Question about Nokia N900 Smartphone
Malfunction shutdown in 10 sec NOKIA N900
How i can fix malfunction problem?
3 Suggested Answers
marinos
  • 114 Answers
SOURCE: Hi, my nokia N900 screen goes slightly duller
It's completely normal. This means you have the display brightness set to lower than full brightness. To solve this, go to menu, select Settings, then select Display from Personalization menu and then adjust brightness to full and click save. now, switch off your device and then back on. Problem solved :-)
Posted on Jul 14, 2010
caroldon
  • 17129 Answers
SOURCE: i have download some sofdware
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Possible that the downloaded software is corrupt or is not a valid file. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Posted on Jan 25, 2011
What os code 12
The FI light on our Yamaha is much like the check engine light on your car. If it comes on it is real easy to check the code, and for the bike to tell you what is up. Just ground the diagnostic wire and it will start reading them out. Mine just had one code, but it will read out as many as you have. Then you can know what to address to potentially fix issues with the bike. There are more than this, but below are some basic codes to work with. Service Codes FI Indicator Light (LED) Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction
31 Vehicle-down sensor malfunction, wiring open or short
32 Sub throttle sensor malfunction, wiring open or short
34 Exhaust butterfly valve sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank key detection
51 Stick (Ignition) coil #1 malfunction, wiring open or short
52 Stick (Ignition) coil #2 malfunction, wiring open or short
53 Stick (Ignition) coil #3 malfunction, wiring open or short
54 Stick (Ignition) coil #4 malfunction, wiring open or short
62 Sub throttle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
May 01, 2016 | 2005 Yamaha FZ6 Fazer
Get out of malfunction mode?
Most likely there is a problem that will need a dealer to fix. Stuck in Malfunction Mode means there is a problem.
Nov 14, 2014 | Heating & Cooling
Why is the malfunction indicator lamp on?
the malfunction lamp is on to tell you that there is a fault in the system of the engine and/or gear box. It requires you to have the fault codes read and to have the fault fixed. It is there to notify you that something has gone wrong and to have it fixed before it becomes expensive.
Jun 20, 2014 | 1994 Volvo 850
P1300,p 1305,p1310,p1315 how do i fix these fault codes on a Toyota echo 2005.
P1300 Igniter Circuit Malfunction / 14
P1305 Igniter No. 2 Circuit Malfunction / 15
P1310 Igniter No. 3 Circuit Malfunction /15
P1315 Igniter No. 4 Circuit Malfunction
Jan 07, 2013 | 2005 Toyota ECHO
Malfunction detected c3451
gives the corresponding malfunction code and maintenance call
May 17, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Yzf r6s error 30 how to fix or remove
Fault Code: 33
Diagnostic Code: 30
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
Probable cause of malfunction:
Open circuit in wiring harness.
Malfunction in ignition coil.
Malfunction in ECU.
Malfunction in a component of ignition cut-off circuit system.
If the bike turns over but doesn't start I would check the kill switch and from there the wiring harness to the coils.
Dec 28, 2010 | Yamaha YZF-R6 Motorcycles
How do i check my codes in a 86 nissan z24 pickup
The self-diagnostic system identifies malfunctions of signal systems such as sensors, actuators and wire harnesses based on the input signals received by the ECCS control unit. Various malfunctions are coded and displayed on the control unit by a series of blinking red and green lights. Results of the self-diagnosis are retained in the control unit's memory and are displayed when the mode selector, located on the rear of the control unit, Fig. 122, is switched to the On position. When displaying malfunction codes, the code number can be determined by counting the number of light pulses. The red light represents the first digit of the code, while the green light represents the second digit of the code. For example, a Code 32, would be displayed as three flashes of the red light, followed by two flashes of the green light. Malfunction codes can be translated as follows:
  1. Code 11 -- Crank angle sensor circuit malfunction.
  2. Code 12 -- Air flow meter malfunction.
  3. Code 13 -- Water temperature sensor circuit malfunction.
  4. Code 21 -- Ignition signal malfunction.
  5. Code 23 -- Idle switch circuit malfunction.
  6. Code 24 -- Transmission switch and clutch switch circuit malfunction.
  7. Code 32 -- Starter signal malfunction.
  8. Code 42 -- Throttle sensor circuit malfunction.
  9. Code 43 -- Injector circuit malfunction.
  10. Code 44 -- All monitored systems satisfactory.
May 10, 2010 | 1986 Nissan Pickup 4WD 1986
Service engine light comes on 2006 pontiac blonnie, code 0440, what is it and how do I fix it
First thing to check is whether the gas cap is on tightly. If it is, the next would be to replace the gas cap. That solves 90% of these problems.
P0440 is a generic code for Evaporative Emission Control System Malfunction... pretty much for all makes. It takes 1 malfunction to create a pending DTC... at 2 consecutive malfunctions the MIL(Malfunction Indicator Light,Check Engine Light, etc.} Ok, after you fix it, it should take 3 trips to turn off the light, then 40 more to Remove the code from the computers memory
Oct 04, 2009 | 2005 Pontiac Bonneville
I am blowing error codes P0442 and P0456, can i fix it myself
P0442 Evaporative Emission Control System Small Leak Detected
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
You should replace the VAPOR CANISTER PURGE REGULATOR.
Oct 03, 2009 | 2002 Dodge Dakota Club Cab
Nokia N900  Smartphone Logo
224 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
