Question about Mountain Cycling
Manual 2010 8202-41 next amplifier mountain bike
Rear gear replacement parts
  • 5 Answers
SOURCE: Mens Titan Pathfinder Mountain Bike
If the gears will no longer go back on the bike, I would recommend buying a new wheel (including a new rear hub). It is usually easier and more cost effective to buy a wheel than to replace the hub. To replace the hub (the part that is stripped on your bike) you would also have to remove and replace spokes, etc. Search online for the wheel size you need (probably 26" - you can check the tire size) or take to a reliable bicycle shop and they will gladly help you. Anyway, you need a new hub but probably better off getting a new wheel - much easier.
Posted on Aug 27, 2009
  • 1138 Answers
SOURCE: trying to reassemble rear wheel gear assembly for
This should help you:http://sheldonbrown.com/gearing/index.html. Also try here:http://www.parktool.com/repair/byregion.asp?catid=4 Hope these sites help. Good explanations and pictures.
Posted on Aug 29, 2009
Testimonial: "Thankyou, both sites were very helpful. Excellent pictures & directions both. Easy to follow. Another helpful site I found was bicycletutor.com. "
  • 71 Answers
SOURCE: i have a mongoose rockadile
i have never fixed this bike but normally there is an allen wrench bolt right on top of the shaft you have to loosen it (not take it out there is a tightening nut at the other end of the that you want to stay on) then after it is lose you should be able to adjust it but if not you will have to loosen or take of the first bolt down the shaft and that should make it able to be adjusted i hope this helps
SabiousOne
Posted on Nov 09, 2010
dunnbiker
  • 8546 Answers
SOURCE: took apart the rear assembly
http://www.bicyclinglife.com/howto/changeachain.htm
Posted on Jan 24, 2011
  • 205 Answers
SOURCE: I require an instruction manual
Below is a link to the tech docs for the Shimano Alivio system look for the specfic componet you would like to adjust. The links with SI are the Service instructions. EV are the parts lists.
Shimano Alivio System info
Hope this helps.
Zeppelinx12
Posted on Mar 16, 2011
Need to find a new seat/replacement post for 24" Next PX 4.0 Boys Mountain Bike, Black
I am a privet bike repair shop the seat post is a 25.4 mm 9 inch log i have a used seat post in stock and a new seat in stock that will work with a next px 4.0 a had the same issue you contact me on my web site
May 08, 2015 | Next 24" PX 4.0 Boys Mountain Bike, Black
I want to replace my Pacific Bicycle derailleur parts.The parts that are on there are td-one and the bicycle is a mountain bike. the model number is R4446WMUT.Later on I would like to replace possibly the...
Are you in love with TD-One parts or would an upgrade to almost anything Shimano be a possibility? Look on eBay. A Pacific Bicycle or any bike sold by a department store isn't really what one would consider an upgrade-worthy project. A new bike better might be cheaper considering labor costs. Replacement of parts for failure might be worthwhile.
Sep 16, 2011 | Mountain Td-one Bicycle Front Derailleur...
I have a SRAM 3.0 rear derailer. It is difficult going into the two largest gears, I have a 7 speed cassette. I notice there is no barrel adjustment on it. Any suggestions
The barrel is for fine tuning the indexing among the gears. Limit screws set the inner and outer physical swing of the derailleur.
A simple web search for "Sram 3.0 Mountain Bike Rear Derailleur adjustment" finds the manual.
http://www.sram.com/_media/techdocs/RD_X0_X9_X7_5_4_3_QS_03.PDF
There IS a barrel adjuster.
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
Aug 10, 2011 | Sram 3.0 Mountain Bike Rear Derailleur -...
I have (2003-2005 ?) year model Schwinn Sierra GSX 26" mountain bike. I need a diagram that shows how to route the chain. I had to remove the back tire. Now I can't get the chain to line-up on...
Basically, shift the rear derailleur to the highest (smallest) gear before removing/installing the wheel.
Google "how to replace rear wheel on a bike" for video advice.
Jun 18, 2011 | Schwinn 26in Men's Drifter Cruiser Bike
Need pulleys for my TD One derailleur
There are no pulleys on the front derailleur. Only the Rear derailleur has pulleys.
The Front derailleur consists of two plates that work the front gears (chainrings)
The Rear derailleur consists of a long arm with 2 pulleys to wrap the chain while shifting the rear gears (cassette).
Pulleys range from $10- a pair to $75-. Your local bike shop should have a suitable replacement set of pulleys, depending on the model of your derailleur it is sometimes less expensive to just replace the whole unit.
Dec 09, 2010 | Mountain Td-one Bicycle Front Derailleur...
I bought a mountain bike with Shimano Altus gears over the net with most of the assembly in place. Have indexed the rear gears which work fine. Did the same for the front deraileur works changing up but...
There are a couple of possible problems. You can try backing off the cable tension a little bit at the shifter and running back and forth through the gears adjusting as you go till it hits 2nd coming down.You can also try backing off the High limit screw on the derailleur. This will allow the shift to start a little farther from the bike hopefully hit 2nd. Hope this helps.
Sep 12, 2010 | Mountain Shimano Altus Front Bike...
Trying to reassemble rear wheel gear assembly for huffy mountain bike. i didn't take it apart and don't have a manual. someone else took it apart
Aug 29, 2009 | Huffy Blackwater Men's 26-Inch Mountain...
2005 Mercury Mountaineer rear end whine, how hard to fix
Before you do this you might want to try fresh gear lube. On Ford products they use a synthetic additive in the rear and not in the front 4x4 axle.
The next thing would be to determine if it is a wheel bearing or a pinion bearing. You have to pull the axles and eliminate them as the problem. You might get lucky and not need to do the pinion.
The technical part of shimming the pinion gears with replacing the pinion bearing is about the worst part of the job. You won't know about the gears until you see them. You will need extra shims on hand.
It is a moderate job for two people. If you have all the parts it can be done in a day.
Aug 21, 2009 | 2005 Mercury Mountaineer
Feb 14, 2009 | TitanNet Bike USA Titan Pathfinder Ladies...
Cycling Logo
412 people viewed this question
Top Mountain Cycling Experts
Michial Gueffroy
Lawrence Oravetz
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
