Question about Samsung Televison & Video
My samsung lcd tv has red, yellow, and green vertical lines on the screen. What is happening to my tv?
Samsung lcd tv model # LN46B650T1FXZA THE TV HAS RED, YELLOW AND GREEN VERTICAL LINES ON THE TV SCREEN. SOMETIMES IF I CHANGE THE CHANNEL, I CAN STILL SEE THE PREVIOUS CHANNEL IN THE BACKGROUND. THE TV HAS STARTED MAKING A POPPING NOISE WHEN I TURN IT OFF. IF POSSIBLE, I WOULD LIKE TO FIND OUT WHAT PART IS GONE BAD ON MY TV BY THE SYMPTOMS I PROVIVED. THANK YOU!
techman
  • 3130 Answers
SOURCE: nec plasmasync 4200w 3 vertical lines one yellow two purple
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
Posted on Oct 08, 2006
SOURCE: zenith 42" plasma p42w46x
I have the three zenith plasmas, I've fixed the two that were flickering. The one with the verticle lines, I sawpped the Z-SUS and the Y-SUS from the good TV to the bad and still had the white lines. I looked at the two boards hooked together with 3 aluminum covered ribbon cables that are in the lower center of the TV with all the video inputs, on the far left there is a right angle connector that has about 20 pins, the white cable comes out and goes under to a circuit board this looks like this cable supplies the video signal to the screen. I disconnected the cable and the screen went black, all the voltages going into the video board are normal, so there must be something fried on one of the two boards, there are a LOT of electrolytic caps on those boards. I will post when I figure out whats cooked, you may have the same problem too.
Posted on Dec 26, 2007
  • 213 Answers
SOURCE: Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
it sound like the the part that you need to replace is assy pcb maine-amlcd p# bn94-01199e 306.20 core of 50.00 or the ip board P# bn44-00168a but be vear care whan you do this job the cable the some time to git offf the pcb mount. good luck this sould help you out.
Posted on Mar 30, 2008
jerryg50
  • 1689 Answers
SOURCE: plasma tv
If the set is under an extended warranty get it serviced.
On rare occasions it may be the Plasma screen itself that is defective. In more than 90% of the cases it is a circuit board that has to be changed.
This can be an addressing problem to the screen. The failure can be in the screen addressing circuits or probably in the processor circuits. After or during the signal conversion to the data buss, there are many areas of the set that can actually cause missing pixels, lines, or ailiasing in the image.
The service tech will swap out boards to find the fault. Once he finds the defective board, he will quote you for a new board.
Jerry G.
Posted on Apr 27, 2008
  • 23 Answers
SOURCE: plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Posted on May 02, 2009
Samsung TV model UN65H6350A shows yellow vertical lines on screen
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 10, 2016 | Samsung Televison & Video
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
Jan 03, 2016 | Samsung Televison & Video
Should the T-CON board be replaced on a Samsung LN40C650 LCD TV to fix the vertical lines problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 08, 2015 | Samsung LN40C560 LCD TV
Samsung LN46B650T1FXZA has vertical lines. What part needs to be replaces? Thanks, Nina
This might be a bad T-Con Board. This is the board that is in the middle top side of your TV. It connects to your main board (with the hdmi inputs) to the LCD Screen. Your TV has a major issue with the T-Con Board going back. The T-Con for that TV is avaialble here 55 46T03 C11 Samsung Con Board for LN46B650T1FXZA
Jul 23, 2011 | Televison & Video
Vertical lines in picture
The machine is still under warranty from samsung so I would call 1-800-samsung to find the nearest service center. Problem could be caused by a bad main board, bad lvds cable or a defective t/con board or lcd panel.
Jan 22, 2010 | Samsung LN46B640 LCD TV
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
139 people viewed this question
Jerry Greenberg
Jerry Greenberg
