Question about Kenmore Washing Machines
Inner wash basket # W10296143
Does the inner wash basket # 8557267 or #W10296143 on a Kenmore Elite Oasis Model # 110.27092600 suppose to have water in it ?
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: model 80 Sears Kenmore washine(Remove inner basket)
under the agitator youll see a lock nut appox 2-3in, around "locking" the inner basket to the outer basket. although they do sell a spanner wrench to remove this nut, A decent pipewrench and little muscle will get it loose, after that the tub will pull right out. assuming youve taken off the outer tub gasket cover
Posted on Mar 10, 2008
  • 1937 Answers
SOURCE: Trying to remove spin basket (inner tub) from Washing Machine
See the Sears parts site for washer 82372110.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82372110
The following may also help.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=146
Posted on Jan 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Elite 45986 Front Load Washer: I have a kenmore elite oasis he model#27092600 wil...
It appears your drive belt/coupling has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 27, 2010
Kenmore Elite Oasis washer does not lock
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 22, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
My Kenmore Elite Oasis HE is flashing a code "F50", can you tell me what the error code means?
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Oct 17, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
F 50 code machine stops
Hi
The F50 error code indicates that the rotor position sensor(RPS)detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Hello, I have a Kenmore Elite Oasis 110.27062603 washer that is displaying error code F 50
Aug 11, 2010 | Kenmore 24032\24036 Top Load Washer
My Kenmore Elite Oasis HE model # 110.2706 stopped working during the middle of a load and showed an F 50. Tried to unplug it, restart it and tried the clean machine mode. Nothing is working.
Jul 27, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore elite oasis washer model # 110.2703 shows code F-50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 25, 2010 | Kenmore Oasis 27042 Top Load Washer
F50 alarm on my kenmore oasis washer
Sep 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis he top load washing machine f 50 code
Aug 18, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE top loading washer model #110.27082602 gives me error code F50 and doesn't spin. Other blogs tell me that it is possibly a main control board. What do you think?
Mar 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Ellite Oasis - model #27042603
Jun 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
79 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
