Question about Sony Walkman D-EJ361 Personal CD Player
HI dc In
"HI dc In" my discman displays this and I can't seem to get rid of it. It will show for about 60sec and then turn off. Are you familiar with this issue and how can I get it to play my cd and go back to normal display? Appreicaite and advice
2 Suggested Answers
SOURCE: My Sony D808K portable CD player will not play a
It's dead. Mine did the same thing, but I noticed also that the disc never spun up fast enough to be read successfully. I'm guessing that the motor just lost its oomph. I imagine that one way or another it's fixable, but with portables so cheap and a player this old not being able to read anything but manufactured CDs, i.e., no CD-R, CD-RW, etc., it's not worth it. And mine was old enough to vote! :)
Posted on May 28, 2011
Printer is not turning on
Hi dear friend , seems your problem is depend to dc controler board which makes hi and low voltages and sends them to other sections like drive motor-display - laser unit - fusing section and other parts in the mashine . If you are a technision so you know well what can you do , if not , just follow power cord and check if there is in put AC voltage ( 220 or 110 volts)on the power supply board ? If you saw the voltage on the diode bridge go a little further on the maun capacitor and check about 300 dc volts on it . If there is not ac and dc volts , you should remove main connection from power supply to dc board then check the voltages that mentioned . Remember that , this is step by step diagnostic finding issue and all of my prefers to you was depend to this point that be careful and if there is nothing voltage even on the panel lights . Good luck
Nov 24, 2014 | Canon I-Sensys Lbp5050 Laser Printer
Remove battery cover from discman
Model of your discman is ... ?
Mar 17, 2014 | Computers & Internet
My screen is cut off
Unfortunately DC Universes online only displays in Hi-Defintion. If you don't have a Hi-Definition television, the game will appear to be "zoomed in".
Aug 03, 2012 | Sony Dc Universe Online
Hi, I own a vintage Sony Model no. D-555 Discman Portable CD Player. Unfortunately, I have lost both the User's Manual and the Wall Wort (power supply) for it. The DC In Spec. on the back of the...
The current factor for this model is around 750mA but if you can get an adapter with 1Amp rating there is no harm as the model requires good current factor with the 9 Volt supply.
Make sure that the polarity is correct and you do not cross connect on the pin.
Feb 18, 2011 | Sony Audio Players & Recorders
Chinese display on Siemens M65
setup>
Profiels,
Themes,
Display and then > Language and set to automatic or simply *#0000#
Dec 05, 2009 | Siemens M65
I can`t seem to get rid of the clock or channel on my screen HELP
Press Display or "info" button on Sony TV Remote, on-screen display will disappear. Please use TV Remote, no other remote will work for that.
Jul 15, 2009 | Sony KP-57WS520 57" Rear Projection...
Dual band amateur radio ic-3210a no rx no tx on uhf side?
Since the problem involves both the RX and TX of the UHF (assuming display/logic circuitry is OK), then possible areas of concern would be:
  • UHF VCO/PLL section;
  • UHF voltage regulator.
I am assuming that you are comfortable/familiar working with electronic circuitry and components, a DVM and a soldering iron. Initial course of action would be:
  • check for CPU triggers to IC4 and IC6;
  • check +5 & +8 regulator and the 30V DC to DC converter (unlikely, but worth the effort).
  • of course comparing with standards voltage checks would be the best route. A service manual would be of help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 22, 2008 | RIM BlackBerry Pearl 8100
Sony Walkman D-EJ361 Personal CD Player Logo
180 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
