Question about GE Dryers
No head on model # DCvH515GF0WW
Power works, gas works. everything but heat. replaced ignitor. still no heat any suggestions?
SOURCE: gas dryer will not heat
The dryer will not heat i check the vent to make sure no upstruction and open the back to make sure no wire was lose. where will the fuse be kenmore model 76722697 serial No. 0702383
Posted on Jan 18, 2008
SOURCE: Gas dryer not heating up
dear sir
hi
would you please let me know more about the system of dryer.
sincerely
j.alavi
Posted on Feb 24, 2008
  • 14 Answers
SOURCE: no heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Posted on Jul 25, 2008
rylee_smith
  • 8619 Answers
SOURCE: Also have a Whirlpool dryer that tumbles but no
Hi!
Please check the thermal fuse, this fuse blows and can only be replaced not repaired. Check for the continuity in the fuse using a multimeter.
Please revert for any clarifications.
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Posted on Mar 14, 2009
  • 77 Answers
SOURCE: maytag gas dryer, no heat, ignitor wont glow
The machine will check all safety features first. check the overlimit by the burner. It may have a reset. If not, turn power off and check continuity (ohms). Good luck.
Posted on Apr 18, 2009
I have a Kenmore gas range. The bake option doesn't work but everything else does. I've replaced the ignitor and still doesn't work. Any suggestions?
does the ignitor glow orange?if so could have a bad gas valve,clogged orifice,gas can't enter the tube.if it doesn't glow,bad clock assy.next time send the model number off of the machine
Nov 21, 2012 | Kitchen Ranges
MY carrier model #58DHC with hot surface ignitor has quit working. Blower works, but no heat. If you turn the thermostat to on fan will run but no heat. Did preliminary testings with self test on printed...
If you suspect its the ignitor? The hot surface ignitor is powered by 120v. Inspect ignitors' hot surface for cracks or burnt spots. Uplug ignitor from board. Cycle heat on and verify 120v to the ignitor at the cannon plug on the board where the ignitor plugs in. If you have the voltage then replace the ignitor. If not, you'll need to verify all other circuits are working before condemning the board. Work safe and at your own risk! Hope this helps!
Mar 25, 2017 | Heating & Cooling
My Maytag Gemini cooktop and top oven work. The bottom oven will not heat up past 100 degrees. What is the problem?
Replacing the ignitor is not difficult or dangerous. To get at it, you will first take out the racks. Then undo the box-like cover inside the bottom of the oven; the screws face front. Underneath that is a wing-shaped cover, held in place with wingnuts. Remove it.
The pipe that the gas comes out of heads straight back; the ignitor is just to the left. You'll be able to see the wires going out the back of the oven. Remove the plates that hold the tube/ignitor combination.
Once the pipe is free, then get your head out of the oven and pull out the oven so you can see, and get at, the back. On the lower left is a cover, about 12 x 15 or so, held in place by four screws. Remove it.
At this point you can see where the ignitor connects to the orange wires (at least mine are orange) with a plastic connection. Undo that connection.
Viola! You have removed the ignitor! Now, before you forget, make a diagram of everything you did. Put the screws in separate plastic baggies, with paper number tabs that correspond to your drawing. This will greatly help in putting everything back together.
Dec 12, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I have a Kenmore Dryer model #110.66732500 that just quit heating. Everything else is working fine, tumbles but no heat. It is 4.5 years old. When it quit it tripped the circuit breaker, we reset the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
bn
Sep 28, 2010 | Kenmore Dryers
Oven does not heat, no sign of a lit burner but broiler works. Suggestion to check ignition system would be appreciated. thanks Russ and Sherry Model 17bew5bb sn ff642442d
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 15, 2010 | GE JGRP17 Gas Single Oven
Gas oven stopped working it heats up to 100 like it is supposed to then there is no whoosh sound and no futher heating .yes there is gas. it did this once before and then worked like it was supposed to...
Every time I have done this repair, the problem was the ignitor, even if it is glowing. Replace your oven ignitor, ask the parts company if there is a cheaper generic ignitor for your model. You could have a bad valve or a sensor, but since they came out with these ignitor models 12-15 yrs ago, it has always been a bad ignitor,. Good Luck, Appliance Specialists
Dec 20, 2009 | Washing Machines
Our stove was not heating up, but the electric pilot was glowing red, we replaced the gas valve, and it still will not heat up....what do you suggest?
Hi, The problem may not be so obvious. It sounds very crazy but the problem can still be with the ignitor even though it is glowing and heating up. The gas valve will not turn on unless the ignitor pulls a aet number of amps. of power. When theignotor ages it can stop drawing the same amount of power and the gas valve won't turn on because it thinks that the ignitor is not owrking correctly. I went through this with a couple of different ovens, the first one really took me awhile to figure out. Change the ignitor and your oven will work again!
Nov 16, 2009 | Ovens
Its the same problem
SHUT PWR OFF ALWAYS , GO BEHIND OPEN PANEL, REMOVED PANEL THEN CHECK LIMIT T`STAD, THEN VOLTAGE @ IGNITOR HARNESS. IF GOOD THEN CHECK COIL @ SAFETY VALVE, BUT LOOK A THE IGNITOR IF TO BLAK NEEDS TO BE REPLACE
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
