My epson sx440 series printer will not print wirelessly
My EPSON SX440 series printer will not print using the wireless facility. My laptop will connect to the printer, but it will not print the document. I've tried plugging my laptop into the printer and my document prints first time. I feel that the problem is with the wireless connection?
SOURCE: Epson r300 printer
step1..............switch on
step2............press+hold stop,ink,power buttons untill printer switches self of
step3............switch back on and problems should have gone
Posted on Jan 13, 2008
SOURCE: Epson rx 500 "service required"
Press on off, load expulsion, byw,color and stop all at the same time, wait until it is on. then press color and then shut down.
Posted on Jun 25, 2008
SOURCE: Poor print quality of pdf documents on Epson LX-300
PDFs are designed to print using Postscript language.
The problem will occur with any non-Postscript printer. You can get better results on Windows printers by clicking on the "Advanced' button in the Print dialogue window. Then check 'Print as Image'.
This has worked well for me.
Posted on Feb 20, 2009
  • 700 Answers
SOURCE: my r230 photo printer epson stylus was sevice required unable to print and see your printer documents
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
Posted on Apr 17, 2009
  • 133 Answers
SOURCE: Cannot print documents wirelessley from SX515W
in vista as with windows 7 you must tell the computer to connect to your printer in network preferences. It wont work untill it is told to connect!
Posted on Jan 01, 2010
Need service manual for panasonic sx440
1. You posted under "AIR CONDITIONERS"
2. Are you sure it's a Panasonic and not a Pioneer?
3. If it's a Pioneer sx440 you might find it
http://www.eserviceinfo.com/downloadsm/16439/Pioneer_SX-440.html
Mar 14, 2014 | Amana PTH123B25AJ Heat Pump Air...
I have a epson L110 series printer , i am using it through usb port , how can i change it to online
Do you mean wireless?
Both nodes (pc and printer) need to be online (wireless network). Then install the printer by IP, or unique DNS name to PC. Print as normal by choosing wireless printer from app.
Nov 22, 2012 | Epson Stylus C110 Series
Make Epson Photo RX620 print wirelessly
This model printer has only an USB connection.
It is possible to print wireless by connecting the printer to your computer and sharing your printer on your network that is connected to a wireless router.
OR connecting your printer to a wireless router that has an USB port for connecting a printer.
Aug 04, 2012 | Epson RX620 All-In-One InkJet Photo...
Hi there...wonder if you can help answer this question I have with my printer Epson SX440. We have it for over 2 yrs now though hardly used it has started to give poor quality print the past week when we...
Hi .
I am assuming when you say your printer has hardly been used over two yearsthat you never changed the ink cartridges.
If my memory serves me right Epson inks have a shelf life before drying out or the heads on the carts clog and this causes what you describe...
To Test this
Go into CONTROL PANEL...>....PRINTERS and FAXES.......There you will see your installed printer
Epson SX440 ..>.. Right click on your printer Icon, and then left click PROPERTIES
.This should bring up a dialogue box with 5 or 6 tabs...The default open tab should be General....Look near the bottom of the open box and you should see a button with PRINTING PREFERENCES.Click this box.
You should now see 3 Tabs in a new pop_up box. The one you are looking for is maintenance . click this tab.
You should now be in the right area to check for problems 1st. start the Status Monitor ,this will show you ink levels and display them for you.If these look okay try the nozzle check utility. This will print a series of lines on paper for you to check against an onscreen image..
If there are problems ,run the Head Cleaning utility. This will run the print head back and forth over a cleaning pad in the printer..After one or two of the cycles run the nozzle check again .
This sounds like a long drawn out process but i can assure you it is very simple as the software does the work, just follow the onscreen instructions and you won`t go wrong.
NOTE: due to age and lack of use of the printer I would advise you get a new set of inks ,Compatible inks are not expensive on ebay and other online stores.
Hope this helps and if there are any more problems just do a follow up post
Nov 05, 2010 | Epson NX400/SX400/TX400
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
Trying to connect new laptop wirelessly to Epson Workforce 600
You need a wireless router and then follow the directions that came with the printer.
Jul 13, 2009 | Epson WorkForce 600 All-In-One InkJet...
Wireless printing
To initialise an Epson R300 and Draytek router I have to turn:
Router off
Printer off
Printer on
Router on
This may work with your setup
May 14, 2008 | Epson Stylus Photo R300 InkJet Printer
1,498 people viewed this question
jasbo
jasbo
