Question about KEF Audio KIT100 System
Kef instant theatre - kit200
Trying to unlock code on dvd to open for all regions, can you help ?
thanks for your helpregional
    Novelist:
  • 189 Answers
Nice player. I'm not lucky enough to own one myself, but I found this info which might be worth a try:
Kef Kit 100 & Kef Kit 200 Instant DVD Theatre handset hacks 1. Press & hold the "Skip Back" button, "Play" button & "Volume Up" button on the main unit.
2. After a few seconds the front display should display "PAL RESET"
3. Release the "keys.
4. Power off your unit at the mains.
5. After 20 seconds, power on your DVD player, thats it!
Posted on Oct 30, 2008
RECENTLY I HAVE BOUGHT A PHILIPS HOME THEATRE MODEL - HTS 3265 . ONE DAY I WANTED TO PLAY STAR WARS MOVIE DVD INTO IT. BUT NOT OPERATING.IT IS SHOWING REGION AND STOP PLAYING. PLEASE GUIDE ME FOR THIS...
HI,
ur dvd player has region lock . it will not play all the disk. check the DVD OF STAR WARS MOVIE which region it belongs. jus try the following not sure is it work or not
Open the tray. Press 99990 on the remote.
by doing this ur dvd player will become region free
then insert ur dvd and try.
for region 1 and region 2 code is 99991 ,99992 respectively.
feel free contact through fixya.
ok
Dec 21, 2010 | Philips HTS-3565 Theater System
Need region code to unlock LG dvd home theatre HB905PA
If you live in the US your region code is 1
if you are able, put in 0. this will allow you play DVD's from all over the world regardless of region code on the particular DVD.
DVD region code
Sep 15, 2010 | Audio Players & Recorders
How to connect Panasonic DMR-EZ25EB to KEF KIT 120
OK for some odd reason I never noticed that this was a reghurgitated question
BUT hey
The only way to really do what you want is to insert an AUTO HDMI switch to the AV1 and go from there.
http://www.monoprice.com/products/subdepartment.asp?c_id=101&cp_id=10110
Have a selection
Oct 06, 2009 | KEF Audio KIT120 Theater System
Kef dvd is stuck in tray. It is trying to read it and now wont allows us to eject, change for sat sound NOTHING!! Help!
First you do is to unplug the cord of your DVD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the DVD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the DVD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the DVD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you; Regards; VOTIT DONT FORGET TO RATE;
Jun 10, 2009 | KEF Audio Instant Theatre KIT200 System
Unlock Region Code for LG XB12 Mini Home Theater
Below is the only known process to unlock the region settings on that model of dvd player.
Make sure there is no disc in it
Turn on by pressing "Power"
(--------) apears an "No Disc"
Press "Pause" on remote and "314159"
"Code" apears
Press "0"
"Code 00" apears
press "enter"
Turn off and on
Hope this works for you, let me know. If it doesn't then there are no available region hacks for your dvd player.
Thank you for trying Fixya!
Mar 25, 2009 | Sylvania DVC-840E DVD Player/VCR
Unlock code for my Philips MCD 177
I need a region unlock code for my Philips Micro Theatre MCD290 DVD
Nov 17, 2008 | Philips MCD288/37 DVD Micro Theater System...
Wrong region
Hi , The reason for the error message is because your DVD player is set to one specific zone. The below procesure will open the DVD player to play all zones.
TURN ON THE PLAYER
PRESS OPEN/CLOSE
USING REMOTE PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL APPEAR. PRESS "0" TO UNLOCK (OPEN the DVD player to ALL zones) ALL, THEN WAIT. INSERT YOUR DISC. Hope this helps. Let me know the status. Thanks, Mike
Nov 03, 2008 | Audio Players & Recorders
Unlock the coby DVD-755 to free region use
I believe this works - I've yet to try it myself! Coby DVD-755 1 user region code/hacks August 13, 2007 Post region code/hack comment Region code hack posted by Peter, August 13 2007: DVD -755 from Walmart home theatre for $79.00 1-Press ?Setup? 2-Press Vol +, Vol-, Vol +, Vol -, 3-Number shows up 4-Change the region code by using RIGHT arrow. 5=Press ?Setup? to exit. Succesfuly tested bt Peter F.
Jun 29, 2008 | Coby DVD-755 System
Phillips LX3600 Home Theatre
Power up the set and open tray in DVD mode.
Press <9999> follow by <X> buttons on the Remote control.
where x = numeric 1 to 6 denoting the regions below:
Then show your region on TV
1 = USA
2 = Europe
3 = Asia Pacific
4 = Australia, New Zealand, Latam
5 = Russia, India
6 = China
0 = Code Free
This is taken from the original service manual for the reciever
Jan 27, 2008 | Philips LX3600D System
KEF Audio KIT100 System Logo
728 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Greg Cann
Greg Cann
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
