Question about Sony Playstation 3 (PS3) Console
PS3 Nothing..No Power Light.. Nothing
I've recently found my PS3 Dead in the living roon.. No indication that its getting power, although I know its being fed power from the cord. I've never cracked open a PS3 before, but willing at this point since its out of warranty & Sony is willing to fix it for $150 (including S&H) regardless of its condition. So, I don't need to worry about voiding any warranty by breaking the seal. I would appreciate anyones input on this.. Maybe its just a replaceable fuse?
Mike
Gainesville, FL
  • Houdin8888 Oct 27, 2008
    I decided to send the unit out as I found myself so inept that I couldn't find the way to open it up to look for a fuse (if one existed). Thanks for trying!
    Mike
    Gainesville, FL
    Novelist:
  • 111 Answers
Hi there, by the sounds of it you could have faulty fuses, Whether its inside the console itself or inside the Power adaptor its Uncertain. Before opening up Your PS3 i would suggest Checking the fuse in the power adaptor to make sure that is not fried. if it isnt. then it must be something to do with the power input to your PS3 Device. it could be either the Fuse or The transistors on the Power input Circuit. When you Pop open your PS3, Go straight to the back-end where the power input is located, and see if any of the fuses or transistors look fried, if they are. then that is where your fault lies !
Posted on Oct 27, 2008
No power appears to be coming in....no connection when door is closed; no lights come on on any of the cycle indicators...deader than a doornail@l
Hello. I need the make/model number to help you most accurately. From the symptom you describe, there might be a main fuse located on or near the main control board which has opened, killing power to the unit. Clues: totally dead--no lights--an open door will not affect indicator lights, the unit won't do anything though--safety(nothing will happen until the door is closed) Have you had a power outage recently? Usually 3-4 weeks after an outage, the damaged chips on the boards start to fail. This can be evidenced by blown control panels, blown main boards, etc. Make sure 120 volts *is* getting to the dishwasher--check the power connections below(be careful). If the breaker has tripped, reset it and see if the unit runs. Troubleshooting starts from the outside and proceeds inward, eliminating the obvious and moving to ever more complex problems until the culprit is found. Definitely supply me with that model number so I can see what I'm dealing with and guide you correctly. Thanks!
Oct 17, 2015 | Dishwashers
Its dead, no power indicators, doesnt beep, its dead ?
unless your wall socket or the fuse in your lead has blown, the only other thing I would suggest would be the PSU.
If you search PS3 PSU replacement you should find a video guide how to do so
of course when it comes down to weather it would be worth it that is entirely up to you the average cost is about 20 to 50 depending where you get it from.
Dec 12, 2013 | Sony Playstation 3 (PS3) Console
Dead set (no indication lights coming on when I push the power button.
Hi Gwendolyn,
First of all thank you for posting your question here at Fixya.
I'm assuming here that you're TV is a Vizio L32 HDTV.
My initial advice is to ensure that the AC source(outlet) is live. Please plug the unit to a known working outlet, if you are using a surge protector, directly plug the power cord of the TV to the outlet to confirm that the AC source is not the issue here.
If you've confirmed that the AC source is not the problem, then the fault is inside the TV and most likely the power supply. Most of the TV with a dead set symptoms that I've encountered is a power supply issue but of course needs to be confirm.
If your unit is not under warranty period (if so, avail it because the manufacturer will fix it for free, opening the rear cover will void the warranty), open the back cover, check the internal fuse of the power supply board, this is near where the AC power cord's directly connected. Check its continuity using the multimeter/ohmmeter, if you found it open, replaced it with a new same current rating that is printed on its body itself. Sometimes internal fuse fail due to voltage surge/flactuation, aging, etc, replacing with new one resolve the issue, however if the fuse blow again, this is an indication of more serious problem on the power supply board, it needs to replaced the entire board.
If the fuse is intact, you have to measure the output voltage of it through connector J1 (pin 9,10,11). You should be getting 5 Volts. If there's no voltage at these pin, you're power supply board is dead, replaced the entire board. If the 5 volts is present, replaced the main board.
I've provided you a links for the power supply board and mainboard below.
Vizio L32 Power supply board
Vizio L32 Mainboard
Let me know if you need further assistance.
Rating and feedback are highly appreciated!
Hope I helped you.
Good luck and take care!
Have a nice day!
Kind Regards,
Jdvillanueva
Dec 13, 2011 | Vizio L32 32 in. LCD HDTV
Playstation 3 wont work it gets to the wavy screen a message says the PS3 was not turner off properly' then i try to restart but nothing happens just a blank screen? Help
Hello
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
I wish you good luck.
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
Television will not stay on. The indicator light
first you have to open the back cover of the television to check for bulged capacitors,if found replace with the same number, but if otherwise
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helps....
Jun 07, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Wont turn on at all. no red, yellow or green light. nothing. Is it dead?
This is pretty indicative of a "Blown" Power Supply. First though check all connections IN. This is a common problem. Usually simply fixed by PSU replacement.
Feb 12, 2010 | Sony Playstation 3 (PS3) Console
Console wont turn on has blinking red light wont stayed powered on and can't get game out
I'm sorry to say this but the blinking red light is = the light of Doom. Your PS3 is dead. This is somewhat like the XBOX Red ring of death.Yellow lights and blinking red lights indicates general hardware failure on ps3. If your ps3 is still under warranty call Sony and they will send you a new or refurbshed one. Your ps3 is one in a billion (according to Sony).
North America: 1-800-345-SONY (7669) United Kingdom: 08705 998877
Now you could try doing a few things (hey it's worth a try!)
1. Turn off the switch in the back and wait a few minutes. Turn it back on and try it again. If that doesn't work it may be dead.
2. You could try this article, if you choose to, it's a long shot but might work for you in your case. http://ps3.qj.net/Possible-PS3-flashing-red-light-fix-from-MXACE/pg/49/aid/75721
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont power up
try powering the system up by HOLDING the on;off button , it will reset all your audio and video settings . then plug the system using the AV cables (default) .
else, you should take it to an assastance centre for hardware issues checking . can be a problem with your RAM or GPU units that makes the system unable to startup it's firmware .
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
214 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
