Question about Dell Inspiron 6000 Notebook
Easy Update fails in SS9
After installing SS9, Easy Update reports "no update necessary" day after day. (This happened also with SS8 initially, but Avanquest posted a fix.) I am running Windows XP. Gene
  • muldrin Oct 28, 2008
    I have the same problem... Avenquest System Suite 9 will update. Called their techs and they pointed me to a page with .dat file downloads staying it would fix my problem. The downloads were for System Suite 8 and would not work. This is a serious problem because this program leaves the user mostly unprotected against viruses and malware......and thats what we are paying for.....they need to fix it NOW!!
  • 177 Answers
Go to your control panel, click on add/remove programs and then click on the program (not remove) to see support info, you can usually go straight to the company's website or check for updates
Posted on Sep 20, 2009
Microsoft update downloads the same updates every day. what could be causing this to happen?
they may be failing to install, or maybe you just haven't actually installed them. next time it downloads them, let the wizard finish installing them before you do anything.
Feb 01, 2012 | Dell Latitude D800, PP02X Series Laptop...
The application failed to initialize properly (0xc0000135).
When attempting to run Microsoft .Net based applications, you may get the following error on startup:
The cause of this error is that the Microsoft .Net framework is not installed or is damaged in some way. Therefore applications will fail to launch.
To fix this error you can run Windows Update and find the Microsoft .Net framework update to install. Alternatively, you can download the Microsoft .Net Framework directly from Microsoft.
Aug 18, 2010 | Computers & Internet
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
When i update it freezes at 3% please help
If you knew it was frozen you should have not of let it go on for another day and if you try to use an Update it will end up freezing so don't use an update and those updates can take days for them to finish
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
Avenquest system suite 9
Two things to try. First, uninstall SS9 completely> restart> disable any network access> turn off automatic security settings in vista> reinstall SS9> restart> enable vista security settings> reconnect network> run update. Firewall and AV should work now. If this does not work then try the same steps above but do a selective install and uncheck firewall. When install is complete and you are connected to the network then go into control panel and, using the system suite repair function install firewall. Good luck.
Jan 19, 2009 | HP Pavilion dv7-1130us laptop
CANNOT INITIALIZE API - REINSTALL THE SOFTWARE
When you installed the 5.0 in, did you put the update in also?
ecdc_v53.5.10 basic_enu
You will need this or 5.0 will not run.
Mar 30, 2008 | Roxio Easy CD & DVD Creator 6...
Magellan Explorist 500
The necessary map software is not installed - did you buy the unit with software?
Mar 19, 2008 | Magellan eXplorist 500 GPS Receiver
Driver update problem for digital camera
In order to get rid of the error, you have uninstall the driver, update your operating system with updates from Microsoft (see below for instructions) and follow these suggestions:
  1. Best method, copy the photos to the computer by connecting a card reader to the computer and plug the SD card into the card reader and transfer using your favorite software (like Picasa) or through My Computer.
  2. Drivers are not required for the A400 and Windows XP. So you can plug in the camera, without drivers and it should work. This appears to be the one that's not working, You need to un-install the drivers and either reinstall, try updated drivers from the links below, or don't use the drivers.
This information is in the manual on page 96. See this link for the manual.
See this link for details about the WIA driver.
About the error "driver update failed" rea
I personally have stopped altogether trying to get the drivers and software installed because they can cause more problems. I just transfer using a card reader.
If you want to use the software that comes with the A400, it's best to install ZoomBrowser, then you will need to follow to this link to get the update to this software.
Once this is done, reboot your machine to make sure the system is then up-to-date.
Make sure you have also updated your machine with Windows Updates. This is done by opening Internet Explorer and clicking on Tools | Windows Updates. Follow the links at their site to update your machine.
Dec 06, 2007 | Canon PowerShot A570 IS Digital Camera
Forget the hassle of trying to get the camera linked to the pc with software etc....
Much faster transfer of photos and no hassles with a usb card reader works every time 'no drivers' to mess with.....
http://www.memorybits.co.uk/shop/card-readers/14-in-1-card-reader-plus-100-meter-bluetooth-dongle-/4314
Nov 21, 2007 | Canon PowerShot A400 Digital Camera
Dell Inspiron 6000 Notebook Logo
108 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
