Question about Thermador Ovens
Where is the reset button on a thermador sc301tp oven
3 Suggested Answers
  • 24 Answers
SOURCE: looking for the repair & users manuals for my
Hello cfrisz,
I am new to the fixya and I saw that you were looking for a manual. I hope that this information can help you find one if you still are looking.
At this web they have a similar users manual or if you type in model (if there is another number on oven) number maybe they'll have it.
http://outdoorcooking.manualsonline.com/search.html?q=Thermador+SC301tp&submit.x=25&submit.y=28
or here is the main website (you might have tried it already)
http://www.thermador.com
in the contact us section there is a form to fill out and maybe you can get one that way. I'm not sure on response time. Most company's do not mind giving people replacement manuals.
hope this helps
Posted on Aug 04, 2009
Macmarkus
  • 2605 Answers
SOURCE: Thermador single convection oven, SC301TP has inop
Welcome to FixYa.
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available.
You can find these "display kits" at "repairclinic.com" for around $275USD and includes what I've attached here...
**Your other option, and the one I recommend, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
Here you'll find all the info pertaining to this option by clicking on the link I've provided below
http://www.corecentricsolutions.com/CCSWeb.nsf/published/bosch
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Posted on Dec 29, 2010
I have a Thermador Model SC301TP wall oven. When I try to Self Clean I get error F2 which I think is that it is a tempature issue. What should I do?
either the oven sensor is bad or see if the pins where it connects on the relay board have bad solder joints. re-solder first, then replace if needed.
Jan 18, 2015 | Thermador Ovens
Thermadore oven won't heat
Have you set the clock?
warmest regards
Richard The Repairman
Mar 27, 2014 | Thermador Ovens
Thermador Model SC301TP display panel stopped working
bad condenser on the display board. The display has to be replaced.
Nov 10, 2013 | Thermador SC302T Electric Double Oven
Thermador single convection oven, SC301TP has inop LED panel. Dim, then blank. Solutions? I have Googled this complaint, and find many irate owners stating this is a common problem. Is there an LED panel...
Welcome to FixYa.
Regards,
Macmarkus :)
Dec 29, 2010 | Thermador SC302T Electric Double Oven
Is there a reset for the oven in a thermador smw? I had it worked on years ago and the repai guy simply pressed a button and all was well...also is there a source for control panels, since mine is almost...
Never use Self-Cleaning!!! It will fry components, melt connectors, and burn wires. If you have violated this rule and an oven no longer works, it is probably not a bad element if neither the bake nor the broil work. It is likely the high heat cut out breaker.
On a Thermador CT 227 double oven, there is a panel on the right side (facing the unit) that is about 3 inches wide and runs from top to bottom held in place by about 6 or 8 screws. Turn off the power, slide the unit out of the kitchen cabinet, remove the sheet metal panel and you will see two high heat cut out breakers. They have a small red button in the center that resets the breaker. Push firmly and you should hear a click. If there is no click, check the unit for continuity. If it is open and the button push does not reset it, the unit may be fried. These breakers trip with high heat and will prevent both elements in an oven from heating. If the breaker is good, you'll have to test the leads to each element and then trace the dead lead to the problem.
Dec 27, 2010 | Thermador SMW272 Electric Double Oven
After self cleaning my Thermador double oven, it does not heat up anymore The elements are not working. Is there a fuse, switch or something that I can do or check to make it heat up again.
Aug 01, 2010 | Thermador SC272T Electric Double Oven
Thermador SC302T won't reach temp (stuck at 100 degrees)
Sounds like you have a real POS on your hands. I would chuck it and get another unit rather than waste any more time and money on this Thermador.
Jun 20, 2017 | Thermador SC302T Electric Double Oven
Thermador oven display fc
Try turning off your circuit breaker for a few minutes. Then, after you reset it, push clear, then set your clock.
Sep 11, 2009 | Thermador SMW272 Electric Double Oven
Looking for the repair & users manuals for my thermadore wall oven sc301tp
Hello cfrisz,
hope this helps
Mar 07, 2009 | Thermador C302U Electric Double Oven
Thermador SEC301BPSS Electric Single "service Message"
Sometimes, you can reset the panel by turning off the circuit breakers. Look for a linked pair of 40-50 amperes. Turn them off then on. If this doesn't fix it, you will need to change the circuit board...first things first, though.
Dec 21, 2007 | Thermador SEC301BPSS Electric Single Oven
Ovens Logo
211 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
