Question about Ultimate Sound T3 Series 4320 Car Audio Amplifier
Need Wiring Help
I just bought a 2006 Ultimate T3-4075 four channel amp in another rediculous attempt to power 2 boxed Alpine S-Type 6x9s and 2 open Kenwood 6x9s (all 4 200 watts). The power and everything seems to operate properly, but I cant get any sound in the freakin speakers. I expect that once again I have been played by some retard salesperson who really doesnt know stereo equipment. The speakers are 4 ohms, but the amplifier has a 2 ohm impendency. Can anyone explain this problem to me, and possibly offer me some advice on whether or not I should take this amp back and look for another. Thanks for your help.
    Problem Solver:
  • 8 Answers
How do u have everything wired for the amp and speakers?
Posted on Jul 25, 2010
Need help wiring two 10" alpine type E subs to a alpine 500 watt monoblock amp
Just connect both sets of wires from the subwoofers to the same speaker output terminals on the amplifier. Make sure you keep the positive and negative wires together. This is called parallel wiring. The Type E is a 4-ohm, single voice coil subwoofer, so wiring them like this will give the amplifier a 2-ohm load, and the power produced will be divided between the two subs.
http://crutchfield.custhelp.com/rnt/rnw/img/enduser/Mono_2-4OSVC.jpg
Jul 16, 2015 | Alpine Car Audio & Video
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
Wiring diagram for radio. 2004Chrysler Sebring LX Convertible. Also How to size a Amp to 4 6x9's 2channel?4channel?
you prolly want a 4 channel but it can be done with 2 channel and you would want about a 1000 watt amp for 4 6x9s that would be about 250 watts per speaker
Mar 24, 2010 | Car Audio & Video
How to hook it up to system with two 10s 400 watts per sub and two 6x9s at 200 watts each?,subs behind seats, 6x9s in doors. IF i need another amp i have one,to help push. But either way i need your help...
Hello www_mitzjohn,
I'd definitely use another amp.
The 2-channel Sony is well suited for powering the 6X9's but a monoblock would be better for the subs. The different types of speakers running from the same channel will not sound very good and likely it'll be impossible to get the impedances to match.
You'll want to set the Sony to send higher frequencies to the 6X9's, but not to the subs. You can't adjust the channels individually. So, just connect each 6X9 to one channel of the Sony and use a monoblock subwoofer amp for the subs.
Hope this helps.
Oct 31, 2009 | Sony XM-2150GSX Car Audio Amplifier
Bought some 6x9's now need an amp to power them up cause my headunit is weak.. umm any advice on what amp to get.. i only need to power 2 vibe qb69 6x9s so do i need a minimum 2 channel amp? hope you can...
I know this is a very broad statement, but your budget will allow for what you buy. You will want a nice 2 channel 50 watt rms amp min. 50 watts is a lot of power for those speakers and you will be happy. I would recommend if your budget allowed a nice kenwood, Alpine, Diamond Audio or MB quart. Just make sure whatever you buy that it is a low noise A/B class amp. Nothing to special.
Take care and have fun!!
Jun 03, 2009 | Kicker KX500.2 Car Audio Amplifier
Can a rf 201s amp push 4-6x9s and 4-104s door speakers
Hello jon_jonmay,
Wiring 4 speakers to each of 2 channels, you will need to wire them series-parallel and run them at 4 ohms. If you wire all 4 parallel, the load will be 1 ohm and the amp is only stable down to 2 ohms.
According to your manual, the 201s will deliver 50 watts into each channel at 4 ohms . So it will be supplying about 12.5 watts per speaker which is about what you get with the average factory radio. They will work OK, but they're not going to be very loud.
Hope this helps.
Apr 21, 2009 | Rockford Fosgate Punch 201S Car Audio...
Alpine eq 3331 install
USE THE FOR CH RUN ALL THE SPEAKER THE MEANS TWO RCA ONE FOR FRONT AND ONE FOR REAR INTO THE AMP AND NON-FADE REAR-FOR YOUR SUB --POWER FOR EQ--[POWER 'REMOTE AND GROUND]
Mar 26, 2009 | Alpine ERE-G180 11-Band Car Equalizer
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Adding a woofer to a 4 channel amp with 4 speakers
well yeah thats what im doin riht now in my ford taurs what u do is u can hook up your 5x7s and ur 6x9s on ur amp sill have room for a sub the way too do that is get the front speakers off the amp just run the back andsince its a four channlel amp 1 and 2 channel are used for the back and 3 and four are used for thesub of couse u brige the sub to the amp 3 and four are used for the sub hope that helps friend let me no what happens
Apr 08, 2008 | Car Audio & Video
Power Acoustik Area 51 Amplifier
I havthe same amp. Try moving youry ground t a different location. that seemed to help me when i was brigging mine.
May 08, 2007 | Power Acoustik Area 820x2 Car Audio...
Ultimate Sound T3 Series 4320 Car Audio Amplifier Logo
147 people viewed this question
Top Ultimate Sound Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you an Ultimate Sound Car Audio and Video Expert? Answer questions, earn points and help others
