Question about Uniden DXA15588-2 Twin Cordless Phone
How to turn down based station ringer in a Uniden DECT1480
The base station on the Uniden DECT1480 has an answering system and a separate ringer from the handsets. Have been unable to determine if the loud ringer on the base station can be turned off or at least down.
SOURCE: tru9466 base and tru9465-2 handset
You need to simultaneously hold down the red hangup and # buttons for about five seconds or until the handset says de-registered. You can then put the handset into the base unit and it will registere.
I had this problem myself on two Uniden TCX905 phones and that was the solution. I couldn't find it in the manual but verified it with Uniden support.
Posted on Jul 15, 2008
SOURCE: Uniden handset TCX905 with base unit TRU8866-if compatible?
Forget what I said before, the TCX905 does NOT fit into the TRU 8866 base unit with the battery cover on.
REMOVE THE BATTERY COVER TO REGISTER THE TCX905 WITH THE TRU8866 and everything works fine....
Posted on Oct 21, 2007
SOURCE: Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
Posted on Sep 20, 2009
SOURCE: Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Posted on Feb 02, 2010
PCTechOnline
  • 532 Answers
SOURCE: Handset won't connect to base unit
Try placing the handset in the base unit to register it. Then see if it is found by the base.
Posted on Mar 21, 2010
How do I turn down the ringer volume.
For the base station set the ringer switch on the base from high to low. To turn it off select off. You can find that switch on the panel where the phone plugs into the wall on the far left.
The handset is adjusted the same way on the leftside as you are looking at the phone.
Sep 17, 2017 | Sony Lands Phones
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
How do I cut ringer offhow do I put someone on hold andanswer another call
You may download a copy of the manual at http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1480-2om.pdf.
To decrease the ringer volume, press DOWN while in standby mode.
Call waiting is a service offered by your telephone company, not a feature of any particular phone. To learn how to use it, contact your telephone company for their instructions.
Jul 18, 2013 | Uniden Dect1480-6 Dect 6.0 Cordless 6...
How to turn volumn on ringer up also put in the dates & time
To change the ringer volume, while in standby mode (not on a call, not doing anything in a menu, etc) press Up(+) or Down(-) on the base or press up or down on the circular cursor pad on the handset.
The date and time should be set automatically the first time an identified call comes through. If you need to change it, press MENU/SELECT on the handset then select "Day & Time". Select the day of week, then use the number keypad to enter the hour and minutes in HHMM format (e.g., enter 0345 for 3:45). Then, select AM or PM.
If you need a manual, you can download one at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1480-5Com.pdf.
Sep 19, 2011 | Uniden Cordless Phone
DECT1480 series - system is sreaching only! Also answering base will not turn on.
check the cable of the base. may be it wont be getting electricity so show it to some expert or visit Uniden Customer care centre along with your complete system
Sep 07, 2010 | Uniden Cell Phones
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Dec 30, 2009 | Uniden DXA15588-2 Twin Cordless Phone
The base ringer on my Uniden TRU9480 base station rings very loud and cannot find where to either adjust or discontinue the ringer. Jackgee1
I found my owners manual and to adjust the ringer on either the Base Station or Hand Set as follows:
with the hand set in place just use the base arrow up or down to go from 0 (off) to 2 (loud) and on the hand set just use the arrows for high low or off. Just bew sure to have the hand set on the base before adjusting the ringer
jackgee1
May 01, 2009 | Uniden 2.4 GHz Cordless Phone System
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Uniden DXA15588-2 Twin Cordless Phone Logo
120 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
