Question about Ibico Office Equipment & Supplies
Ibico laminator ML-9 - - do you need a sleeve for the small (government id laminating pouches) to go into for laminating
3 Suggested Answers
  • 6 Answers
SOURCE: the unit was heated up
Hi, there's a seperate switch for the moter on my laminator. After the device is heated up you need to turn on the switch, so the mechanism starts to pull in the pouch.
Posted on Mar 18, 2011
edy_bubat
  • 259 Answers
SOURCE: what do you use to
use compound rubber or material as same as body car cleaner.
Posted on May 12, 2011
Do I insert the printed paper into clear pouch & just put these 2 items into Smith Corona Laminator LX900? Do I need a heavy paper protector to surround these 2 items? How do I order a protector?
use what is called laminating pouches
you put what you want laminated in the pouch, centre it so that the edges all have the same space, wait until the green light on the laminator appears and enter the pouch with the folded end in first.
It will slowly move through and seal off as it goes
make sure that the pouch is entered square to the rollers or it will crease the finished product or jam the laminator
there is no need for any additional equipment
Jan 08, 2017 | Office Equipment & Supplies
How do I get something out of that the laminator ate?
You can't do any more laminating until you do. Some laminators have to be used with a document carrier and some don't. It sounds like yours does need one. This happened to me once. You have to remove the screws on the bottom, lift off the top and you will find your document and laminate pouch wrapped around the roller. Using a sharp paring knife or nail scissors, cut the pouch along one side making sure not to damage the ceramic roller. I have a recollection that I cut the pouch away on both sides. I used a chef's boning knife as this was at work in an airport business class lounge.
Oct 12, 2016 | Apache Al18p 18 Professional Laminator
Fellowes laminator
Plz try the "Jam free" lever located on the top LEFT of the laminator. You ca try to feed another film in....hoping it will force the pouch out. Otherwise, you will have to take the cover off and unroll the pouch from the inside rollers. Good luck!
Aug 20, 2014 | Fellowes Saturn2 125 Laminator
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
Some one at work tried to laminate a card. when it did not come out she put in another sleeve thinking it would push the other out. smart uh! how do we get the 2 pages out?
If you were using GBC brand laminating pouches they don't need a carrier, if you were using another brand of laminating pouches, then a carrier is needed (something they don't clearly specify) and that's why the laminating pouch got stuck.
If you have had the laminator under a year, it should be under warranty, and you can call the company, and they will send a replacement, and they will probably then inform you of the above listed laminating pouch issue.
You may also want to try using the reverse button, but many times the pouches will get stuck between several rollers, and you risk destruction of the entire machine by attempting to take them out manually.
May 31, 2011 | Gbc HeatSeal H425 Laminator
The unit was heated up and when I insert the laminator pouch with the document to be laminated it does not feed. it just cooks the front edge of the pouch. do I need to let the unit cool and start...
Mar 14, 2011 | Xerox Staples XRX LM1910 Laminator
Ibico 2700 laminator
I need to replace the rollers on my IBICO 2700 laminator. I will need to order the new rollers can you help?
Apr 24, 2008 | Office Equipment & Supplies
241 people viewed this question
Top Ibico Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Ibico Office Equipment and Supply Expert? Answer questions, earn points and help others
