might be the screen is weak and needs calibration. To calibrate the screen. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Thank you for using fixya.
Caseytech
Sep 21, 2011 | Cell Phones
My iphone screen cant touch ?
Hello there,
Caseytech
Sep 21, 2011 | Apple iPhone Smartphone
Samsung a897 touch screen not responding at all
Hello there,
On the other, it might be the screen is weak and needs calibration. To calibrate the screen depends on the type of phone it is. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Caseytech
Jun 27, 2011 | Samsung Star GT-S5233 Cell Phone
How do I turn of the lock and unlock sound on my pantech laser?
I asked Pantech and the short answer is, you can't.
However, I discovered if you slide out the keyboard out it will unlock without the annoying click.
Please, go to the Pantech website and leave a complaint so it gets fixed in the next release of software. IMHO, the lock/unlock sound should follow whatever the Touch Feedback settings are for volume !
Hope this helps.....
Jan 07, 2011 | Lexerd - Pantech Laser TrueVue Crystal...
I get no response when i push i agree on first screen
Then you have to calibrate the screen since it is not responding to touch. To calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen for about 30 seconds until the calibration screen comes appears (white screen with touch dot),
  4. Follow the on screen instructions.
It is an easy fix. The solution above will help you out on that. Another solution is for you to remove the battery and fix it in back. That should also help.
Jan 02, 2011 | Garmin nuvi 255W GPS Receiver
My pantech freezes.
is your phone touch screen .then kindly go to screen calibration adjust your screen as it instruct
Apr 08, 2010 | Pantech Matrix Cell Phone
My Sylvania SMPK8854 touch screen 4GB mp3 player will not respond to touch. I tried resetting it but did not help. How do I fix it?
YEA PLEASE CAN YOU HELP MEE BECAUSE MY Sylvania SMPK8854B WILL NOT LETT ME TOUCH THE SETTING AND I REALLY NEED HELP!! WITH MY Sylvania SMPK8854B!!
THANK YOU THEY MUCH!♥
Jul 09, 2009 | Sylvania SMPK8854 Digital Media Player
Touch screen wont work
Have you tried removing the battery and waiting for a minute and replacing it in the phone.
The phone will reboot and possibly your screen will work again.
May 28, 2009 | Samsung Instinct Cell Phone
Cell Phones Logo
626 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
