Question about JVC FS-G5 CD Shelf System
Where can I purchase an FM antenna for a jvc ca-fsg5?
3 Suggested Answers
dougcurrens
  • 4 Answers
SOURCE: fm Radio signal?
There was a black wire included (with a metal "cap" to insert in the FM center connector) that served as the FM antenna, but in a pinch any wire can do, preferably about 33" long and with the insulation stripped from the last inch or so (or get creative and sand the last inch of varnish off a properly sized untwisted clothes hanger and gently bend to suit). Bare stranded wire should be twisted or folded until it's thick enough to firmly fit the middle "hole" of the FM antenna connector. Be careful that no strands of wire short to the metal ground "ring" surrounding the hole or the antenna won't work (although it won't burn out your amp like shorting the speaker wires would, it just won't work). Orient the wire horizontally or vertically for best reception. This unit also doesn't pick up FM very well if you're in a steel-framed building or away from windows in the general direction of the local transmitters, so moving the unit closer to a window may help dramatically. In bad reception areas you can get an external FM "rabbit ears" type antenna but you'll need the "European" style of 300 ohm to 75 ohm transformer to plug it into the unit's FM connector (one that has a bigger central connector "plug" than the usual US units). Some cable systems also still support FM, if yours does, a VHF/UHF/FM signal splitter and either the above mentioned transformer attached to flat 300 ohm cable or a plain  "European" style connector attached to the end of the 75 ohm round black cable will do the trick. Some Radio Shacks have them. Good luck!
Posted on Feb 11, 2009
Ironfist109
  • 3018 Answers
SOURCE: NEED A MANUAL FOR JVC
Here is the users manual you requested in PDF http://resources.jvc.com/Resources/00/00/94/LVT1349-001C.pdf
Posted on Mar 23, 2011
On the back of my jvc mx 200, there is an FM antenna input that says F 750. How do I get it to receive FM broadcast?
Ideally, you need an FM antenna, which is usually a folded dipole loop, looking like a 'T' made of parallel conductor. The input impendance, symbol Z, is usually 50 ohms, so the F 750 may be
F Z50 with bottom of Z not visible.
F=Frequency modulated input
Z=Impedance
50=50 ohms impedance
The number '750' makes no sense, as the FM broadcast band frequency of 88-108 MHz is way below 750MHz (UHF), and impedance at 50R is well under 750 ohms.
Tip:
Although a proper FM antenna is recommended, in good reception areas, such as near a city, a single insulated wire stuck into one 2-pin FM socket or center-pin of a coax FM socket can give reasonable reception.
Dec 18, 2017 | JVC Audio Players & Recorders
There is no electrial retailer in bendigo that has fm aerial to suit this is why i am asking you
Make your own.
  • How to Make an FM Antenna: 8 Steps (with Pictures) www.wikihow.com/Make-an-FM-Antenna
    • 832K VIEWS
    2016-01-11 ยท How to Make an FM Antenna. Improving the reception of commercial FM radio (88Mhz - 108Mhz) can be done by you at home, simply by replacing the antenna ...
  • Simple FM Radio Aerial - Robert Sewell www.robertsewell.ca/yahoo/fmaerial.html Simple FM Radio Aerial A simple FM radio aerial can be made using about 5 feet of old 300 ohm TV downlead, an alligator clip and some hook-up wire.
  • Or try Jim
  • Antenna Installation Bendigo
    May 23, 2016 | Audio Players & Recorders
    Where can I purchase an fm aerial for this jvc
    Just about any electronics or big box store (Walmart, Target, etc.) will have an FM antenna. They will be in the electronics section.
    Mar 18, 2015 | JVC MX-J30 CD Shelf System
    JVC CA-FSG5 service manual
    Manual has many sections. Specifiy which one do you need. Service manual, schematic, parts list, etc.... email me jpulickal@gmail.com
    Feb 13, 2012 | JVC Car Audio & Video
    MY Jvc KD-SX939R. FM is not working but the CD is Good.
    did you pull the unit and check the antenna going into the radio make sure that it's fully in.
    if that not it follow the antenna line back and see if there are any other spot that the antenna line plugs into.
    i hope i help you out some how
    Feb 25, 2009 | JVC AM FM CD DET FACE CAR STEREO
    JVC detachable face with auxillary input
    You may have a bad antenna or antenna cable.
    FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
    Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
    Fm Radio signal?
    Jul 23, 2008 | JVC FS-5000 CD Shelf System
    JVC FS-G5 CD Shelf System Logo
    Top JVC Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
