Question about Tricity Bendix Dishwashers
Tricity bendix Dishwasher - model number TBDW41 - integrated - 4 years old
My dishwasher isn't working correctly. You turn the dial on any programme, then push the on button, then close the door and it should work as it has normally up until yesterday. It sounds as if it is working - you can hear the pump but there is no water? Bear in mind that this has just happened on its own, I have not turned water supplies off or anything like that, it has just stopped supplying water. Therefore after say.....2 or 3 minutes - there is no more pump noise and nothing else happens.
Your assistance will be very gratefully received. Thank you.
SOURCE: GE Nautilus dishwasher wont run
getting ready to try what everyone suggests......wish me luck
Posted on Nov 11, 2008
Rotu
  • 175 Answers
SOURCE: Bosch dishwasher SHU9922UC
Sounds like you already know how to fix it. The inlet valve is only held closed by water pressure...if you have low water pressure it could be causing this. Its more likely just a bad fill valve though. The water inlet valve is accessed by removinf the lower kickplate and the sheild behind that. Then all you have to do is remove the water line from the valve, remove the 2 screws holding it and pull it out far enough to disconnect the 2(possibly 3) wires and the fill hose. Make sure to mark where your wires go, if you hook it up wrong it could continue to fill and overflow. Hope this helps!
Posted on Feb 02, 2007
SOURCE: Clean light on dishwasher won't stop flashing
Reset worked for me. I had the same problem as others. Thanks for your help.
Posted on Nov 10, 2008
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Posted on Mar 08, 2009
How to remove upper spray arm
I gather that you are un the UK, Here is the spares store: http://www.ebay.co.uk/itm/Tricity-Bendix-BDW53-BDW60-DH102-TBDW41-BDW52-Dishwasher-Upper-Spray-Arm-/310859913118
IF this unit mounts under a counter you should take it out of the space under the counter so that you can see the top of the outside to see if there are any mounting bolts for the spray arm.
Feb 19, 2014 | Tricity Bendix Dishwashers
Hi I have a Tricity Bendix dishwasher model DH090. Light comes on, starts up, tablet even drops out of the holder but then the dial stops, nothing else happens. It doesn't matter which of the four...
My wife discovered the solution to this problem.
If you place large plates at the front then the flap with the cleaning tab can't open. So only place small plates at the front of the Dishwasher.
Oct 03, 2011 | Tricity Bendix 18 in. DH090 Free-standing...
Hi there, I have a Tricity bendix dishwasher, approximately ten years old. the other night in the middle of the wash cycle, it went pop, tripped the mains at the board and there was a smell of burning in...
You know, I think the best thing to do would be to replace the dishwasher. It is ten years old and a new one would be more energy efficient and you would save money in the long run.
Jun 29, 2017 | Tricity Bendix Dishwashers
Dishwasher not working
sounds like the heater is not working. it's washing while waiting for it to heat to correct temperature.
if you are not electrically minded i'd get an engineer out or ring one for a quote.
Jan 27, 2009 | Dishwashers
Tricity bendix dh101 wont empty trying to but only a trickle was working ok no kinks in extract pipe
Check the drain hose and the drain lines, if you find no obstructions, then you have a defective drain pump.
If you find no problem with the drain lines, you may need to replace the pump.
If you enter model number here , you can find parts and diagrams.
Dec 08, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Check pressure from power supply, check if the inlet valve is faulty or obsstructed.
Nov 03, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Tricity Bendix DH101 dishwasher
my tricity bendix dh101 will not fill up with water what could be the problem
May 09, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
My Tricity Bendix won't work
Check out the water inlet solenoid valve if this is clicking then it is probably the water level pressure switch which appears to be controling the flow of water mechanicaly dependent on whether the water is high enough in the machine and therefore giving enough pressure to close the switch .This may be stuck closed.
Oct 17, 2007 | Tricity Bendix 24 in. DH102 Free-standing...
Tricity bendix keeps turning off !!
assuming you still have power to machine, it could be that the main circulating pump has a thermal overload in it which is tripping off. can you give me more detail?
Apr 23, 2007 | Tricity Bendix 18 in. DH090 Free-standing...
Dishwashers Logo
128 people viewed this question
Top Tricity Bendix Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
