Question about Samsung CLP Office Equipment & Supplies
Samsung clp-310 via bonjour - CLP Samsung Office Equipment & Supplies
namizhka
  • 148 Answers
SOURCE: Samsung CLP-315
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Posted on Sep 16, 2008
komguy
  • 2306 Answers
SOURCE: how to print miror image
After you select the image to print the printer dialogue box opens, click on preferences and tell the printer to print a mirror image. It's set in your computer and not at the printer.
Posted on Jun 22, 2009
  • 3 Answers
SOURCE: Papr Jam, Samsung CLP310 - paper jams half way through the job
If it jams every page, it is the infamous Samsung design flaw. There are dozens of reports of this problem all over the internet. The best solution: sell it or otherwise get rid of it ASAP and buy another type or model of printer. The 2nd best solution: call trained technician and ask to replace the broken part. It could be thermistor near fuser, some people say it is a photo-interrupter.
Posted on May 05, 2010
Testimonial: "Thankyou"
  • 360 Answers
SOURCE: how to know the version of my samsung clp 310
hello get a system data report of your machine.their have a firmware version
Posted on Sep 11, 2010
SOURCE: My Samsung CLP 310 won't come out of sleep mode
I had faced the same problem, after the printer switched into the sleep mode, I could't wake him up. So I have checked why, and I could find a solution so far, then I have deactivated my mac address filter list of my router, and see it works, hmm, so I have checked the WIFI settings again and found the BSSID mac address, so I have added this address to my mac filtered list, and see bingo it works fine !
Hope hat helps, I found another solution which means when you have spaces in your SSID the printer can't wake up as well, but I can't confirm this problem.
Jan
Posted on Jan 01, 2011
Printer problem with OS X 10.9 Mavericks
THE SAMSUNG CLP-310 is fully supported by Mac OS X 10.9 Mavericks. The printer driver (like all nowadays) is supplied by Apple not the manufacturer. If you installed drivers/software from a disk, you need to put that disk back in and run the uninstaller. Be sure the printer is removed from the printer list in the Printing system prerefernce pane and then unplug and replug in the printer. If it does not show up automatically you may need to add it manually in the system preferences window (no big deal.)
Nov 22, 2013 | Samsung CLP-310 Series
Error message appears please install supported driver or port
ok So I did alittle research for you.... you either have the wrong driver or your printer is set to the wrong port via the printer properties in windows but here is the driver download page and a manual download as well http://www.samsung.com/ca/consumer/office/printer-multifunction/colour-laser/CLP-310/XAA-support
Oct 10, 2013 | Samsung CLP-310 Series
How to know the version of my samsung clp 310 firmware?
Sep 10, 2010 | Samsung CLP-310 Series
How to change the ink toner for clp 310 n
open fron door and slide cartridges out, slide new cartridges in, just remove protective tabs from new cartridges and that is all...
Jul 22, 2010 | Samsung CLP 315 Laser Printer
Samsung clp 310 printer regularly jams
if your printing is halfway to the exit. it is most likely the exit sensor is mulfunction.
get the exit sensor replace.
May 14, 2010 | Samsung CLP 315 Laser Printer
Go to YouTube and watch this video: 5fJHykzkfww
I will try to add the video to this post. The sensor is available on eBay for around $8 to $12 and it takes only about 15 minutes to fix the printer.
Mar 26, 2010 | Samsung CLP 315 Laser Printer
Printer doens't like to print anytime
It sounds like this printer is not coming out of sleep mode. You need to change the settings so the printer do not go to sleep mode (power saving mode)
Aug 06, 2009 | Samsung CLP-300N Laser Printer
When trying to set up Samsung CLP 310 I cannot get the software loaded. Sony notebook VGN SR220J. Server works fine from 2 network connected PC's I've tried it from the disc and the loaction on the HD.
download latest drivers and install with printer unplugged...it will install software to c:\program files\samsung\ and then 2 more folders in you will get the drivers folder - add printer and just do have disk and browse to that folder.
Aug 01, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Greyed out duplex option Samsung CLP-310
does the printer have a duplex option,if yes should be able to print,check driver.if no,option does not allow you.
Jul 06, 2009 | Office Equipment & Supplies
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
