Question about Lexmark C530dn Laser Printer
Lexmark T654 914.000 service dc pick up motor
I've tried the troubleshooting I can but where on the machine is the sensor flag?
5 Suggested Answers
Ajkill
  • 2035 Answers
SOURCE: printer troubleshooting
Use this link to troubleshoot:;
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS507&relevance=1
Posted on Apr 04, 2008
  • 5 Answers
SOURCE: Error message service dc pick motor on screen
Get new rollers.
They are held on with a little clip you push in and the wheel slides right off
Posted on May 07, 2010
SOURCE: I cannot find the ADMIN PIN for a new LEXMARK
The only way to gain access when the admin pin has been lost is to open the panel on the left side of the printer. With the printer off, rRemove the metal cover over the board. Look for a small yellow jumper. There should be a series of three pins with the jumper connecting the center and right pin. Move it to the left so it covers the left and center pin. Wait about a minute and then turn on the printer. You should be able to regain access to the menus. You may always want to do a restore to factory by holding in select (checkmark) and right arrow then turning on the printer and releasing the buttons after about ten seconds to gain access to the service menu. From in there you can reset the printer back to factory. You can also reset just the network to clear a forgotten web password for example. These instructions also work on the Dell equivalent which is a 5530dn I believe.
Posted on Jul 31, 2010
  • 138 Answers
SOURCE: updated to snow leopard and now I can't print with Lexmark x6570 wireless printer
do you try to restart the printer..do you check cables on it..if you try all..and didn't work..try to contact the hot line of the technical support.
Posted on Nov 15, 2011
Error 50.7 colour laserjet 6030
Its either the fuser flag or pressure switch would be my guess. Remember when troubleshooting something. KISs....Keep It Simple....its usually the easiest thing that fixed the problem. Replace the fuser then work out from there, especially since you have a spare machine to work from. Here is the Canon Service manual page on it. Good Luck!!
From the Canon Service Manual:
50.7 Fuser Error : Fuser has experience a pressure-release mechanism error
1) Reseat the following connectors: fuser motor, fuse-unit home-position, intermediate & the DC controller PCB
2) Test the Fuser Pressure-release sensor by performing the paper-path test or the manual sensor test
3) Check the sensor flag on the Fuser Pressure-release sensor. If the sensor flag is damaged, replace the fuser.
4) Check the inside gear on the product that drives the fuser
5) Perform the fuser motor & fuser pressure release motore components test.
6) Replace the fuser Motor
7) Replace the Fuser
Jun 04, 2012 | HP COL LJ CM6030 MFP P/C/S 30PPM 1 100SHT...
I have a Lexmark E240n printer. It keeps jamming at the same spot each time I try to print. Checked and tested the entry and exit switches. Checked good. All gears are turning smoothly. The paper jams...
does the exit switch stick up in the back of the fuser into the paper path? I've had to replace lots of the exit sensor flags because the top half was broken off while clearing a paper jam.
Apr 07, 2011 | Lexmark E240 Laser Printer
E450dn get's a paper jam any time two or more sheets are sent on a print job. There is no space between the papges to allow the input sensor to reach the Home position. How do I fix it?
This is a possible pick tire issue. Try to reverse the tires, turning it inside out. Fan the paper and adjust the tray guide. If that doesn't help, printer will probably require service. I suggest you contact Lexmark technical support or your authorized service provider. Thanks.
Jul 22, 2010 | Lexmark E450dn Laser Printer
Printer says tray 1 low, but paper is not low
Most likely has something to do with the sensor the pick arm's flag. Try to check if the flag is moving freely. If it is, the sensor may need replacement.
Jun 23, 2010 | Lexmark T520 Laser Printer
Get new rollers.
Dec 27, 2009 | Lexmark T640 Laser Printer
KEEPS SAYING PAPER JAM AND THERE ISNT ONE. DOESNT SEEM TO WANT OT PICK UP PAPER
ok im going to guess here that you are getting a 201 paper jam error with no paper in the printer. this would indicate a bad main motor drive replace it.
if its a 202 error check the 2 sensors on the fuser for stuck flags
if its a 241 error clean the pick wheels with aresol elctronic contact cleaner to remove the glue build up from them. or replace them
Dec 04, 2009 | Lexmark T640 Laser Printer
Constant paper jams in lexmark t614
it would help to have a bit more information on where the paper jams. but ill give this a shot any way. 241 jams clean or replace the pick wheels on the auto compensator. 201 jams no paper present change main motor drive. paper stops 3 inches through the fuser timming issue check the paper size i the paper menu check the fingers on the side of the tray letter is the 2 bottom fingers sticking out. if you have network port print the network page if it is smaller than the page change paper selction pcb located behind the logic pack. if the the line at the bottom of the read out is missing and the box is incomplete the printer is reporting leagal size paper change the paper size pcb. 202 errors check the sensor flags on the fuser. there are 2 sensors on the fuser the one on the left is the narrow media sensor the one on the right is the exit sensor. check to make sure the sensor flag is not broken. check them for fluid movement if you cant hear them snap back replace the sensors hope this helps you out
Oct 01, 2009 | Lexmark Optra T614 Laser Printer
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
Apr 17, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 7300 error message...
The problem is a crazy design in the printer itself! I've now found a reliable fix for this problem which is relatively easy to carry out. You will find the details of how to do it here :
www.michelsplace
Jan 24, 2008 | Xerox Phaser 7300DN Laser Printer
Lexmark C530dn Laser Printer Logo
183 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
