Question about Arrow No.ETF50PBN Extra Heavy Duty Professional, , Electric Staple Gun/Brad Nailer
Triger wont fire on staple gun arrow eft50bn - Arrow No.ETF50PBN Extra Heavy Duty Professional, , Electric Staple Gun/Brad Nailer
2 Suggested Answers
  • 4 Answers
SOURCE: instruction book for Arrow ETF50P staple gun
Look at the rear of the stapler. Push in then down on the stapler tensioner to release it from the rear of the gun. Slide the tensioner out. Next slide the new staples over the rail and into the gun with points down. Slide the spring tensioner back in and connect it to the stapler by maneuvering its clip down and then up.
Posted on Jul 10, 2010
Why doesn't my Arrow fire any staples any more? It's not jammed. The piston doesn't seem to raise high enough to get over the next staple in line. Is it worn out?
Might be could also be that you have the wrong staples in it. Arrow makes about 15 different staple guns. The reason for that is so they can sell you the right for your use staple gun. This also means that certain staples only work for certain guns. Check the model then check arrow web site and find the compatable staples for that gun. Hope this helps
Aug 19, 2014 | Tools & Hardware - Others
T50 elite wont staple
I just bought a T50 elite, and it will NOT staple too.
Simple 3/8" staples loaded and nothing comes out.
Jan 31, 2012 | Arrow T50P ARROW STAPLE GUN
My etfx50 arrow staple gun jams, what can I do to fix this problem?
There is a screw and nut at the feeding end of the gun that allows you to remove the guide and get to the jam. Make sure it is unplugged and prepare for the firing mechanism to eject the jammed staple. Otherwise, a pretty simple maneuver. Wish Arrow would have included such in their owner's manual.
Nov 30, 2010 | Aerobie Arrow Etfx50 Staple Nail Gun
Arrow staple gun will not shoot it seems it is locked into place
You likely have i staple jamed in it see if you can get something that fits into the end where the staples come out and pull the bent staples out this is common even on bigger models
Nov 23, 2010 | Arrow T50P ARROW STAPLE GUN
How do I load JT21 staples into a Arrow JT27 Stapler gun?
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Nov 07, 2010 | Arrow T50P ARROW STAPLE GUN
My T50P will not discharge staples. I'm using the correct staples, there is no jam that I can see, and everything is well-lubed. It seems like the driver is not retracting far enough to allow a staple to...
sometimes mine won't shoot, and i find a single staple in the track, almost ready to fire out , but can't , they can be hard to see in the tract, i keep sharp pliers on hand to clear them. hope this helps
Sep 30, 2010 | Arrow T50P ARROW STAPLE GUN
The staples do not enter the wood completly
often when squeezing the tool the front gets lifted and the staple does not set fully. try making sure the front is tipped down fully and in contact wood when it fires. if that doesnt work the push rod is not working properly and is easier to replace than try to fix
Apr 22, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
Can't load staples
Fire the stapler with the load chamber open and down, see if anything falls out. Point it in different positions and fire it, just make sure it cannot fire anything at you.
Apr 18, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
Piece of staple stuck in the trigger section of arrow t-50p
First, remove the magazine pusher / spring and any staples loaded in the magazine.  Then try firing the gun to clear the staple.  Use a small jeweler's screwdriver and small needle nose pliers to get the staple out.  Reload and test.       These are relatively inexpensive staple guns.  If the problem persists it might be less trouble to replace the gun.     Best of luck and I hope this solution works for you.   Michael Mittelsdorf
Jan 11, 2009 | Arrow T50P ARROW STAPLE GUN
Arrow No.ETF50PBN Extra Heavy Duty Professional, , Electric Staple Gun/Brad Nailer Logo
55 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
