Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Tv is showing red shadow
Had tv repair guy out to replace 2 things(schematics)? to get the coverage red to line up unfortunately or original remote is broken and he said we may need that to use to set restore the factory setting can you help?
Since he installed the (schematic) the color has improved some. We are using universal remotes.
  • Philips Master
  • 5,568 Answers
I understand that you already have 'universal' remotes but the link below refers to Philips brand remotes that may access the settings you now need:
Remotes
I can't say how responsive Philips is today but it might be worthwhile to email them with the model numbers of your set and the remotes offered above to see if they will let you kow if either of those will access the adjustment settings you need.
I wish the makers of those aftermarket remotes would introduce some honesty into their spiel by calling their NON-universal remotes 'multibrand' instead. I have a half-dozen so-called universal remotes in my junk drawer, including even a 'learning remote' that still doesn't program with the original.
Posted on Oct 31, 2008
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
WS55511Mitsubishi TV convergance problem
Your TV most likely has a problem in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 22, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Different color shadows appear.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 06, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Red shadow on TV Screen Hitachi HDTV
Your convergence is bad. You need to have convergence amplifiers changed.
Apr 21, 2009 | Hitachi 51F59 51" HDTV Projection...
Shadowed colors inpicture
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
Mar 12, 2009 | Hitachi 46F500 46" Rear Projection...
Turns blue and has shadows
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Sep 10, 2008 | Sony KP-51WS520 51" Rear Projection...
Hitachi 43FDX01B Convergence Problems
Hitachi remote part # HL01643........I like the original remote
to do adjustments.................T.
Aug 06, 2008 | Hitachi 43FDX01B TV
Replaced STK392-110 convergence chips in tv
1) You will need the original remote for alignment...
Note: Do not open set to adjust red line.....
2) Remove lower front speaker grill cover and possibly the
access panel....find RGB focus / screen block...adjust red
focus...................................T.
P.S.remote control part 23306269 $26.90 ...........
Dec 07, 2007 | Toshiba TP50H95 50" Rear Projection...
Shadow around objects in picture...shadow is bluish
  • Screen looks 3D
Oct 26, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
216 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
