Question about Kenmore Side by Side Refrigerator
Where can I find a kenmore refrigerator manual model number 106.52554100
abhishek33
  • 1239 Answers
SOURCE: Kenmore Bottom Freezer Refrigerator
hi In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary.
Posted on Nov 06, 2008
SOURCE: kenmore refrigerator model 106, 2doors, ice forms
I had the same problem and discovered that the water control valve was not shutting off completely between cycles. The water seeping through the valve was freezing in the water inlet tube. I replaced the water control valve for the icemaker and solved the problem.
Posted on Mar 02, 2009
arikrom
  • 528 Answers
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Posted on Dec 30, 2009
livewire874
  • 618 Answers
SOURCE: Need a manual for the
Try this site http://www.manualsonline.com
Posted on Dec 03, 2010
SOURCE: kenmore coldspot model 106: top freezer leaks
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Posted on Dec 19, 2010
I have a Kenmore/LG Fridge that leaks - does anyone know where I might find a service manual?
Good luck on finding a service manual but providing your Kenmore Model number will help me provide the help you may need to resolve the leak problem. A Kenmore sold LG model number begins with 795. I also need those number after the 795.xxxxxxx A description of the leak problem would also help
APPLIANCE911
Apr 16, 2016 | Refrigerators
Kenmore Elite 106.54609300 What are the exterior dimensions? H,W,D I need to replace with a similar sized refrigerator in an enclosed spot. Can't find this info anywhere.
This is not credible request: Manuals are available from SEARS...
Use your measuring tape... and then go to the MANUAL and add the required clearances
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/user-manuals/manual-downloads/Model-10654609300/0582/0165000?modelNumber=10654609300&diagramPageId=&documentId=26037129
STRAIGHT FROM THE OWNERS PDF
Door ...
shipping dimensions... seriously!
Part Information
This manufacturer-approved door assembly (part number L2255526LJ) is for refrigerators, including Kenmore refrigerator model 10654602300.
Unplug the refrigerator to disconnect electrical power before installing the new door assembly.
Follow the instructions in your owner's manual or installation guide to remove the existing door and install the new door assembly L2255526LJ
This Refrigerator Door Assembly part #L2255526LJ is guaranteed to fit your KENMORE REFRIGERATOR #10654609300
Door shipping Specifications
  • Category: Refrigerators and Freezers
  • Shipping Length: 77 in
  • Shipping Width: 28 in
  • Shipping Height: 13 in
  • Shipping Weight: 45 lbs
for questions or assistance, call 1-800-733-1381
M-F 6:30 a.m. - 10:30 p.m. CT
Sat 7:00 a.m. - 9:30 p.m. CT
Sun 7:30 a.m. - 9:30 p.m. CT
(Se Habla Espa?ol)
Jan 03, 2016 | Kenmore Refrigerators
How do I life the refrigerator door up? It is not closing.
Find your user manual at this site. Model number is longer look at diagram to locate the model number.
Parts for Brands Craftsman GE Kenmore Whirlpool and more
Oct 30, 2014 | Kenmore Refrigerators
Can I view a manuel for Kenmore Refrigerator online?
If you have the model number, you can download the manual at searspartsdirect.com. However, it won't have the mfg date. User Manual Downloads
Oct 04, 2014 | Kenmore Refrigerators
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
Red light on to replace water filter, how to do this?
Knowing just who made your Kenmore refrigerator may some day be important because Kenmore does not make the brands they sell. I am going to try to get you as many different ways the water filter can be changed as I can but if you can you locate the model number of your Kenmore it may make things much easier should you need parts or a manual some day. The number should look like this 521.345678 and located around the inside of the fresh food section door.
Here nis what I have found on different models and water filters from Whirlpool How to Replace In-Grille Refrigerator Water Filter - Push Button
How to Change the Water Filter in Your Refrigerator
Whirlpool Part UKF7003
How to Change a Kitchen Aid Refrigerator Water Filter
Read more:
If by chance you are able to find your model number that looks like the 513.235647 I mentioned before this will solve just what instructions you need or you can post a photo here or swend one to my email appliancepartsse (@) yahoo.com and I will be glad to help you get a manual and instructions for changing your water filter, Thanks Sea Breeze
How to Replace Interior Refrigerator (Filter1) Water Filter
Jun 25, 2012 | Kenmore Side by Side Refrigerator
Need Owner manual refrigerator... number: 106-62262101
I am not sure you got your model number 100 % correct.
See this page:
http://www.managemylife.com/mmh/owner_manuals/search?query=106.62
Find the model number closet to your model number and download the manual.
Thanks for choosing FixYa,
Kelly
Jul 03, 2011 | Kenmore Refrigerators
Need owner manuel how can i get one?
you can get a free manual at : http://kitchen.manualsonline.com
move down to refrigerators and then type in your model number and it will be there.
c...
Feb 19, 2011 | Kenmore Refrigerators
Kenmore Side by Side Refrigerator Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
