Question about Sewing Machines
Where to oil on my brother LX 3125 - Sewing Machines
  • 55 Answers
SOURCE: I have Brother LX-3125. I am using it for the
the lx 3125 has a front loading bobbin case which must be removed by pulling the latch on the bobbin case and thereby pulling the bobbin case from the shuttle.
once you have the bobbin case in your hand, let go of the latch and the bobbin will drop out of the case. you can now wind the bobbin or replace it with a wound bobbin - make sure that the bobbin thread is threaded down the slot in the case and behind the tension spring, also the bobbin should turn clockwise when you pull the bobbin thread when loking at the bobbin in the case.
scott
Posted on Jul 26, 2009
SOURCE: My Brother LX 3125 does not sew zig zag stitches
Mine did the same thing. The needle is probably to high. Do not insert the needle all the way to the top. Lower it a bit and it should zig zag!
Posted on Feb 13, 2010
  • 1788 Answers
SOURCE: hi, My sewing mechine is brother
Most likely your machine is not threaded right, read your manual closely and double check yourself. Rethread your machine, no mixed thread use same weight, color does not matter but weight does. With your presser foot down, your top thread should be had to pull, with it up it should pull freely. Make sure your bobbin is wound evenly, and on a fresh bobbin. Then put in a new needle. Now, if the machine is still acting up, it may be your timing. You can call Brother at 1-877-276-8437 customer support. if you need a manual, go to www.brother-usa.com. I am answering this for free just to try to help you. Good luck
Posted on Oct 07, 2010
SOURCE: My needle does not stay threaded on my Brother Lx
keep a thread tail of 3-5 inches & when you sew make sure the thread is pulled behind the needle each time you sew, even if you have to hold the thread tail with your fingers
Posted on Nov 24, 2010
  • 1564 Answers
SOURCE: My Handwheel on Brother LX
sounds like you have the bobbin clutch disengaged. Check to make sure you have flipped it back to sewing mode.
Posted on Mar 08, 2011
How to oil lx-3125
Your owner's manual should have instructions. Download the manual here and then enlarge the picture on your computer screen to see it better. I believe it shows to put a drop of oil and spread it around the outside edge of the hook (see pg.41 for picture of the hook). Then there are five spots to put a drop of oil on the take-up lever and needle bar (pg.39). Basically, they are spots where the metal parts rub against other metal parts. Gently rotate your handwheel toward you and watch where things move and apply a drop of oil. The last spot is where the needlebar rubs when you raise the presser foot. Here's a manual to download:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB8QFjAAahUKEwjn342p5-fGAhVBMIgKHUsfC3E&url=http%3A%2F%2Fwww.brother-usa.com%2FModelDocuments%2FConsumer%2FUsers%2520Manual%2FUM_LX_3125_ENES_1612.PDF&ei=HuqrVefYLMHgoATLvqyIBw&usg=AFQjCNGhQ30zoj93NdlMH7lzNHr2J21zQQ&bvm=bv.98197061,d.cGU&cad=rja
Jul 19, 2015 | Brother LX3125 Sewing Machine
The hand wheel will not turn on my brother LX-3125 sewing machine
This sounds like a job for a repair shop.
Gears break, and all such things can be wrong.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 29, 2014 | Brother LX3125 Sewing Machine
Top and bottom thread will not connect
same old problem, the needle is to short. Loosen the needle screw and drop the needle down just a little at a time
Jun 30, 2014 | Brother Sewing Machines
User manual for brother sewing machine lx-3125
This is the site for your help! Just choose the type of your machine and its model and it will give you the complete user manual :)
http://www.brother-usa.com/manuals/default.aspx?productgroupid=3#.T-MTH5GeFS9
Jun 21, 2012 | Brother LX3125 Sewing Machine
On a brother LX-3125 when you sew an item then remove it the bobbin thread has bunched up alot of thread comin out
rethread the machine top & bobbin
change the needle
make sure the bobbin is not warped
clean under the needle plate & in the bobbin area for loose thread or lint
May 28, 2012 | Brother Sewing Machines
I need a manual for Brothers XE 5840-001 Model LX 3125 Prod. Code 885-407
Go to www.brother-usa.com and under support for home sewing and embroidery, you will be able to download a free manual.
Apr 12, 2011 | Brother LS2020 Sewing Machine
My Handwheel on Brother LX 3125 Sewing Machines does not move needle
Feb 13, 2011 | Brother LX3125 Sewing Machine
I have Brother LX-3125. I am using it for the first time. How can I take the bobbin out of the bobbin case. The case has an empty bobbin snapped in.
scott
Jul 26, 2009 | Brother Sewing Machines
Sewing Machines Logo
138 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
