Question about Microsoft Xbox 360 Console
Xbox console 360 white box
Locks up after about one minute of game play, also has a red flashing light at times. have checked connections and unplugged it but does not do any good
  • 31 Answers
Sounds like the heatsink over your graphics processor is loosing contact after it warms up, i ended up opening the xbox and removing the x clamps and adding nuts and bolts to both heat sinks and that was a permanent fix, if you give me your email i will go in depth about how to fix it, not enough room here to give all the details
tyler
Posted on Jul 06, 2009
  • slydog123 Jul 07, 2009
    another thing you could try is a new power brick
When i connect xbox 360 arcade[new] to my tv can't it to play
have you switched the switch to hdtv and NOT tv on the back of the big grey ariel plug going into your 360 ? then turn your tv to the aux or av channel as it wont be on a normal channel ??
Jan 26, 2010 | Microsoft Xbox 360 Console
Problems with x box 360
Just try http://www.threeredlightsfix.com and it will work! I like the video preview as well check it out! It comes with HD videos to guide you through the whole repair! I checked out all 3 and this one was the cheapest. took me 32 minutes , they say 30 minutes but took me a bit longer not very tech minded..
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Microsoft Xbox 360 Console
XBOX 360 TWO RED LIGHTS FLASH
the two flashing lights is the code for your console overheating make sure nothing is on top of or behind the xbox and make sure it is not in an enclosed space
Sep 20, 2009 | Microsoft Xbox 360 Console
2 red flashing lights
The Xbox console is overheated.
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
Best of Luck.
-Mind
Jun 30, 2009 | Microsoft Xbox 360 Console
When playing Xbox 360 Games i get Flashing lights/Lines
sounds like the graphics chip is on its way out might just be a cold solder joint normaly turns to 3 red lights when ppl mention this to me
Jun 08, 2009 | Sony Playstation 3 (PS3) Console
X box 360 console
Most of the time when you have 2 red flashing lights one of the clamps has come loose holding down the cooler on the GPU or CPU.
Dec 30, 2008 | Microsoft Xbox 360 Console
Flashing red ring on x box 360 console
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
Cannot view picture or game for my xbox 360
Make sure you are using the correct video settings. Try using the basic red white yellow cords and see if that helps. Also make sure you have switched between HD and regular video. there is a switch on the video cable connector that plugs into the xbox.
Jan 06, 2008 | Microsoft Xbox 360 Console
Xbox 360 Freeze!!
It's a common fault with X boxes, the red lights indicate overheating, so make sure it is well ventillated and if neccasary you can purchase an add on cooler for the system.
Dec 30, 2006 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
71 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
