Question about Acer Computers & Internet
Battery will not recharge for travelmate 533XC. Are there some settings to restart the charging process?
    Champion:
    Scholar:
  • 209 Answers
I guess not. You will have to replace it. Mine last about 2 years, before it stopped recharging completely.
Posted on Oct 28, 2008
I'm one of many who have had problems with the battery exhausted signal one gets with Nikon cameras, even sometimes with freshly charged batteries.
Yes. It sure could have caused the problem. You didn't say which Nikon camera you have, so consider this a general answer. NMH (Nickel Metal Hydride) batteries are rechargeable and alkaline batteries are not. When your camera is set for rechargeable, the recharging circuit is activated when your camera is plugged into the wall outlet. When the camera is set to alkaline, the charging circuit is disabled. Therefore, if you had the camera set to alkaline and you used rechargeable batteries, you batteries were never getting charged. Since your NMH batteries were in a discharged state, your camera gave you correct information.
Jan 01, 2017 | Nikon Cameras
Do all the Acer Travelmate 240 series laptops use the same rechargable battery
This high capacity rechargeable Acre Travel Mate 240 replacement battery definitely disposes of more power than the battery which was included in the delivery of your device.This laptop battery for Travel Mate 240 is 100% compatible and will meet or exceeds original specification.Made with premium quality cells,the Ac er laptop battery for Travel Mate 240 has been tested for safety and designed for high performance
Dec 24, 2012 | Acer TravelMate 244XC Notebook
Hi sir/mam, this is revanth and am using nokia e5 phone from 1year and i updated my handset with nokia pc suite,, after one week my phone is getting switched off when i get a incoming call and doing out...
Updating cell phones does drains battery during the process espercially when not fully charged before the process . Get a new battery from an authorized Nokia vendor charge not more than 4 hours and see what happens.
Note: the new firmware am sure had an issue reading the right battery level state it is nothing much of a big deal.
All the best.
May 25, 2012 | Nokia Cell Phones
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
Jun 16, 2011 | Acer TravelMate 2480 PC Notebook
Hi I have an Acer Travelmate 6492 first I wanted to reset it to factory settings I could not manage that & now it is not booting it's just flashing on top
Seems like your hard disk is not getting detected.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Start tapping the DEL key as soon as you power on the computer.
This will take you to the BIOS screen.
If it doesn't, you will have to check whether your hard disk is faulty with a local technician.
Once you get in to the BIOS screen, press F9 to load the default settings.
Than press F10 to save and exit.
Once you do this, the computer will restart.
Hope this helps.
Dec 21, 2010 | Acer TravelMate C112TCi-SP2 Tablet PC
Battery will not charge. Black box (on wire which connects to mains - sorry not good with techno!) light is on. Acer Travelmate 2480 laptop. Quite old I think, got it second hand. Does it just need a new...
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 04, 2010 | Acer TravelMate 2480 PC Notebook
Sorry but does the dw911 xe type 1 radio charge the battery
Yes, the DeWalt radio will recharge the batteries, from the 12 Volt to 18 Volt versions. However, even with the radio plugged into an AC outlet, you have to either have the radio turned on, or have the unit in the AUX setting, in order for the batteries to get charged.
It typicaly takes about an hour +/- to fully charge a discharged battery. I normally don't put batteries directly into a charger right after they become discharged from being used in a tool, since they are still warm from use and charging them will generate more heat in the recharging
process.
Heat is the enemy of rechargeable batteries, so to get the longest working life out of your batteries, I'd let them cool down first, before recharging them, unless you absolutely need to use them right away, then go ahead and recharge them. If you can delay recharging them until they've cooled down, you'll get a more fuller recharge out of them.
Hope you find this Very Helpful and best regards!
Sep 30, 2009 | Dewalt Drills
Laptop battery won't stay charge, need battery relearning instruc
This process will take a lot of time and money, its better to buy new battery.
Apr 23, 2009 | Dell Inspiron 9300 Notebook
255w in a loop - loading maps, then restarts...can't recharge
Use a USB connection to your computer and let it charge for three hours. Also download updates while your at it. Cigarette lighter charger is not efficient
Dec 20, 2008 | Garmin nuvi 255W GPS Receiver
Computers & Internet Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
