Question about Horizon Fitness Exercise & Fitness
I need an assembly manual for an horizon omega 500 elite treadmill
Omega 500 Elite
SOURCE: Request manual for treadmill.
I have a manual for this exact treadmill. Don't have a scanner though. I checked with my local print shop ans they said they could scan it and save as a pdf for $10, if you are interested.
Posted on Jun 19, 2009
  • 16 Answers
SOURCE: Need to put together a Nordic Track Elite 2900 treadmill.
Type into the serch, icon health and fitness, then click on the customer service, then click onto the manuals and the instructions should be in the owners manual.
Good luck.
Posted on Jun 29, 2009
  • 14 Answers
SOURCE: I have the horizon elite 507 treadmill, how do I
Is it all the way over to one side? Is the belt damaged on one side? If it is damaged you will never get it to Track correctly.
If it is not damaged, then start the treadmill moving at about 2.5 mph, if the belt is all the way to the right then turn the right rear roller adjustment bolt, clockwise one full turn, and wait. did the belt move over a little? if yes the increase the speed to 5.0 mph and observe.
Make small adjustment from one side only until you get it straight.
Posted on Jul 08, 2009
  • 16 Answers
SOURCE: What silicone oil is needed on Horizon Paragon 408 treadmill?
You should be able to google the answer.
Posted on Jan 29, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a Horizon elite 507 treadmill, everything
Unplug your treadmill and remove motor shroud ,locate Motor control board their a series of LEDs . Now without getting on treadmill hit start look down and you should a light starting to flicker this is your PWM signal, t the upper console sends a signal to the lower board and instructs the motor to start. This tells me that the upper board and cable are functioning properly and our problem is either the board or motor.
DC motors can be easily tested in a number of ways. Many times a motor is replaced only to find another problem exists so be sure to test the motor if you think it is a problem. Methods to test a motor: 1) Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH. 2) Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
If the motor test good then all fingers point to the Motor Control Board replace the board. When was the last time lubricated the running deck?
Answer: Never ! Then I suggest you purchase lubricant and apply it on the deck about 75% to 85% of the problems are belt and deck related.
Posted on May 23, 2010
Testimonial: "Many thanks for prompt response, seems that the treadmill works only when in the upright position and not the horizontal as per normal. Gonna have to learn to run up walls i guess"
Omega 3 treadmill - Does anyone know what might be wrong with my tread mill? its showing 500 on the screen and is not starting.
replace the old batteries (if your system have batteries, clean the contacts batteries) put a new ones.
2) adjust the REED swtich see the diagram attached.
3)tight the ribbon cables inside from display board and clean it. tight and clean the upper and lower connector. and try again.
God bless you64554154-b7bd-4100-8a70-779a1727ba63.gif5b2cf7d6-545e-4e9e-80cd-605d4c8ca29d.gif
Oct 16, 2013 | Horizon Exercise & Fitness
Manual car seat model 22456 CAB
hello
i can not install my new alpha omega elite car seat model 22456.CAB please guide how can do it ?
Jan 08, 2012 | Safety 1st Alpha Omega Elite 3in1...
Don't know how to connect for rear facing
Here is a link with instructions to follow to install the seat in a rearward facing position. Good luck.http://www.ehow.com/how_7624391_instructions-cosco-alpha-omega-elite.html
Jul 25, 2011 | Cosco Alpha Omega Elite 5-Point 22-155
Looking for an online car seat manual for my Alpha Omega Elite (2007). Cannot find with general searches. Any suggestiions?
Go to the site thru the link below. Put in your model number and date of manufacture.
It will give you the manual.
Alpha Omega Lookup
Mar 29, 2011 | Cosco Alpha Omega Elite - Hammer Print
I need a owners manual for my cardio zone treadmill we bought it and did not get a manual
You have a Horizon Elite Treadmill.
Owners manuals can be found at
http://www.horizonfitness.com
look under customer support, archives/manuals
Dec 15, 2010 | Elite Exercise & Fitness
How to remove base off of Safety 1st Alpha Luxe car seat?
How do you get the base off of the saftey 1st alpha omega elite car seat ?
Sep 28, 2010 | Safety 1st Alpha Omega Elite 22456 TTN...
Need a manual for cosco alpha omega car seat
You can input your seat's model number and date of manufacture from the label on the seat itself at Cosco's website to download the instruction manual at http://www.coscojuvenile.com/instructions/
Sep 05, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
Cosco Alpha Omega Elite car seat
Manual is available at the manufacturer's website
Mar 19, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Exercise & Fitness Logo
137 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
