Question about Cambridge Soundworks CD-740 Clock Radio
Volume fluctuating the volume fluctuates dramatically on fm without touching the unit or the remote controll
2 Suggested Answers
Open SKy
  • 620 Answers
SOURCE: Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Posted on Nov 26, 2007
Why does the drive speed of my Craftsman Lawn Tractor fluctuate between fast and slow.
I feel you may have a spring that is on the carb that has broken or come off. The thing the spring goes on is just floating back and forth as the engine revs making it rev up and down. I had that happen and had to get a new spring. this spring should be hooked to the control section of the carb.
Nov 13, 2017 | Craftsman Garden
My Dremel 3000 makes a grinding noise and fluctuates speed while in the low speed range. Why is this?
I have one that I must keep pressing ******* the speed control with my thumb during use otherwise it is hopeless except at or near maximum. The potentiometer is of poor quality.
Jan 02, 2017 | Speed Washing Machines
Volume fluctuations
Does the volume fluctuate through speakers?
Feb 19, 2016 | Marantz Audio Players & Recorders
Speed fluctuating on controller. goes from slow to fast without me touching controller on pride jazzy 614 hd battery powered chair
Your controller is dirty. Unfortunately, the unit is sealed and you therefore can do other than replace the unit. I suggest monster scooter parts at Jazzy 614 HD Parts The cost is high at $377.00. If you were really into fixing electronics it is possible to take the unit apart and clean the joystick, but that is a stop gap measure until you get your new joystick. Let me know if you need instructions on tearing the joystick apart and I will help if I can.
Jul 22, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Sometimes, when I take a picture with my 40d the automatic shutter speeds that display can fluctuate dramatically from 100th of a second to 10th of second in just a split second before I press the shutter,...
your camera is probably set to SPOT exposure instead of AVERAGE exposure,. Which means, your camera is taking readings from a smaller area within the frame instead of using the whole frame to decide exposure. When in spot exposure you can move a hair and the exposure will change dramatically. does this make sense? put your camera back into average metering.
Feb 07, 2011 | Canon EOS 40D Digital Camera
Just bought E420VL 42" LCD
Go into menu, sound set-up, and switch SRS to off. It's a vizio thing they came up with to act like "Smart Sound" where commercials won't be louder. It is total BS and does not work, it makes your normal sound fluctuate. Worked on all 3 of my Vizios. Hope it helps you.
Dec 13, 2010 | Vizio Televison & Video
The volume goes up by itself - SABA M5115GT
This is due to the signal reception. Some channels are broad casted with strong signal strength. Therefor you will find the audio is louder than other channels. Also, if there is voltage fluctuation/surges/spikes that is also responsible for suddenly increasing the volume. Best is to put a voltage stablizer
Jan 22, 2010 | Televison & Video
Sound volume fluctuates
sounnd like your power supply
check you cap,s in power boulg cap.s
Aug 12, 2009 | Polaroid FLM-2632 Television
Got t7900`
I have had that problem with a T7700/T7900 speaker system.
Disconnect the remote control from the subwoofer. Then what you need to do is unscrew the remote volume/bass control unit (4 little screws). Swab the contacts on the volume dial with a cotton bud (q tip) denaturated alcohol or even perfume will work. Make sure you do it several times until all the slight dirt that is causing the volume fluctuation/spikes to happen. Also remove any remnants of cotton that might get stuck.Now you'll have it working as new as long do not cause any other damage to the unit.
Cheers,
Daniel
Jul 02, 2008 | Creative Labs Inspire T7900 Computer...
Loud popping and decrease in volume
I'm guessing power supply problems fluctuating, or main control board.
Apr 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Cambridge Soundworks CD-740 Clock Radio Logo
57 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
