Specs for temco fireplace model ADL 36 1
Model ADL36 1 btu,s heating for sq. ft
burzerko
  • 254 Answers
SOURCE: heating a 300 sq ft room to 125-135
What is the activity in this room is it and interior room how many exterior walls and what is the winter climate like where you are located.
Posted on May 30, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: I'm considering installing a Goodman LP Gas Furnace:sizing? Ops?
Consider a variable output system like a Carrier 58MXA or an American Standard AUX unit. This way the unit will ramp up or down based upon the heat required. These units have two or three Btu outputs so they will modulate to find the right range. Yes they will cost more than the Goodman units but will save you gas dollars for many years to come. Goodman is a good Builders unit but look to fuel economy as prices of fuel increases. Right now your furnace is is using 60 Btu's per square foot. Are you located in Alaska? Here in Vermont if we figure 30 Btu's per square foot, that is one very drafty home. Ask to see their Manual J heat loss. If they say "What" time to move on to another heating contractor.
Posted on Nov 03, 2009
james3751
  • 614 Answers
SOURCE: how much cfm heat should i have for a 480 sq ft
Where are you located? I am available now for live chat and would be glad to answer your questions. But we need to clarify. Rusty
Posted on Nov 21, 2009
SOURCE: Temco DV6400N fireplace will not turn on. Pilot
Do you have a remote that turns the unit on and off
and has different heat settings? Could be the batteries are bad in remote
Posted on Jan 02, 2010
  • 1015 Answers
SOURCE: I am looking for basic information regarding
The basic method that i've used for years is using square feet of floor space. There are all sorts of multipliers in different calculations dependent on number of windows, type of insulation, numberof doors to exterior, area of the country you live in and number of people in your house.
We live in north central Kansas and it gets plenty cold and hot here. I figure 1 ton of cooling for each 500square feet of space and 40,000 B.T.U. s for heating. This is just a quick way to figure and around here it works pretty well.
I always thought it was better to err on the side of a little more is better then a liitle less.
Hope this helps you some. Thanks
Posted on Dec 07, 2010
How many square feet does 50,000 BTU forced air furnace take
One BTU is sufficient to heat about 55 cubic ft. of air by one degree Fahrenheit.
With good insulation, it's about 75 BTUs per sq/ft
With poor insulation, about 300 BTUs per sq/ft
Oct 04, 2013 | Health & Beauty
Temco gas fireplace manual adl 36-1
where can I find a manual for a ADL 546-1 termco vent free gas fireplace. Really need your help as the township is requiring certification for these fireplaces. thanks
Jan 02, 2012 | Pool & Spa
Mr. Heater MRH-MH18B. looking heat a unfinished basment about 1000sq ft
If you're asking if the Mr heater you referenced will heat 1000 sq ft, it won't. You'll need at least 32,000 Btu's to heat that much space. Either a gas mounted convection or infrared wall heater or a vent-free gas fireplace, that has a maximum heat out put of 32,000 Btu's should do the trick. Keep in mind, the air temperature in a basement, doesn't change more than 10 degrees F, thru out the year, so more than 32,000 Btu's is not better.
Hope this helped you and thanks for choosing FixYa.
Sep 12, 2011 | Mr. Heater MRHMH18B Gas Utility
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
It is 106 degrees outside, I have a a/c unit which is cooling at 75 degrees in a 1180 square foot townhouse apartment, this seems like the unit is doing all it can with the excessive heat, is it
Unfortunately, 7000 Btu's will not cool 1180 sq ft. At best, it's rated for 400 sq ft, as it's only rated as a "Room Air Conditioner". To cool 1180 square feet, you'll need at least 30,000 Btu's (like in Central Air Conditioning) or 4 more window units spread out throughout the condo. It takes more Btu's to cool, than it does to heat.
I really sorry. I wish I had better news for you. Thanks for choosing FixYa.
Aug 02, 2011 | LG Heat cool Window Air Conditioner
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
Jan 02, 2010 | Heating & Cooling
Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
need a fireplace log for temco fireplace, serial number 10807, model number adl 36-2. middle log is missing.
Dec 21, 2009 | Computers & Internet
Heating & Cooling Logo
176 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
