Question about Refrigerators
Flap on ice dispenser does not open
The cubed and crushed ice feature works but piles in chute without coming out. Is there a way to adjust the tension on the flap gate?
  • 4 more comments
  • jsimons Oct 27, 2008
    It is GE Eterna Side by Side.
    Mike, It's a GE Eterna Model # ESS25GMCC. Is the flap purely mechanically operated (spring) or is there some sort of activator. If spring operated, can tension be adjusted?
  • jsimons Oct 28, 2008
    After looking closely at dispenser and reviewing the part schematic, there is a spring on the ice door/crank door recess. There is a Solenoid assembly in the dispenser, but isn't this for operation of the ice auger?
  • jsimons Oct 29, 2008
    Micbeth1981, my apologies. I based my comment from info from the GE helpline. It now appears they don't know their own product. How unfortunate. So the solenoid does operates the ice dispensor flap. Is there an operating arm seperate or on the solenoid assembly? Also, for access to this, is that done from the backside of the door. I see the screws around the gasket and assume they need to be removed to get at this part. Jim
  • jsimons Oct 30, 2008
    This seems to be right on. The only question is the arm included with the solenoid assembly and is there any way to lubrcate so problem doesn't happen again.
  • Ben Lofhren Jun 20, 2013
    it seems that the flap is sticking OPEn and then it warms up the insid of the chute and thsi causes an ic jam at the chute because the flapper isn;t closing like it should
    Genius:
  • 1,122 Answers
What make and model?-mike
Posted on Oct 27, 2008
  • 2 more comments
  • MIKE major Oct 27, 2008
    there should be a solinard under the cover that control the opening and closing,no spring-mike
  • MIKE major Oct 28, 2008
    the solenoid work the ice flap like i said,you might be looking at the tension spring with no adjustment,and oh thanks for screwing up my expert rating when i gave you the fixya answer-mike
  • MIKE major Oct 29, 2008
    most of your ge sxs ice ,water, dispenser's have the panelon them that pops off,remove this slowly,you can then unscrew the board panel to get to the solenoid,the solenoid has a arm on it that engage's the solenoid,most of the time the solenoid's have rusted and must be replaced,hope this helped you out, you can go to sears .com come for parts
  • MIKE major Oct 30, 2008
    i'am not sure if the arm comes with it,if you go to sears .com click on parts put in your model number you can see if it does and also order any part you need,also cross check the price at repair clinic .com, -mike
I have whirlpool refrigerator side by side, with ice and water in the front. the ice flap has seem to be loose and i cant figure how to keep it close when ice is not coming out.
Posted on Aug 29, 2009
Ice cube stuck on crush
remove the ice bin,there must be a chunk of ice blocking the cubed dispenser chute of the dispenser and channeling all ice thru the chopper chute,run hot water thru it to melt any chunks blocking the cube chute,then dry it and let it get cold before filling with new ice or you will have the same issue again
Aug 12, 2012 | Frigidaire Refrigerators
Our new 48" Viking side by side does not feed ice cubes adequately. If you need several glasses of cubes it stops feeding and when one opens the freezer door they are piled up and fall all over the floor....
I experienced the same problem several times with our VCSB483DSS also.
What I found was that the ice come down the chute side way and got stuck at the flap in the door. As you continue to press for ice, the machine pushes more ice & they all back up in side the chute and in the door, ready to dump on unsuspecting person who open the freezer door.
I think the the problems are:
1 - over application of foam insulation in the chute pathway in the door.
2 - possible bad timing on the flap opening causing the falling ice to get stuck.
My solution for the past 6 years:
1 - clean out the over application of foam insulation - this reduce the incident frequency from once a month to once or twice a year.
2 - inform my family member that if while you pressed for ice, and the ice is not dropping, but you hear the motor still cranking away, stop pressing for ice immediately. Stick you finger up the dispenser to make sure the flap is open, and push the ice to un-stuck them. And finally, be prepare to get 2 cups full of ice.
Viking may make professional quality fridge (13 years experience in restaurant business), but ice & water dispenser is not their strong point.
Oct 09, 2010 | Viking 42 in Built In Professional...
Ice cube dispenser will only deliver crushed ice
Remove the ice bin, and in the back of the freezer you'll see a square opening with a white plastic piece inside. When you dispense cubed ice this piece lifts up, lifting the long metal rod that runs along the bottom of the ice bin. When that rod lifts it opens the ice flap at the front of bin, allowing cubes to be dispensed. If the flap is not open, the cubes will be ground against the cutters and you will get crushed ice.
Here's what you can do to make it so that you always get cubed ice. Take a wine cork and stand it on end. Using a good knife, I positioned the blade about 1/3 of the diameter from the edge and cut all the way through the length of the cork. Then remove the ice tray.
Now put your finger in the sqaure opening and lift up the white pastic piece. Slide the modified cork under the flap so that it is jammed into the raised position. (This is the position it should be in when you are asking for cubed ice.) Now slide the ice tray back in while using your left hand to push the plastic ice flap at the front of the tray to the left side (again, the position it should be in for delivering cubed ice). Peer under the tray while you're slowly sliding it back in so that you can see if the metal rod connected to that ice flap successfully slides into the square opening at the back. If it can't slide in above the cork-raised plastic piece, you may need to pull the cork back out and trim a little more off it.
This worked for me... I can't get crushed ice anymore, but I've only needed crushed ice once in the 16 months I've lived here so that's not an issue for me.
Apr 02, 2010 | GE GSS20IEP Side by Side Refrigerator
Ice maker chute becomes jammed with snow and cubes are being crushed even if the cube option is selected
You need to remove the ice bin , remove ( save ) the ice , and defrost the bin opening with hot water . It sounds like a piece of ice got caught behind the bin flap , keeping the flap from opening fully , so cubes will go thru . When cubes cannot go thru , the crusher will crush anything that tries . Now this is the ice container only .
Sep 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
MAYTAG Ice control doesn't change from Cubed to Crush
If you prefer ONLY cubes , remove the ice bin and 1 or 2 screws hold the long rod attached to the bin . Without this rod , you'll only get cubes . With the bin removed , the square hole where the rod inserts in the rear freezer wall , you'll see a square , white , plastic "gate" . Asolenoid with a plunger , raises this gate for cubed ice and keeps it lowerer for crushed ice . Usually this "gate" plunger , rusts , thereby replaceing the solenoid and plunger would have to be done . Without the rod on the bin , the inner flap would open automatically , dispensing cubed ice .
Aug 16, 2009 | Refrigerators
Flap on ice dispenser door won't close
clean it again and make sure when you use it that all the ice falls out if not and its open a little it will cause it to freeze open
Jun 26, 2009 | Whirlpool GS6NBEXR Side by Side...
Can't make ice cubes only crushed ice
Hi: There is a flap right where the ice dispenses. When you remove the bin you will see it when inverted. This flap has to open for the ice to be cubed. You might rember a slap as it swung open when it worked. There is a bar that runs from the flap to the back of the dispenser. Work it manually to see if it's jammed or broken. If not look at the back of the freezer and remove the metal panel if neccessary, to find the jam or defective part. I hope this helps, Jeff
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
651 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
