Question about Acer Aspire 3680 Laptop
Wireless adapter not working
The laptop is running fine, but the wireless adapter doesn't turn on for the computer to search for an available network. I am in range of the wireless network. Is the some setting that needs to be adjusted or what?
  • DBotha Oct 27, 2008
    yes it's on and flashing
    Genius:
  • Acer Master
  • 1,250 Answers
Have you also switch on the wireless button
Posted on Oct 27, 2008
Adapter inactive
It is not the problem with the router. It is the problem with the wireless adapter on your computer. Open Network connections and look for Wireless network connection. If it is not there then open the Device Manager and look for Wireless network adapter under Network adapters. It seems that wireless adapter on your computer is not working or it is not detected by your computer. If you have external wireless adapter then unplug it and replug it.
Nov 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Sylvania net book doesn't see available wireless
If it's not seeing wifi networks, more than likely, there is something wrong with the adapter. Try these steps:
1.) Look for a WIFI switch on the side or front of your laptop and make sure it is set to the ON position. 2.) Check Device Manager to make sure the driver is installed and working. If it's not, uninstall and reinstall. 3.) Go into Network Connections and make sure the Wireless Connection is set to Enable. 4.) If none of that works, perform a System Restore to a time when everything was working. 5.) If this doesn't work, you need a WIFI adapter replacement.
I hope this is helpful and thanks for using Fixya!
Sep 23, 2011 | Computers & Internet
Laptop Winxp suddenly not seeing wireless network. Vista 64 main computer and Netgear WGT624 wireless router appear to be working fine.
Are you using the WZC on your WinXP computer of the wireless adapter's software utility? Try to reboot the computer and check on the system tray if you will see the computer icon with a red X, right click it and select view available wireless networks, if it cannot see anything... Go to Start, All Programs and look for anything that pertains to wireless adapters open the utility and refresh the list of wireless networks available.... if you see your wireless network name, select it and hit connect
Mar 27, 2010 | Computers & Internet
Can't power on wireless adapter. worked fine since
my laptop lenovo 500 cant find any networks, have done the usual searches and checks but to no avail. any ideas
Feb 13, 2010 | Lenovo 3000 N500 Notebook
My laptop is not detect the wireless
first check the wireless switch on your laptop if it`s turned on.check if wieless network is actually available where you are trying to connect,if any other wireless device can go online wirelessly.check device manager and uninstall it and install it again and if still it doesn`t work then it`s time to replace the device.
Jul 16, 2009 | Computers & Internet
No wireless adapter detected ad wireless button ot turning on
First u need to make sure ur adapter is installed correctly.
1. Click on Start-->Run-->Type in "devmgmt.msc"
which will open device manager.
Under device manager , u should find network adapters, make sure ur adapter is listed under it without any yellow exclamation mark or red cross which would mean that the drivers are not installed correctly or the adapter is disabled. In this case u need to reinstall the drivers via the CD.
2. Secondly u need to goto start-->run-->type in "msconfig"
which will open the system configuration window. Now under the "startup" TAB. Find the service for ur wireless card and disable it by unchecking it and then apply the settings and OK.
Reboot computer once
3. After reboot, goto start-->run-->type in "services.msc"
It will open the services windows . Find an option for wireless zero configuration . Rt click on it and start it.
4. Goto start-->run-->type in "ncpa.cpl"
It will open network connections window.
Rt click on Wireless network conection and enable it .
If it is already enabled , then rt click on it again and click on "View available wireless connections"
It will give u a list of all the wireless connections available in ur area.
Click on the one which is ur connection and then click on connect.
It might ask u for a wireless key if it is a secure connection. Enter the key and it should all work fine.
May 25, 2009 | Acer Aspire 5520-5579 Notebook
Wireless connection problem
Right click,on my computer,Click properties,click device manager (on the left),Click the Network adapter,Click on the wireless adapter and click enable.Then turn the wireless radio off and back on as you have done before or just restart the computer.
Apr 05, 2009 | HP Pavilion dv9000t Notebook
Wireless accessing problem with Lenovo Y410 using broadcom
If you have not been able to check this at all yet, please uninstall anything you install for the NIC and reinstall drivers... after that you can also try making sure the DNS is set correctly...
http://forum.dreamhosters.com/troubleshooting/76452-Is-my-DNS-correct.htm
Dec 06, 2008 | 3Com (3CRPAG175) 802.11a, 802.11g/b...
I have 2 laptops. One my my laptops (Inspiron 2200 Dell running on Windows XP home edition ) was working well until suddenly it would not connect to wireless internet. I am currently on my second laptop...
on your inspiron 2200...
1) click "start", "run", and type "services.msc"
2) select "wireless zero" at the bottom and check if it set to "automatic"
3) make sure that "wireless zero" is set to "start"
4) turn on inspiron 2200 wireless switch
5) right click wireless icon near to your computer's system time
6) click "view available wireless networks"
7) check if your wireless name is visible
Dec 05, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Acer Aspire 3680 Laptop Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
