Question about Bosch Axxis WTA 3510 Electric Dryer
Frigidaire fde336res1 The dryer is not heating and the back panel is turning brown. When I opened the dryer door to take clothes out, I saw sparks.
  • Bosch Master
  • 19,396 Answers
Unplug power immediately.
Check the fuses/circuit breaker at the back of the appliance.
You may need to have the heating element inside the machine tested, and eventually replaced, it had probably shorted out.
You can call a technician using the number listed on the owner manual.
You can get replacements here.
Posted on Oct 27, 2008
Dryer not drying
Hello Tony Palow - Have you recently cleaned the ducting? Confirm that it doesn't have any debris or build up. Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if the unit still does not dry, I would recommend contacting a professional to proceed further since it could be any one of several underlying causes. Most than likely the dryer has a faulty control board, heating element, blower assembly, thermostat, sensor or damaged cord.
Mar 18, 2013 | Frigidaire Electric Dryer
Were is the thermal fuse located on the frigidaire fde336res1
It is located on the rear bulkhead upper right hand corner. Ti access it you pop the top with a putty knife and remove the front panel. Get the drum out. I recently worked on one and did a video:
The smaller disk is the fuse. If blown the dryer will not run
Jul 07, 2012 | Frigidaire Dryers
Affinity aeq6000es2. After two cycles of the
sounds like your heating element opened up,as it was running and when the element broke it arced and these were the sparks you saw,you will need a new heater element
Jul 19, 2010 | Frigidaire Dryers
Clothes caught between drum and top of front panel: Frigidaire
You have a bad tub seal. It is glues onto the front panel...looks like a thick felt pad. Common thing on Frigidaire dryers.
May 21, 2010 | Dryers
Noise in dryer Frigidaire model fde336res1 when running
Could be the drum bearings are worn. These are what the dryer drum turns on and when they wear out the drum and frame rub together (metal to metal). Also could be the belt idler which keps the belt tight around the drum. In either case the dryer would have to be internally accessed to determine failure.
Feb 17, 2010 | Dryers
Model FDE336RES1. Is drying very hot only. Even
sounds like your hi-limit switch (contacts welded themselves)if its as hot as you say it is and wont shut off heat.or the clothes setting temp sensor is faulty
Jul 29, 2009 | Dryers
Drum making intermittent sqeaky noise for 3-4 minutes then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Jun 03, 2009 | Frigidaire Electric Dryer
Door switch isn't working
Hi, Is the switch a two or three wire?
Please let me know so I can try and assist you.
May 24, 2009 | Frigidaire FDE336RE Dryer
Our 2-year old Frigidair dryer, Model # GLER341A was working fine-I removed the dry clothes, put in the next load, turned it on and it sounded like a load of chains was in it.. When I opened the door...
could be rear drum bearing. possible heat element broke and is rubbing on back of drum those light you say you saw was probably your heat element arcking on the metal in other words sparking
Jan 12, 2009 | Frigidaire GLER341A Electric Dryer
Brown streaks on clothes
mich, The brown streaks are probably caused by worn drum guides and lower basket seal. I've seen this quite often on Frigidaire dryers. Part numbers 5303937139 upper felt guide and 5303283286 lower basket seal. This can be a task for an inexperienced person but can be done. It requires removing the top panel and front panel/door assy. The old guides have to be scraped off. The upper felt guides and lower seal glue on. back.
Nov 19, 2006 | Frigidaire GLEQ642A Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
166 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
