Vivitar wireless keyboard connection problems
Lost manual on how to reconect wireless key board to the computer cannot connect
jitenok
  • 151 Answers
SOURCE: Wireless Keyboard not connecting
Check driver for it
  1. right click on my computer
  2. click on properties
  3. click on hardware
  4. click on device manager
  5. click on mic & other pointing device
  6. click on(+)
  7. then right click mouse
  8. click on update driver
  9. select second option in window(advanced)
  10. then click on( search removable.......)
  11. then insert driver cd in cd rom
  12. And click on Next option
If you have done this then do this
  1. if it is not work then do above procss and select third option(Don't search.I will...............)
  2. And click Next option
  3. click Next option in next window.Thats it
Hope this solution works
Posted on Mar 16, 2008
blackhearted
  • 30 Answers
SOURCE: Wireless Mouse and Keyboard Connection Lost
You might want to look into the settings on the wireless appliances they may be using a power saving setting. if they are wireless they run off batteries. Most devices now have a power save setting, most Mp3's do and most other decives as well check to see if this is the case, if not feel free to contact me and I will help you futher Thank You!
Posted on May 01, 2008
SOURCE: wireless keyboard not functioning
I unplugged the usb connector and took out the batteries for both the keyboard and mouse for 30 seconds. Then I plugged everything back in.
Posted on Jan 11, 2009
yooperbud
  • 8637 Answers
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Posted on Jan 20, 2009
SOURCE: wireless keyboard no power
Try scraping at the positive battery terminals.  Worked for me.
Posted on Mar 01, 2009
Not sure if it's a wireless connection issue or a keyboard hardware issue
Did you replace the batteries in the keyboard? Usually wireless keyboards or mice are powered by AA or AAA batteries. I would replace first to see if that is your problem
Nov 02, 2012 | Computers & Internet
I lost the manual so I don't know how to connect the BenQ x730 wireless key board
you may download manual from "http://benq.co.uk/support/downloads/downloads.cfm?product=688"
you must vote for solution
Aug 23, 2010 | BenQ X730 Pro Keyboard
Wireless key board & mouse
  • Decide where the keyboard will be placed, whether it is on your desk or a table. Spend a little time experimenting with positions and placement to make sure your wrists and arms will be comfortable. You should consider ergonomics before you set up the keyboard to avoid repetitive motion injuries later on.
  • Step 2 Install the batteries (usually three AA) in your wireless keyboard. Replace the cover securely so the batteries are connected properly. Turn the keyboard on.
  • Step 3 Get out the wireless receiver that came with your keyboard. Position it close to your computer, but not closer than about 8 inches, as the computer itself can cause interference with the wireless signal. You will also want to set the receiver away from other interference-causing devices, such as radios, TVs and telephones.
  • Step 4 Ensure that your wireless receiver is no more than about 6 feet away from where you plan to set your keyboard.
  • Step 5 Insert the CD containing the accompanying software into your computer. A dialog box should appear on your screen. If the install instructions don't pop up right away, manually access the CD by double-clicking its icon or selecting it from the Start menu.
  • Step 6 Plug the wireless receiver into a free USB portmag-glass_10x10.gif on your computer. If you don't have any ports remaining on your computer, you can use an external USB hub instead.
  • Jul 07, 2010 | Dell Wireless Keyboard Optical Mouse w0147
    How can I connect my Fujitsu Siemens key board with my Acer AL1912 monitor? There is a connect button on the key board, but where is the connect button on the Acer?
    Is it a wireless keyboard? If that is the case, then you should have a receiver unit attached to the PC, usually to a USB port. The ACER is justt a monitor, here is the user manual: http://www.retrevo.com/support/Acer-AL1912-Monitors-manual/id/719ag115/t/2/
    Jan 20, 2010 | Acer AL1912 19" LCD Monitor
    My keyboard works properly for about 20-25 minutes and then the keys I touch are not represented by the letters that are printed. I have a new wireless Logitech and new wireless Logitech mouse. It does not...
    check *********** board .Please try to connect your key boardusing USB converter. and see whats happening there may be a problem in the key board is which is inbuilt motherboard
    Oct 04, 2009 | Computers & Internet
    The key board is not working- I can not log on- the mouse is connected but the light on the key board is off
    Try to shut down the computer unplug it wait for about 2 min. Plug the pc back into the wall and make sure all the keyboard is plugged in all the way.
    If this is a wireless keyboard do the same, and make SURE the batteries are FULLY charged. Press connect to see if the wireless devices work.
    Sep 12, 2009 | Logitech S520 Mouse
    Wireless keyboard stopped working; mouse still does though
    on this key boards problem is that they key pad circuit board has no mechanical connection or wire connection it merely lays across the circuit board loosing contact that's why if you squeeze the bach it starts working again
    May 03, 2009 | Gear Head WIRELESS keyboard/Mouse
    My touchsmart key board stopped working. it did this once before and I think I somehow pushed some buttons and accidentally got it working again but now it has stopped again. is there a button or switch...
    looks like this is a wireless keyboard? If so there is usually a connect button on the bottom of the keyboard and/or on the unit itself. You may have just lost the keyboard to wireless receiver connection.
    Jan 08, 2009 | HP TouchSmart IQ770 PC Desktop
    Sony PCV-V210P PC with PCVA-KB6/U computer and wireless keyboard
    Press the CONNECT buttons located on the left panel of the computer and then press the connect button on the bottom of the keyboard, to establish communication.
    Aug 05, 2008 | Sony VAIO PCV-V210P PC Desktop
    Lost manual
    go to this link my friend.
    http://www.labtec.com/index.cfm/service/listing/AMR/EN,crid=68,crid2=1762
    you can download thier drivers and the instruction manual as well.
    Goodluck!!
    Feb 05, 2008 | Labtec 9675260403 Keyboard
    Computers & Internet Logo
    194 people viewed this question
    David Payne
    David Payne
