Question about HP Color LaserJet CP3525x CC471AABA Printer
49.1D33 Getting this error message on first time start up. What does this error indicate?
CAN YOU REMOVE A 404 CODE FROMMY PC?
Firstly i believe that you are getting this error code from your browser, the 404 code is simply a Not Found error message is a HTTP standard response code, many times indicating that the page you're looking for either cant be reached , ie servers may be down for servicing, or more the case no longer exists, its nothing wrong with your pc , but could be an issue if your getting this message on every single web page you try to link to ,
Oct 01, 2014 | Computers & Internet
Getting fdl error message, when I try to start load, door is not locking
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Aug 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Keep getting following error in Outlook 2007:
Fault bucket errors can be caused by many things. Sometimes it is a program that is using memory improperly. Also, it can be a hardware issue with the RAM itself.
You can Google RAM TEST and find programs that will test your RAM. MS makes one that you make a boot disk and run it.
Also, it never hurts to open your computer and make sure the RAM is seated properly. The last time I saw many random bucket errors it turned out to be 2 of 3 RAM sticks weren't properly seated.
May 04, 2010 | Dell XPS M1330 Laptop
False error empty cartridge
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jun 01, 2009 | HP Photosmart C6280 Printer
Error E000001 -0010
The error code is for the fixing assy not getting to the correct temperature in a specified time. The 0010 part of the code is indicating the copier was turned off and back on without resetting the error. To reset the code, Press the additional function button, then the numbers 2 and 8 at the same time and then the additional function key again. The display will now be indicating the service options available. Touch COPIER, then FUNCTION at the top of the display, the CLEAR in the middle, then ERR, then OK. Power down copier at the right side rear, then turn back on. If the error comes back then you will have to check the fuser assy to see if the front drive gear has failed or one of the thermistors has gone bad. Good luck
Mar 06, 2009 | Canon imageRUNNER 5570 Copier
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Error messages: U150 + Ink tank errors have occured
ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon i320
Try unticking ENABLE BIDIRECTIONAL SUPPORT on the Ports Tab under Printer Properties accessed through control panel / Printers and Faxes. Try to print - get error message Enable Bidirectional Support. Reverse back into Ports Tab and re-enable Bidirectional Support and try printing again.
Jan 13, 2008 | Canon BubbleJet i320 Printer
HP Color LaserJet CP3525x CC471AABA Printer Logo
113 people viewed this question
Seeker5211
Seeker5211
