Question about Siemens Washing Machines
Siemens xl 1600 washing machine wont spin
Xl1600 wont spin
yalmer
  • 549 Answers
SOURCE: My siemens XL 1600 washing
If it is out of balance this can occur.
Try leveling and then make sure the load is not lop sided.
Posted on May 27, 2008
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
kjmac
  • 97 Answers
SOURCE: washing machine
is all the water out of the machine if not the door wont open.
if all the water has gone, have a look behind the small flap on the front of the machine where the filter is and there might be a small plastic loop which when pulled should release the door catch.
please note i say might as some models have this feature and some dont.
hope this helps
Posted on Jul 25, 2008
jyackle5
  • 8197 Answers
SOURCE: my siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Posted on Dec 16, 2008
  • 190 Answers
SOURCE: SIEMENS XLM 1600 WON'T GO INTO SPIN CYCLE
Dear customer,
                     When the spin cycle doesnt occur the most recommended steps are
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission.
  You can click on the highlighted words to get details abt the checking procedure..
Plz rate this solution.. thank you..
Posted on Apr 09, 2009
Hello, I have a Siemens 1600 WXL166AGB (1600 XL) washing machine. there is a humming while still washing and then it stops and beeps on drain, but not every time. have cleaned out filter, impeller turns,...
Sometimes the impeller can wear so that it is pulled to one side and jams intermittently. Try removing the pump and running it outside of the machine to see if you can catch it misbehaving. Or just replace the pump.
Sep 13, 2013 | Siemens WK61420GB Front Load Washer /...
Code E13 on siemens washer
Pump may be clogged
Washer controller may not be changing from agitate to drain-spin. Check by manually advancing to spin or selecting a spin-only operation.
Sep 12, 2012 | Bosch Siemens Washing Machine Drain Pump &...
Siemens s.16.38 washing machine doesn't always spin so clothes come out soggy
The washing machine picks up on wait and will only spin if there is enough weight. Make sure that the washing machine drum has enough weight in it so that it can spin properly.- This what a Siemens washing machine engineer told me as I had the same problem.
May 04, 2011 | Washing Machines
I have a Siemens Washing Machine WM 1000. After a good service it has a problem now. The container is not spinning though it sounds like the motor is running. It has happened suddenly. Perhaps the gear...
There might be a problem in the pump, which drains the water. to confirm it, please manually release the water, by opening the bottom right port, Then try if the spinning is working. The pump approximately costs Rs. 1600/- approx. please check & confirm. Regards, Sivaraman H, Bangalore-560016. Mobile number: 9845228625
Dec 17, 2010 | Siemens Washing Machines
Dear customer,
  8. Test the motor
Apr 09, 2009 | Siemens Washing Machines
My siemens washer will not pump the water out or spin
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Servis easy logic 1600 wont spin
servis easy logic 1600 wont spin just moves the drum half a turn and stops but repeats all the time
Aug 17, 2008 | Washing Machines
Washing Machines Logo
141 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
