Question about Sony Ericsson K510i Cellular Phone
Joystick will only move up or left on the screen
My K510i joystick will only move up or left on the phone's screen. There does not appear to be anything in Settings which will resolve this other than reset to factory settings. I am reluctant to do this as it warns Imay lose data that was on the phone when I bought it.
Any ideas?
Andy
Remove the back panel, remove the battery, and put the battery back in again. No data's lost. Just done it and it works.
Posted on Nov 19, 2008
Damages joy stick, cannot move up, down, left and right
Most of the time joystick problem can be corrected by :-
-put some servicing liquid like petrol on joystick area and move your joystick up dpwn left right
then dry your board .
- most of the time this problem will be solved by this process. if not then change your joystick
Oct 20, 2010 | Sony Ericsson K700
Tip
Sony ericsson secret tips
Sony Ericsson Secret Menu:
> means press joystick or arrow keys to right
< means press joystick or arrow keys to left
1. push joy stick to RIGHT once
2. press *
3. push joy stick to LEFT twice
4. press *
5. push joy stick to LEFT once
6. press *
The Service Menu will appears containing following information !
1. Service Info
a. Software Version
b. SIMlock
c. Configuration
2. Service Setting
a. Contrast
3. Service Test
a. Display
b. LED/Illumination - *This test is very cool
c. Keyboard
d. Buzzer
e. ********
f. Earphone
g. Microphone
h. Real Time Clock
i. Joystick Counter*
Lockstatus: < * * <
Shortcut to last dialed numbers: 0#
Shortcut to sim numbers: On main menu type a number and press #
If you change the language from default to any other language, then it may be difficult to switch to default language.
The shortcut is very simple. Just press < 0000 >
< stands for left arrow button or joystick and > stands for right arrow button or joystick.
Secret Games: Snake on the T68
Go to Erix and then on the main screen press 123 and you will be taken to the game.
Secret Message:
On Tetris on the main screen when the blocks are falling press 397 and a message will appear.
on Mar 08, 2010 | Cell Phones
Joystick
It's a known complaint in SE K510i. Get checked it in a nearest Sony Ericsson Service center. It may costs around $2 - $4 if not under warranty.
Mar 05, 2010 | Cell Phones
I need calibration software for the logitec 3d pro joystick. will not maintain level flight in AP (flight sim ).
this was not originaly my post but i saved it.and it worked for me. HOW TO CALIBRATE THE LOGITECH EXTREME 3D PRO JOYSTICK
I just figured out how to calibrate this joystick. I am using Windows XP. I assume it will work with all Windows operarting systems though.
Go to Control Panel, click on "Game Controllers", or however you get to your joystick settings. Hold down the "Ctrl" (control key) and the "Shift" key together - at the same time, THEN click your mouse on the "Properties". This should take you to a different calibration screen that you would get to without holding the two keys together. IMPORTANT - Click on the "Test" tab first. If you go to the settings tab first, it likely will not work. Without doing anything else after clicking on the "Test" tab, next click on the "Settings" tab. Then click on the "Calibrate" button below. Click "next". Click the thumb button on the left side of the joystick which should bring you to another screen. Then follow the prompts......
* On the "axis calibration", move your joystick in full circles, making sure the "+" symbol moves around the far margins of the square. After a few complete circles, click the "next" button with your mouse.
* On the next screen, click the left button on the joystick again, which should bring you to the next screen. Move the throttle lever back and forth a few times. Then click "next" again.
* On the "Z rotation screen", move the joystick to the left and right (rotate it) a few times. Then click "next" and then "finish" then "ok". Thats it. It should be calibrated now. Hope this helps everyone with problems.
Feb 08, 2010 | Logitech Extreme 3D Pro Joystick
MASTER RESET CODES FOR SONY ERICSSON
Here are the Master Reset codes for your phone.
Master Reset / Codes
Accessing the Service Menu - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key.
Checking Firmware Version - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key, press 1 key twice.
Show IMEI # - press * key, press # key, press 0 key, press 6 key, press # key
Manual brightness adjustment - While in camera mode, press and hold * key and move joystick to lower brightness, press and hold 0 key and move joystick to increase brightness
Quick ScreenSaver - Pressing # and * at the same time
Show screensaver and lock keypad - press * and lock keys
*#0000# - Reset language back to english
Hard Reset -Hold power for 10 seconds
May 28, 2009 | Samsung SGH-D500 Cellular Phone
My sony erricson k750i phone's joystick is not responding
you have to clean the joystick by using contact cleaner. open the cover of joy stick, there is a switch inside it having a metallic cover. use contact cleaner and let it for few minutes.
DONT FORGET TO REMOVE LCD FIRST. it can be damage with contact cleaner. i had a bad experience of it.
btw it happens with sony ericsson phone joystick problem.if joystick problem still persist u have to show it to sony ericsson repair centre or your warranty center of mobile.and u can also use the keys your keypad keys for up down left right.
thankyou.
May 06, 2009 | Sony Ericsson K510i Cellular Phone
Left side and upe side joystick not working
yeah it happen with sony ericsson phone joystick problem.u have joystick problem u have to show it to sony ericsson repair centre or your warranty center of mobile.and u can also use the keys your keypad keys for up down left right.thanks
Apr 27, 2009 | Sony Ericsson K510i Cellular Phone
Sony Ericsson K510i joystick
This is the common problem of a joystick is need to replaced including the keypad and also clean the board ,so it will works better again.
Hope thismay help you;
Regards,
VOTIT
Oct 07, 2008 | Sony Ericsson K510i Cellular Phone
K510i Joystick
you have to clean it by using contact cleaner. open the cover of joy stick, there is a switch inside it having a metallic cover. use contact cleaner and let it for few minutes.
Mar 09, 2008 | Sony Ericsson K510i Cellular Phone
Sony Ericsson K510i Cellular Phone Logo
122 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
