Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
Poulan pro pp125 pull cord - Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
5 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: how do i replace i pull cord on Poulan 031 Pro ?
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the bottom of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or something so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place. Reassemble and you are done. Disassembly requires Torx head drivers ranging from T-15 to T-25
Posted on Oct 05, 2010
2strokeguy
  • 183 Answers
SOURCE: Hi I am looking for part list, for this model.
www.ordertree.com has illustrated parts list for your PoulanPro125. It will be helpful to know if it is a type 1 ortype 2. That info is located on the black and silver sticker. At the end of the serial number will be a "-1" or a "-2". That is your type.
Posted on Aug 30, 2010
  • 4339 Answers
SOURCE: how do i replace a pull cord on poulan 031 pro
This is a tricky job, you have to extract the assembly, remove all old cord, wind the spring and pulley fully, and back off a turn or so, lock the pulley, install the new cord, release the pulley and it will wind in the new cord. reinstall starter assembly.
Try to resist handling the spring, they are messy, uncooperative and hard to reinstall.
#1 Taper
  • 1040 Answers
SOURCE: Poulan Pro Pp125 25cc Gas Straight Shaft
Here is my Tip(s) on this problem:http://www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
Jim
Posted on Aug 14, 2011
Poulan trimmer drive shaft attachment problem
Square drive on the end of the drive shaft has to line up with the drive on the output of the clutch.
Jul 07, 2014 | Poulan Pro Pp125 25cc Gas Straight Shaft...
My poulan pro trimmer has no nut on the head to remove it. it has a screw inside. how do i work that. the screwdriver wont hold it.
See page 13 of your manual here for removing the head. Please realize that the head has LEFT_HANDED threads on it (not the conventional R-handed) so you have to turn it to the RIGHT to loosen and remove it.
http://dl.owneriq.net/0/025d5114-7fc1-41e0-8faa-5205f15e8cf5.pdf
Aug 07, 2011 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Fuel mixture for poulan pro heavy duty brushcutter 331 sn 01254n500330-1is needed asap. lost my manual!!!!!
40:1 mix, 3.2 oz of 2 stroke oil for every gallon of gas.
Link to the manual is below
http://www.poulanpro.com/ddoc/POUO/POUO2001_USen/POUO2001_USen__530088910.pdf
May 27, 2011 | Poulan Pro Pp125 25cc Gas Straight Shaft...
I have (had) the Poulan Pro 25 cc trimmer. The motor and main shaft have been nothing but problems for me. I still have the attachments. Do you know if there is a way just to buy the main shaft/motor? ...
Sure you can...that would be called the crankshaft assembly. You can find it here...along with any other parts you may wish/need. These low-end trimmers are practically considered disposable household items nowadays and a lot of people treat them as such. Look for the crankshaft assembly here:
http://www.ereplacementparts.com/poulan-pro-pp125-gas-trimmer-parts-c-16962_17820_18351.html
I am a little surprised at the lower cost.
Sep 14, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Hi I am looking for part list, for this model. Poulan pro pp125
Aug 30, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
New poulan pro will not start
when I bought mine. The weed eater didn't start right away so I took it back where I bought it and I had them look over it. when reading the manuel It said that it might not start right away becuse the fuel mixture needs to be adjusted on the pro prolan pp125 weed eated. so we utilized what we had around us and found a tube. adjusted it and it started right up.
May 22, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
676 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
