Question about Apple (A1181) 133 in Mac Notebook
Mouse and keyboard wont work on macbook a1181
5 Suggested Answers
  • 19 Answers
SOURCE: Macbook A1181 black take the
When you start up your computer, hold down the option key. This will bring up the bootable devices menu. Depending on wether or not you have an Operating System installed, you should see either 1 or more icons. Click on the one with the CD icon that should be labeled "Snow Leopard". Once you have clicked on the icon, click the arrow beneath it and your Mac will boot off the OS CD.
Posted on May 31, 2011
Macs R We
  • 481 Answers
SOURCE: Iam ahmed morad Want Driver For apple macbook
You can install Windows 7 on a MacBook using either Apple's Boot Camp, VMWare Fusion, Parallels, or a combination of these.
Once you have finished installing Windows 7, you should shut it down, insert the gray disc #1 that came with your Macintosh, then start up Windows and let the disc contents autorun. This will install Windows drivers for the Apple hardware. If the disc does not autorun, just run it manually from My Computer.
Posted on Jun 18, 2010
shadowqat
  • 72 Answers
SOURCE: macbook a1181 works for a couple days and then
Your best bet is to reset the System Management Controller;
(I'm not sure if your model has a removable battery or not, so I'm providing both methods)
Resetting the SMC on Mac portables with a battery you can remove
Note: Learn about removing the battery on MacBook and MacBook Pro.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Resetting the SMC on portables with a battery you should not remove on your own
Note: Portable computers that have a battery you should not remove on your own include MacBook Pro (Early 2009) and later, all models of MacBook Air, and MacBook (Late 2009).
  2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
  3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
  4. Release all the keys and the power button at the same time.
  5. Press the power button to turn on the computer.
    Note
    : The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
...and then reset the Parameter RAM:
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Posted on Jun 13, 2011
SOURCE: How do I take apart my Macbook macbook a1181 to
need a battery replacement apple a1181
Posted on Feb 18, 2012
CAN I UPGRADE FROM OS X LEOPARD 10.5 TO MAVERICKS
Nope, yo can upgrade to osx lion (10.7 max),
Apple says you'll need a better graphics card if you want to use mavericks.
Your macbook has a Intel GMA x3100 which is unsupported.
Try osx lion if you hace 4gb of RAM. It's cool :)
Cheerio :)
Sep 20, 2014 | Apple MacBook 13 inch NW A1181 A1185 WHITE
GE 97986 mouse and Macbook Pro
try a hp mouse it worked for me
May 25, 2012 | GE ho97986 Mouse
Keyboard and touchpad not working on macbook a1181 but power botton work fine
I've found the same problem - keyboard, touchpad and mouse buttons not responsive - and was almost ordering a new KB/touchpad replacement, thinking they were bad. I searched the internet and found that people had already done that with negative results. Studying the KB/touchpad circuit board I found that the controller was a USB device. So I had an idea, why not test it using one external USB port. I soldered the proper wires to a USB plug and connected it to a side USB port and, voil?!, it worked. Then, I removed 2 inductors from the original D+ and D- lines to isolate the KB/touchpad connector and soldered 2 pieces of wire to one of the side USB ports - in sequence, I covered that port with a small aluminum plate to avoid it being used for another device. Reassembled the computer and everything is working fine, back to normal (with one less USB port, of course).
Jul 07, 2011 | Apple MacBook 13 inch A1181, A1185, MA561,...
How do I take apart my Macbook macbook a1181 to switch the plastic outside casing on it?
Go here and look at the categories for "Upper Case" and "Lower Case".
http://www.ifixit.com/Device/MacBook_Core_Duo
That should get you started.
May 17, 2011 | Apple Computers & Internet
I have obtained a second hand wireless Dell Mouse. I hav a macbook laptop and a compaq laptop. Can i use it on any of these?
You can use it on a PC for sure. That keyboard was meant for Dells but it will work on a compaq as well. As far as I know, it won't work with a Macbook but you can hook it up anyway to see if the macbook has built in drivers for it since the dell website doesn't have any drivers for the MAC.
May 01, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My Logitech stopped working on my Macbook Pro
Try pressing the red CONNECT button on bottom of mouse and on the mouse receiver.
Jun 11, 2009 | Logitech Cordless Mouse
?have 17 inch macbook pro and 24 inch apple monitor, also apple wireless mouse and keyboard. Every once in a while the mouse and keyboard lose connection but the trackpad works with the monitor along with...
If you have "good batteries" installed in the mouse and keyboard and you still have the problem- the best way is to remove the devices via the System Preference panel in your MacBook and then re-install them again. It is important that you remove them first as the system may revert to the previous connection. Good luck!
Apr 29, 2009 | Apple Wireless Mighty Mouse
Apple (A1181) 133 in Mac Notebook Logo
364 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
