Question about Bosch Dryers
Bosch condenser dryer - filter indicator lamp flashing -filter clear
Bosch condenser dryer WTL6305GB/05 Filter lamp flashing although filter is clear
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
SOURCE: How to clean the bottom filter
Don't know how old your machine is but on my wtl5400 the bottom flap is opened by:
1. open the drier door
2. note small round button on the lower right hand side of the drum surround
3. press the button which will spring forward then
4. lower filter cover springs off giving acess to filter drawer
NB if the filter is over full the button will spring open itself as a gentle hint
NNB YOU CANNOT CLOSE DOOR WHILE THE BUTTON IS EXTENDED so take care door will only close when lower cover has been correctly replaced relocating the button flush with the front of the machine
Posted on Sep 25, 2008
  • 7 Answers
SOURCE: Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Posted on Oct 25, 2008
  • 864 Answers
SOURCE: Bosch Axxis dryer - lint filter indicator lights up
Make sure the exhaust vent duct is clean all the way to the outlet.
Posted on Nov 11, 2009
My Bosch condenser dryer has a nasty smell. Help me?
1. outlet vent is it clear and blowing a good amount of air out
if not remove condenser stand upright in a large sink/bucket of hot water and shake up and down to wash out fluff, dry and vac out,
2. clean dry filter
3. if machine is quite old it may need the air ducting parts cleaned out as fluff builds up gets damp and smells,
good luck
Jul 17, 2016 | Bosch Dryers
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
I recently had an ventless Bosch dryer installed (WTE8600US) and I keep receiving this message F:03 which the manual says "check hose for condensation outlet". any advice?
For the F:03 problem on the Bosch Axxis (WTE86300US) do all the things mentioned in Solution #1 above. Sometimes the lint in the condensation filter channels (those that run from front to back)can be quite stuck. Use a pipe cleaner to get in there or a garden hose with a spray nozzle. However there is one more crucial step not mentioned in the manual or in Solution #1. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver and gently pop it open. Under the panel is a small chamber where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place. This should fix your problem.
Dec 13, 2009 | Bosch Dryers
I have a Bosch Maxx condenser tumble dryer that wont work.
Have you taken the condenser itself out from the bottom of the machine? Remove the condenser from the bottom door and rotate the clamp tags which secure it in. Slide condenser out (aluminium mutli-finned box assembly) and carefully take it outside. Use a garden hose with lots of water pressure to spray each vent passage carefully to clear lint and dust away. Passages must be cleared in both directions, long ways and cross ways. Cross ways is the problem area and once you finish clearing the air ways you should see daylight through the condenser easily. Reassemble and always clear lint filter in the door /drum area.
Good luck.
Sam
Sep 02, 2009 | Bosch Dryers
I have a Bosch Exxcel tumble- dryer. It starts normally and runs normally for about five then, then a light begins flashing and washing is completely wet. I have been moving the washing around and...
3 important things to maintain with this dryer.
1. after every dryer use you MUST completely clean the lint filter in the machine. examine the fiter closely as washing powder and softener overuse can clog the fine mesh.
2. You should empty the water draw regularly.
3. You need to clear the condenser of lint and dust. This is located at the bottom of the Machine behind a hinged door. Unsecure the condenser and slide it out. (aluminum mutifinned box assembly) Take the condenser outside and using a garden hose with plenty of water pressure , carefully spray the airways clear in both directions, longways and crossways. Crossways is the more difficult to clear but must be done. Make sure you can see daylight through the fins once completed. Reassemble and test. If still problems a service man must come and clear lint and build up away from the pump area.
0417362369 Melbourne and Metro area
Regards Sam
Jan 29, 2009 | Audiovox Bosch 718 World Cellular Phone
Bosch Tumble Dryer Filter Light
Helenhjb, there is a couple of things I can think of that can cause this. The filter is one. The mesh on the filter is extremely fine, so get a steady stream of water running, then put the filter under the water. If the water doesn't run straight thru, then wash the filter with detergent until the water does run straight thru. If this works fine, then your issue may be that the door switch is set too far back and when you do heavy loads, the laundry pushes on the door and shuts down the dryer. On the Bosch, any time you open the door during the cycle, it will flash the lint filter lamp. The only other thing I know of usually has an E:01 flashing on the display is restricted vent. Hope this helps.
Jan 29, 2008 | Dryers
The condenser has two "channels" one for the moist hot air that are easy to clean and inspect. The other flow is perpendicular where cool air drawn from outside and passes through. These channels, viewed from the side can get blocked over time with dust/fluff. I blasted mine with a pressure washer and it was obvious from the change in light when looking through it that it was clogged before I blasted it.
Sep 18, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
44 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
