Question about Creative Technology SBS A200 2 Speakers
The Creative A200 subwoofer is not working but the 2 little speakers are
On the board where the power switch is one of the peaces looks melted maybe had a short
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: Please help me solve a satellite sound problem
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Jun 23, 2011
Testimonial: "Thanks bronk50 that was helpful but has not sorted the sound issue. the subwoofer is ok but ithink there is a cooked component that distributes sound."
How to connect the right speaker straight to the board of the main Creative A200 2.1 speakers? My male pin is cut and lost, I want to solder the wires straight to the board.
Look at the board and trace the route of the circuit on the board. solder it to the trace closest to where the pin is on the board. You should be able to solder it to the stub of the broken pin as well. Just make sure you have no solder bridges when you are done. Best practice if you can is to take a picture of the area before you start so you can see exactly what was soldered and compare it to your repair, any solder bridge will be obvious.Don't overheat things traces are easily ruined by overheating!
Jan 01, 2015 | Creative Inspire 2.1 A200 Computer...
How to open the subwoofer of the creative sbs a200
Simply unscrew black back panel. Circuit is attached to plate. Sockets sealed with hot glue for air tight. You can melt hot glue with solder iron if neccessary.
Apr 21, 2013 | Creative Technology SBS A200 2 Speakers
I have a creative speaker A 200 model number MF0355. its IC was removed by someone and i need to replace it but i don't know the part number so anyone with any info please i'll appreciate..
Hi, which IC?
Board has 3 IC.
Two of them SJ8227L but hard to find item try this link: http://www.aliexpress.com/wholesale/wholesale-sj8227l---dip.html
This chip look like Toshiba TA8227P equivalent and do not forget SJ8227 or TA8227P needs heatsink!
Third one is 8 legged F4558 opamp.
Jul 25, 2012 | Creative Technology SBS A200 2 Speakers
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
I have creative 2.1 channel with sub woofer and 2 speakers (left&right) all of sudden my right speaker is not working left only working then I pluggeg right speaker to left speaker jack in sub...
I have a similar reoccuring problem with the left channel on my speakers. All of a sudden, while playing music or whatever, the left channel jusr dies. Turning the system off and then on again from the conrol unit does not remedy the situation. By chance, I discovered a workaround to get the left channel working again: Push the main power switch of the subwoofer until it almost switches off and then release it so that the power is never actually switched off. Now a click is heard in the system and the left channel comes alive again. This is quite annoying and seems to have something to do with switches in the subwoofer. Low quality components may have been used. I 've been thinking of getting another 2.1 system, but it's not easy to find one... Maybe I should open the subwoofer box and go through the switches and possibly hardwire some connections...
Jun 27, 2010 | Creative Labs MegaWorks THX 250D Computer...
Subwoofer will not play with other speakers
Hello
It looks like you have posted this before. Unfortunately, I don't know what you have tried so I may be repeating some of your earlier troubleshooting.
The subwoofer needs its own power supply to function properly. if it isn't getting enough power, the sub will not work at all.
On the back of the unit, you should see a green LED when the power is turned on. Is this light on all of the time of does it fade / flicker? This would indicate the power supply is going bad and you need to replace it.
http://forums.creative.com/t5/Speaker-Systems/GigaWorks-S750-power-problems-green-LED-faded-and-flickering/td-p/547311;jsessionid=9B7C9D2D939336148A9036D7E7D18A12
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
No sound from creative t3030 2.1 speakers
the circuit board and amplifacation supply inside the sub are blow or shorted out.thus preventing any sound. the head phone jack works only because it is a bypass feature supported by the actual computer not the surround sound unit
Jul 23, 2009 | GE Ultrasonic 2.1 Subwoofer Computer...
Sound card in PC is operable
Look at the plug.... is it metal then a little band and then the tip or is it metal a band then metal and then the tip.
Aug 30, 2008 | Yamaha YST-MSW10 Computer Speakers
Yamaha YST-MSW10 subwoofer quits after about 10 minutes
This problem can be solved by either of the following:
1/ Modify the PCBA to prevent the auto shut off feature from working. This is done by adding a 20k ohm resistor across pins 1 & 2 on the timer IC6. This resistor will prevent the timer from turning off the amp. To do this, unplug the amp. Remove the 8 screws on the perimeter of the rear of the amp. Carefully remove the rear plate. Disconnect the speaker wires at the speaker and the front panel connection on the main board. Locate IC6 on the bottom of the main board. Solder a 20k ohm resistor (1/4W) across pins 1 & 2. Pin 1 and Pin 8 are noted on the board. Be sure to insulate the leads of the resistor to prevent contact with the board. See picture. Re-assemble in reverse order.
2/ Some 5.1 channel amps allow independent control of the volume for the subwoofer in their setup. Check your amp to see if you can raise the signal level going to the subwoofer to prevent the amp from shutting off. You can then dial back the volume of the subwoofer using the volume control on the front._436.jpg
Aug 07, 2007 | Yamaha YST-MSW10 Computer Speakers
Creative Technology SBS A200 2 Speakers Logo
79 people viewed this question
Top Creative Technology Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Creative Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
